Old 01-01-2024, 09:27 PM   #1
raggedjim
raggedjim's Avatar
Previous owner '68
Yes, I am the future previous owner of a 1968 short step that has been basking in the elements of my back forty (actually my back 4 but who's counting?). Since I have retired I have been asked too many times what I do all day so I decided to drag it to the shop and tear it down into thousands of pieces so I could have a decent reply.
I will be using parts I have laying around and also spending way too much on new parts for this build. It won't be a show truck or have any fancy sounding parts and modifications done to it. Mostly I will be trying to make it a decent driver, that's lowered, and runs reliably.
The starting point... ouch...
November 8th
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 01-01-2024, 10:02 PM   #2
68bowtie
68bowtie's Avatar
Re: Previous owner '68
I like it. What color was it originally?
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Old 01-01-2024, 10:06 PM   #3
raggedjim
raggedjim's Avatar
It was 505 dark green. This truck had a government property tag inside of the glove box where a spid usually is and no spid. Not sure if a previous previous owner did that or what.
Roger
'70 GMC Jimmy 2wd
Old 01-01-2024, 10:16 PM   #4
Getter-Done
Getter-Done's Avatar
That is a Great start there Neighbor.
84 Chevy K-20
Old 01-01-2024, 10:22 PM   #5
raggedjim
raggedjim's Avatar
Thanks Getter-D, tons of potential for sure.
I vacuumed MOST of the leaves and mouse deposits out of it and moved it inside, cause I'm old and don't like the cold.
Roger
'70 GMC Jimmy 2wd
Old 01-02-2024, 07:22 PM   #6
raggedjim
raggedjim's Avatar
Bed wood is non-existent. Started out by tearing out the old wood and rusted strips, also took off tailgate and rear lights.
Roger
'70 GMC Jimmy 2wd
Old 01-02-2024, 07:41 PM   #7
raggedjim
raggedjim's Avatar
Since I like 5-lug trucks better because of the front disc brakes and better selection of wheels, I removed the old rearend, using a big (as in LARGE) ratchet to remove the old u-bolts. I removed everything from the 6-lug rearend I thought I might need and took every thing left to my buddy who has a bunch of 63-66 chevy trucks.
Roger
'70 GMC Jimmy 2wd
Old 01-04-2024, 08:49 PM   #8
raggedjim
raggedjim's Avatar
I had a 5-lug rearend from a 72 in my (no)horse shed so I brought it to the shop and opened it up. There's no smell quite like 50 year old readend grease, especially when it's in a worn out posi rearend. After much cleaning I put new clutches in the posi and replaced the worn out pinion gear thrust washers. I put in all new brake parts, and replaced the axle bearings and seals. My wife made me throw away some perfectly fine work clothes after making me strip on the back deck. Hope the neighbors enjoyed it more than I did.
Roger
'70 GMC Jimmy 2wd
Old 01-05-2024, 10:25 AM   #9
wpsharpshooter
I didnt even realize this was your thread.. Whats the plan for the color? Since your just down the road... You cant do red LOL
wpsharpshooter is online now   Reply With Quote
Old 01-05-2024, 10:54 AM   #10
68Gold/white
Post 3
68Gold/white is offline   Reply With Quote
Old 01-05-2024, 10:56 AM   #11
68Gold/white
I'm in agreement with everything you are doing!!!
Carry on!!!
Old 01-05-2024, 10:58 AM   #12
wpsharpshooter
Originally Posted by 68Gold/white View Post
Post 3
**** man... Its been a loooong week... I actually remember reading that LOL
Old 01-05-2024, 11:16 AM   #13
raggedjim
raggedjim's Avatar
I'm thinking I'll stick with the green, but occasionally I think of all the metalwork it needs and I get to wishing I had a simpler hobby, like synchronized swimming or maybe hooting a jug in a jug band.
Roger
'70 GMC Jimmy 2wd
Old 01-05-2024, 09:25 PM   #14
raggedjim
raggedjim's Avatar
While I had the rear axles out I noticed a couple of the lug nut studs were not up to my standards (which aren't really that high to start with) so I ran to a local parts store and got some. Well, they didn't fit. They were 1/2"-20 but the serrated part was too small (about .535) The part number was abn-138. The stud I found that fit was an abn-191 (.621 knurl size)
Exciting, I know.
Roger
'70 GMC Jimmy 2wd
Old 01-05-2024, 09:32 PM   #15
Getter-Done
Originally Posted by raggedjim View Post
While I had the rear axles out I noticed a couple of the lug nut studs were not up to my standards (which aren't really that high to start with) so I ran to a local parts store and got some. Well, they didn't fit. They were 1/2"-13 but the serrated part was too small (about .535) The part number was abn-138. The stud I found that fit was an abn-191 (.621 knurl size)
Exciting, I know.
Sometimes you can find the part number you need on this site>
Link: https://www.dormanproducts.com/c-778-wheel-studs.aspx
84 Chevy K-20
Old 01-05-2024, 09:36 PM   #16
raggedjim
raggedjim's Avatar
Now I have to make a disclaimer at this point, actually more of a warning. I do sketchy crap. There, I've said it. I would not advise anyone to try to duplicate my methods, these posts are not meant to educate or encourage. Trucks can and will try to kill you if you are stupid.
The following pictures may offend and horrify. Children and OSHA guys should go and look at cat videos on Youtube. You have been warned.
Roger
'70 GMC Jimmy 2wd
Old 01-05-2024, 09:41 PM   #17
raggedjim
raggedjim's Avatar
Now that the warnings are out of the way, I decided to remove the bed, by myself, with very little in the way of lifting devices. I survived, it was sketchy. I may just leave it off.
Roger
'70 GMC Jimmy 2wd
Old 01-05-2024, 09:44 PM   #18
raggedjim
raggedjim's Avatar
Good to know! Thanks!
Roger
'70 GMC Jimmy 2wd
Old 01-05-2024, 09:49 PM   #19
raggedjim
raggedjim's Avatar
I made a makeshift cart out of an old hose reel, some piano wood and some old casters. I'm crafty like that.
Roger
'70 GMC Jimmy 2wd
Old 01-05-2024, 09:54 PM   #20
Getter-Done
I don't see anything wrong with that.
Job got done and No one got hurt.
84 Chevy K-20
Old 01-05-2024, 09:56 PM   #21
raggedjim
raggedjim's Avatar
You are correct, and I also remembered a bunch of words from my Navy days.
I have to add, the orange hand crank bumper jack was the one my grandfather used when he owned a garage. I rebuilt it and repainted it the way he had it. I think about him when I'm huffing and puffing trucks up and down.
Roger
'70 GMC Jimmy 2wd
Old 01-06-2024, 07:56 PM   #22
clay68c10
clay68c10's Avatar
That’s a handy old jack.
Did you see my hoist and wheelbarrow frame moving method? If it works…..
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-06-2024, 09:44 PM   #23
raggedjim
raggedjim's Avatar
Hmmm, I'll have to check it out, always looking for better ways.
Roger
'70 GMC Jimmy 2wd
Old 01-06-2024, 09:50 PM   #24
raggedjim
raggedjim's Avatar
I knocked the rust off the frame and used everybodies favorite moisture cure paint to seal in the rust (at least that's what the sales literature says).
Roger
'70 GMC Jimmy 2wd
Old 01-06-2024, 10:11 PM   #25
raggedjim
raggedjim's Avatar
Then I decided to remove the doors. Actually the jack did most of the work.
Roger
'70 GMC Jimmy 2wd
