What should you upgrade?
Hello, I am looking for things to upgrade/modernize when rebuilding/restoring my 1970 Chevrolet C10. I am looking for (functional) items, some of the ones I have planned are:
Front disk brake conversion (1973-87 HD rotors, 2.5” drop spindles, ball joints and outer tie rod ends) Front/rear sway bar Lower control arm u-bolt size upgrade 7/16 to 9/16 (which I just came across last week) 1975 steering box upgrade for quicker ratio steering (just came across this one as I was typing this up) Any recommendations would be greatly appreciated, thanks! |
68 C10 Longbed
![]() Join Date: Sep 2006
Re: What should you upgrade?
I just added front and rear sway bars to my 68. I found an original front sway bar and used the CCP poly bushings and for the rear I picked up the CCP rear sway bar and poly bushings kit. Not a difficult install and the truck handles MUCH better in the turns. There are other companies selling but this was my experience. Good luck.
Nothing really needed. These trucks have become what they are from being what they've been. GM got it right over 50 years ago. These are everything a truck ever needed to be
+1 on front sway bar if it does not have one. I got the 1 1/4" from CPP
![]() Join Date: Nov 2013
Front disc conversion and anti-sway bar are two of the best upgrades.
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
Senior Moment
![]() Join Date: Mar 2002
I’ll 2nd That
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
![]() Join Date: May 2022
"What should you upgrade?"
Seatbelts. Install a 3 point set up with shoulder belts. |
HEI ignition/distributor.
although...Points can/do work fine and when the China/USGovt hits the populace with EMP (electromagnetic pulses) your truck will be one of few vehicles running. |
![]() Join Date: Apr 2016
I like it pretty much stock, but with everything in working condition. Although I did get stock from later model year HEI distributor and 1971 manual disc front brakes. I wish the previous owner of my truck had left the AM radio alone. I put a bluetooth amp and speakers hidden under the seat and am working to put the dash and an original AM radio back in it. Gas tank right there in the cab with you and hearing the gas slosh around is another good thing to leave alone.
And I’ll give the Swaybar and brake upgrade a 3rd vote.
I added a Factory sway bar to mine many years ago, and there’s a night/day different sin handling. I have the brake conversion kit ready, but just haven’t had the time to install it. While a fully optioned truck from this era is as perfect as they come, you’re really just adding factory options anyway. I never thought about the Quick ratio Steering Box, so I’ll have to look into that for mine (700 C-10 LWB). Last edited by custom10nut; 06-13-2023 at 07:39 AM. |
![]() Join Date: Feb 2016
Since you've rebuilding the front suspension I would recommend doing the caster mod especially if you're planning on driving a lot of highway miles. It's an easy unobtrusive modification that can be reversed.
http://67-72chevytrucks.com/vboard/s...d.php?t=501241 Some kind overdrive is a nice addition too.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
