Old 05-24-2023, 10:47 AM   #276
KyleSeal
KyleSeal's Avatar
Re: My 1967 Build (Finally)
The radiator upper clamps/brackets have always sat a bit tight, pinching the harness pretty hard, so I drilled the spot weld out of the clamshells and moved them forward about 3/4 inch and they fit... better.. ish... it will work for now. Fender to wheel clearance is pretty good, was thinking of cutting it for the future where I'll do bags, but the fender isnt that easy to remove so Ill just leave it as is. No need to make more work for myself right now. And the internal frame spray spots I sprayed Im pretty proud of, looks pretty OE!
Size:  80.5 KB Name:  IMG_7444.jpg
Size:  51.9 KB Name:  IMG_7445.jpg
"Sometimes I do serve as a good bad example. Glad to be of service."
My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809
KyleSeal is offline   Reply With Quote
Old 05-24-2023, 11:14 AM   #277
hewittca
hewittca's Avatar
Lookin good! Are those radiator brackets the 2/3 core or the 4 core ones? I am working on getting my new radiator installed and didn't even realize there were different brackets until I saw mine didn't fit the new radiator. I had to order the 4 core radiator brackets which are about 1" longer.
Builds: Green Gus the 68 C10 ; Sullii the 72 1500
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 05-24-2023, 12:19 PM   #278
KyleSeal
KyleSeal's Avatar
These are for the 4 core ones - I also have an aftermarket core support and radiator, which may play into this issue. The radiator seems just a bit too tall to fully fit proper, so I may need to adjust even more
Old 05-26-2023, 04:42 PM   #279
KyleSeal
KyleSeal's Avatar
Heater delete box installed. AC hoses and heater hoses run through it, and harness run through the side. Came out pretty good! The AC hoses and heater hoses look so messy under there, hopefully the inner fenders will help make that stuff a bit more organized. We will see!
Size:  61.5 KB Name:  IMG_7511.jpg
Old 05-31-2023, 09:21 AM   #280
KyleSeal
KyleSeal's Avatar
Crappy weather lately, soon as it clears Ill be grinding the door welds down, I normally take those panels outside so I dont have to deal with cleanup in the garage. In the mean time Im trying to see which caps I like better
Size:  109.6 KB Name:  IMG_7529.jpg
Old 05-31-2023, 11:23 AM   #281
hewittca
hewittca's Avatar
I would go with the dog dish, but if you have both sets you can just swap them out! I have three sets of caps for mine and I go back and forth on which ones I like most.
Old 05-31-2023, 09:45 PM   #282
chewychevy67
I always love the 67 68 p01's. But P03's look good too .
chewychevy67 is online now   Reply With Quote
Old 06-01-2023, 09:23 AM   #283
KyleSeal
KyleSeal's Avatar
Ive even thought of doing one set on one side and the other on the opposing side, probably for shows only, couldnt bare to drive it and lose them while on the highway since theyre both so hard to find.
And you dont see them often either! Ive only seen a few trucks over the years with them on, and have never seen any in person at all
Old 06-01-2023, 09:25 AM   #284
KyleSeal
KyleSeal's Avatar
Flip down bracket for my Holley EFI screen! Mounts with two small screws and has adjustable hinge tension.
Size:  86.1 KB Name:  IMG_7591.jpg
Old 06-02-2023, 07:06 AM   #285
SIXTY9
Man, that is a great idea, may I ask where you got the bracket? Also, killer job on the truck.
SIXTY9 is offline   Reply With Quote
Old 06-05-2023, 08:22 AM   #286
KyleSeal
KyleSeal's Avatar
I found it on Facebook about a year ago, the guy was 3D printing them and posted one in a group Im in, I dont recall how much he charged but it wasn't bad. Im not sure he makes them anymore, Ill double check with him and if he does Ill put his info up here
Old 06-05-2023, 08:25 AM   #287
KyleSeal
KyleSeal's Avatar
Door skin on the passenger side is complete. Lots of grinding and sanding work but its all done. Came out way better than expected honestly.
Size:  42.8 KB Name:  IMG_7877.jpg
Size:  27.4 KB Name:  IMG_7879.jpg
Old 06-05-2023, 10:58 AM   #288
KyleSeal
KyleSeal's Avatar
Went to a ratrod show in Clayton NC over the weekend as well, and found one of the trucks that peaked my interest in 67-72s that lay on the ground. Havent seen this truck in years, had followed it on social media but to this day still cant find it online, awesome truck.
Size:  111.0 KB Name:  IMG_7859.jpg
Old 06-06-2023, 09:12 AM   #289
KyleSeal
KyleSeal's Avatar
Got kind of concerned about driving with inner fenders this low, so I removed the sprig on the passenger side and moved the wheel all the way up and wow... does not rub. I can put it all the way against the end of the shocks vertical travel and spring the wheel. Surprising for sure!
Size:  67.0 KB Name:  IMG_7893.jpg
Old 06-06-2023, 12:08 PM   #290
hewittca
hewittca's Avatar
That's cool you got to see that GMC. I saw it at the C10 Fall Revival in '21 and it's surprising to stand next to because it's sooo low. I guess you can have that effect when you literally cut the rockers off your truck!
That's nice that you clear the stock inners, although it's dangerous doing a test like that. Now you know you need more low! I still haven't figured out what to do with mine. Until then I am just going to run without inners.
Old 06-08-2023, 08:56 AM   #291
KyleSeal
KyleSeal's Avatar
When I see trucks like that, where theyre just having fun, it really makes me rethink my stressors, like dang man stop stressing over that small gap in the body line and just get it driving!
Im still not super sold I wont have a good bit of interference, so I may end up modifying my stock ones like they did on the Nacho truck. I havent seen guys modify the stock ones much, they either go without or do the Stoner/Hills or Slosh Tubz. Nice products, but I can think of a lot of stuff I can get for a grand to get me on the road! Namely Porterbuilt control arms, or even saving that for a Dropmember (a man can dream )
Old 06-12-2023, 08:24 AM   #292
KyleSeal
KyleSeal's Avatar
Some fake patina stuff here, did the drip rails and the bow above the windshield, I need to do some sanding and maybe some extra hits from a spray can but they came out okay. And one pic of some real deal hardcore patina as well
Size:  48.0 KB Name:  IMG_7962.jpg
Size:  70.4 KB Name:  IMG_7961.jpg
Old 06-20-2023, 10:05 AM   #293
KyleSeal
KyleSeal's Avatar
Stepping away from the build stuff..
On Friday, June 16th at 4:53AM my dad, Michael Seal II, took his last breath. It has been a long, long road and fight with cancer, which I will explain in this post.
He was diagnosed with glioblastoma in June of 2020 after we had talked to him about his speech beginning to slur and at times be unrecognizable. They found the large tumor almost immediately upon x-ray. The doctor explained this disease to us and him, and basically said to eat all the bacon, ham and eggs you can "cause you've got maybe a month." We were shocked, distraught, confused, and most of all, lost. Those feelings materialized into a post on Facebook, which led to someone seeing it and reaching out with contact info for a doctor in Wisconsin. I may also add, the doctor here in Virginia told us there was zero fix for this. Well, this doctor in Wisconsin is supposedly one of few doctors in the world who operates on this disease. He motioned us to get there as soon as humanly possible, his team working out the details over the weekend when they were off the clock, it was amazing the leg work into this. We took the soonest flight out and rented the hotel. Its still June at this point. We had to drive back, as brain surgery does not take well to altitude. The doctor in Wisconsin states he was confident that he removed 98-99% of the tumor, as this is a exceedingly difficult cancer to remove. He states that we need to immediately start chemo and radiation. To cut this story short, we went from a few weeks to live to an undefined amount of time. This disease has very little data, and the longevity post surgery has nearly zero data, and his disease always comes back, it will never go away, but it wont show until the very end. We ended up having three years and three days since his initial diagnosis. It had been very tough, he lost his ability to cognitively speak, write or even perform most tasks, eventually lost his ability to cognitively understand. The last time I got any response out of him was a week before he passed, the 24 Hour De Lemans was on and I pulled his bed in view of the TV, and explained to him that Hendrick was in the race for the first time in decades, representing NASCAR, and said "aint that cool?" He nodded.
Here in Williamsburg, VA there is a place called Hospice House. It is filled with the most kind staff, they are helpful, energetic, and emotionally responsive. And this one is unique, it is free of cost, and an absolutely beautiful establishment. I will never forget their hospitality and grace. This allowed him to have 100%, around the clock attention, and to allow us to have a place to go, that did not feel like a hospital, and be with him for his final days.
Size:  62.8 KB Name:  IMG_7997.jpg
Old 06-20-2023, 10:37 AM   #294
KyleSeal
KyleSeal's Avatar
In the midst of it all, I found myself back in the garage, looking for things to do (no shortage with a project) and decided I was tired of getting no call backs on a windshield install. I decided to install it myself, trim and all. First time ever doing it, especially nervous with the trim aspect. But its in, and a throwback to the old C10 Club stickers, I bought that little decal in like 2014/15 when I got into these trucks. Finally found its home.
Size:  56.2 KB Name:  IMG_8026.jpg
Old 06-20-2023, 10:39 AM   #295
KyleSeal
KyleSeal's Avatar
Also found the color for the roof, the photo makes it look more plain white than it is, its more of a antique white (we used Wimbledon White as a reference) and found Nissan had something close apparently. I also finished the passenger door inside. Now onto fauxtina-ing it.
Size:  68.4 KB Name:  IMG_7986.jpg
Old 06-21-2023, 01:33 AM   #296
cornerstone
cornerstone's Avatar
Man I'm sorry for what you and your father had to go through. It's almost the identical path my mom had to walk, and we got to be with her for 3 years after her initial brain tumor surgery also. God bless you for being by his side through that. Is that your dad in the picture giving the thumbs up? Y'all hang in there, eventually the pain subsides and the great memories rise to the surface.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 06-21-2023, 06:53 AM   #297
hewittca
hewittca's Avatar
Totally gutted to hear about your dad. It's easy to forget sometimes on the forum that everyone has so much more going on behind the scenes than just updates on their build progress. It's good that you were able to get more time with him and that he received such great care. There's still good out there in the world, you just have to find it.
Old 06-22-2023, 04:47 PM   #298
KyleSeal
KyleSeal's Avatar
Im sorry to hear that you had to experience the same ordeal, its not fun at all. Luckily we were given time, and I think that has helped quite a bit. Yes, that photo is him. That was after we found a super cherry old bench from a '72 Suburban to put in my old '70. 50 bucks on eBay in 2016 and it was only 1 hour from me!
Old 06-22-2023, 04:57 PM   #299
KyleSeal
KyleSeal's Avatar
That is very true, we all see each other as trucks and truck builds "I cant point him out in a lineup but I know which truck is his!" Its easy to forget we are all people. The forum has been a great escape for me as well, a place where I can talk trucks, post pictures of my work and see some great builds and forget all that surrounds me! Ill never forget all the memories, he got me into these trucks which tapped into a talent I never knew I had, which changed the course of my life in a way. So many great people Ive met, memories, and all those stemmed from him getting me into the C10s. He always told me he wished he had honed in on the hot rod/performance/truck world, custom stuff and such. Im working on getting there!
Old 06-22-2023, 05:12 PM   #300
Kronald_70GMC
Kronald_70GMC's Avatar
Sorry for your loss. Prayers going out to you and your family. Very cool memories for sure.
Kyle
1970 GMC "Project Splice"
2017 Silverado LTZ (Daily Driver)
IG: kyle_ronald
Kronald_70GMC is offline   Reply With Quote
1967, custom, dropped, lowered
