08-28-2020, 05:43 AM | #1 |
blueprint of the great Suburban around 1979
Good morning!
I am looking for a good blueprint of my Chevrolet Suburban from 1979. I have found one but when I compare it with my own photos something doesn't fit ... I know the problems with photos due to the perspective view, but also the blueprints are not exact ... Would be great if you could help! Thanks in advance, Stephan
2 kids, 2 cars Sub2k - 5.3 ltr vortec Sub79 - 7.4 ltr big block Das Schiff ist im Hafen sicher, aber dafuer nicht gebaut. |
08-29-2020, 08:04 AM | #2 |
Re: blueprint of the great Suburban around 1979
The first thing I'm seeing, is that the drawings you're working from are for a 80's front clip. That will obviously skew the front end quite a bit.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
11-05-2020, 07:45 PM | #3 |
Anyone here that own a 1979-1980 suburban factory 454 and can help me out and take a picture of the emission sticker diagram? I need to pass smog . Thanks
11-06-2020, 09:47 AM | #4 |
There are some dimensions on the vehicle info packet located at this link;
https://www.gmheritagecenter.com/doc...t-Suburban.pdf
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
09-03-2023, 02:47 AM | #5 |
Thank you …
09-03-2023, 09:09 AM | #6 |
Here's a few links with info.
link: https://www.auto-data.net/en/chevrol...v8-160hp-14645 link: https://carsplusplus.com/specs1979/c...t_suburban.php link: https://sizedly.com/chevrolet-suburban#1973-suburban-ck
