#151 | |
Re: Ford Model A Tudor Modern Twist on a Classic
Project "Eagle Spirit" 52 Chevy http://67-72chevytrucks.com/vboard/s...d.php?t=763085 Project "LS Scout" https://67-72chevytrucks.com/vboard/...d.php?t=844133 |
#152 |
![]() Join Date: Sep 2016
Similar issue. Push rode between the booster and master cylinder was ok, but I had adjusted out the brake pedal rod thingo so it was too long. That caused the booster to sit about 50% closed when the pedal was released. Now I've gone too far the other way so somewhere in the middle will end up being my sweet spot.
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
#153 | |
How did everyone pass up this update?! Doing your own upholstery is a pretty rare thing around here... this is awesome! Well done.
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
Tags |
ford tudor sedan ls |
