09-06-2022, 02:21 PM | #101 |
Re: Back to the fifties with a 59 project
Lookin REAL good bud!
09-14-2022, 10:32 AM | #102 |
Cruzin
Passenger side done.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
09-14-2022, 06:29 PM | #103 |
Cruzin
Started a floor patch. I didn't see the point of spending close to $100 for a patch I would only use a small part of so I'm just using metal I have. It won't look factory but nobody will probably ever notice.
09-14-2022, 06:49 PM | #104 |
Looks great Steve
My 57 Fleetside C4 build. http://67-72chevytrucks.com/vboard/s...d.php?t=817054 |
09-17-2022, 02:10 PM | #105 |
Cruzin
Floor patches done.
09-17-2022, 02:14 PM | #106 |
Cruzin
I have to fix above the windshield some spots but I'm gonna take a break from the welding,cutting, grinding. Would like to remove the cab and finish the frame cleanup and suspension.
05-20-2023, 12:40 PM | #107 |
Cruzin
Cleaned up the rest of the frame. Welded in some metal where I clearenced for the rac and pinion. Also removed the old trans crossmember.
05-20-2023, 12:43 PM | #108 |
Cruzin
Welded up everything fully and got the front suspension mocked up and the steering rack also.
05-20-2023, 12:53 PM | #109 |
Cruzin
Got a late 70s camero rear end and got it bolted up moved to the top of the springs, not welded until I set the pinion angle etc. Fab up me some leaf spring plates. Got it centered and good enough be able to make it roll. Got to work on shock mounts still maybe a small c notch not sure yet. Also planning on do a disc brake conversion since the price isn't really that much more than totally rebuilding all the drum brakes.
05-20-2023, 12:54 PM | #110 |
Cruzin
We have a roller!
05-20-2023, 10:41 PM | #111 |
nice progress.
question, with the lower control arms sitting level, what angle is the upper control arm? |
05-22-2023, 07:58 AM | #112 |
Cruzin
I really haven't even noticed, but it needs weight on the front to get everything where it needs to be. It is stiff up front with everything new and i ordered the upper end of stiff coil springs. I will probably end up cutting a little off of them but i'm waiting till i get all the weight on it and they have time to settle.
05-22-2023, 09:46 AM | #113 |
Looks good!
71 C10 72 K20 72 K10 Super Kirk |
10-04-2023, 05:05 PM | #114 |
Cruzin
Gonna post some progress. I finished cleaning the frame and underside tof the cab. Painted and seam sealed, painted frame where cab will set.
10-04-2023, 05:07 PM | #115 |
Cruzin
Reinstalled cab with new mounts etc. And decided to try and mock up engine and trans.
10-16-2023, 06:56 PM | #116 |
Cruzin
Built some motor mounts and mocked them up. Not a professional job but I made with what I had and a welder and a grinder. I'm not as happy with the driver side it was a little different mounting wise but I think I'm gonna leave it.
10-16-2023, 07:00 PM | #117 |
Cruzin
Got the trans crossmember fitted and welded on some mounts and mocked in place. It came from speedway motors universal 2in drop crossmember very happy with it.
10-16-2023, 07:28 PM | #118 |
engine mounts look fine. curious what your driveline angle is now. angle at pinion should match but be opposite the angle at the trans. that way the vibrations cancel each other.
10-16-2023, 07:31 PM | #119 |
if you needed to by steel for that i suggest square tubing with a decent wall thickness, then cut one side off to open it up. works well.
10-16-2023, 07:53 PM | #120 |
I like the amount of space the 6 cylinder gives for the steering column to rack gives, should be a straight shot.
My 57 Chevy truck build.http://67-72chevytrucks.com/vboard/s...d.php?t=541132 |
10-16-2023, 08:42 PM | #121 |
I noticed that as well. nice.
10-16-2023, 11:06 PM | #122 | |
Cruzin
I was worried about that but looks like it not gonna be to bad.
