05-09-2023, 09:57 PM | #1 |
Front end rebuild kit question
My 67 has been converted to 5 lug front disk brakes at some point in its life. Im assuming someone probably used parts from a 72. From what I can tell, truck still sits at stock height and suspension is still stock.
My question is, the front end rebuild kits I have seen, the kit for the 67 and the 72 are different, so Im not exactly sure which kit I need. What parts of the rebuild kit (ball joints, tie rods...etc) would have changed when switching to 5 lug disk brakes? Thanks. |
05-09-2023, 10:21 PM | #2 |
Re: Front end rebuild kit question
Pics would be helpful
05-09-2023, 10:22 PM | #3 |
05-10-2023, 07:14 PM | #4 |
Pictures of current setup
05-10-2023, 07:28 PM | #5 |
Moderator
Do the spindles have any part numbers on them? The easiest way to deduce what you have is pop a tie rod end off and measure it with a micrometer, then go to a local parts store and have them pull the corresponding tie rod end for a 71/72 c10 and a 73-87 c10 and compare/match. One of Those two spindles are the most likely that were used.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
05-10-2023, 08:22 PM | #6 |
I'd be willing to bet. You need 71/72 parts for everything that touches that spindle. Ball Joints, Tie Rod Ends. The upper ball joint has been replaced, probably with the 71/72 to fit the spindles. Lower ball joins most likely got replaced with the 71/72 also...
The inner tie rod ends are most likely 71/72 also since the 'tie rod adjusting sleeve' looks like the factory type, I'm not aware of a 'conversion' adjusting sleeve that looks like that.... It surely is the 71/72 connecting bar coming off the steering bar going to the tie rod ends. |
