Old 10-12-2022, 09:09 PM   #126
72c20customcamper
72c20customcamper's Avatar
Re: My "new" 1968 c20
The fender was worse than expected .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-12-2022, 09:15 PM   #127
72c20customcamper
Painted the white today on the grill and fender . The inner skirt and hood latch I painted with DCC black with a flatner added . It was glossy for a while then flattened to a nice semi .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-19-2023, 03:25 PM   #128
72c20customcamper
Really need to update this thread body sans hood is all done . Just put the seat in today
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-19-2023, 05:45 PM   #129
regan wilson
regan wilson's Avatar
Neat old truck. Good work man.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
regan wilson is offline   Reply With Quote
Old 04-19-2023, 10:37 PM   #130
68bowtie
68bowtie's Avatar
Looking good
I live in California, but identify as a Texan
"If a job's worth doing, it's worth doing well"
Survivor "Lil’ Mint" (67 c10 40k mile light green original paint)
Old 04-21-2023, 10:31 AM   #131
72c20customcamper
Thanks it’s been a lot longer than I expected . Started as a spruce up and pretty much became a full resto . Redid the bed
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-21-2023, 05:06 PM   #132
72c20customcamper
New lettering rims and tires . Well the rims were on my 72 when I bought it and the tire res I put on so they have a few thousand miles on them
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 04-21-2023, 05:58 PM   #133
Louisvillekytruck
Very nice work mark
Louisvillekytruck is offline   Reply With Quote
Old 04-21-2023, 06:50 PM   #134
knuckle-nurse
Beautiful truck. All 3 of my trucks are 20's....they need to be able to pull and haul right? Great work.
72 Cheyenne C20 BB, air
70 Suburban 20 BB, air, buckets
68 CST C20 air, buddy buckets
knuckle-nurse is offline   Reply With Quote
Old 04-21-2023, 07:38 PM   #135
72c20customcamper
I have three 20s and a 10 that I lowered.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-15-2023, 02:14 PM   #136
72c20customcamper
Ammo box installed and reworking the hood which had some dents right at the front lip so I decided the easiest way to fix it was to remove the inner brace . Glad I did it was pretty rusted and looked like no paint was applied to the inside of the brace and the front of the hood . Guess I know why the front lip on the hood Rots away. They must have primed after it was assembled
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-15-2023, 03:30 PM   #137
cornerstone
cornerstone's Avatar
Super nice work man.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 05-15-2023, 03:37 PM   #138
72c20customcamper
Thank you
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-15-2023, 04:10 PM   #139
Louisvillekytruck
Looks great as usual mark
Old 05-15-2023, 08:44 PM   #140
72c20customcamper
Usually not a fan of undercoat but it kept the underside of the hood in great shape where it was applied . I did find two cracks on the two rear hinge nuts easy fix just ran a bead on them . Ran a tap through the blind nuts just to clean them out .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-16-2023, 07:11 AM   #141
Warrens69GMC
Warrens69GMC's Avatar
Great job!
Old 05-22-2023, 05:40 PM   #142
72c20customcamper
Last bit of bodywork the hood . Fixed the leading edge dents and stripped the paint and rust . Going to hit it with the DA tomorrow there are a couple of small dings here and there so I’ll fill them as needed. Best tool I ever bought
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-22-2023, 10:03 PM   #143
cornerstone
I have a different brand of the same tool and you're right, they are excellent. It's like a flap disc on steroids. At 30-60 bucks a pop I wish the drums would last longer though. Which grit or style drum did you find the best for paint removal Mark?
Brian
Old 05-23-2023, 08:21 AM   #144
72c20customcamper
This type works the best I start with it and then go to a 100 -120 grit if you go to fine you can heat the metal . I’m going to try the Harbor freight brand drums they look the same but are much cheaper
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-23-2023, 03:55 PM   #145
72c20customcamper
Got the spare on . Now I need a tire cover
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-23-2023, 05:23 PM   #146
3757chevy
3757chevy's Avatar
Very Nice.
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 05-23-2023, 07:19 PM   #147
72c20customcamper
Hopefully I’ll be taking this truck to the SETN in July I’ll have to trailer it 4.57 rear sm465 not highway friendly. But my BIL is using my enclosed trailer to store some furniture because the contractor is repairing his living room and den lots or water damage .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 05-27-2023, 05:39 PM   #148
72c20customcamper
Body work is done . Inside painted going to let it sit a couple days then top coat the outside .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-25-2023, 04:30 PM   #149
72c20customcamper
All the paint is finally done . Now I need three men and a boy to put the hood back on . The truck is pretty much done . My makeshift booth worked out nicely the whole truck is done in single stage no clear
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 06-25-2023, 04:31 PM   #150
72c20customcamper
These EZ wall zipper things work well .
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
