![]() Join Date: Nov 2018
Hatch hinge mount repair help
What is the best way to repair the inner side of hatch where the hinge bolts in? Is the metal piece inside just pop-riveted to the fiberglass, or is there some other reinforcement inside? The piece that's pop-riveted is loose and the fiberglass is cracked.
![]() Join Date: Aug 2007
Re: Hatch hinge mount repair help
Well if I were going to repair this and not sure it's the best way. run some wire through the 3 bolt holes, drill out rivets slide support out of the way. Soak 2" fiberglass strips in resin and using your fingers (with gloves) put them on the inside do 2 layers of fiberglass and finish outside with fiberglass filler. drill the repaired rivet holes when cured, pull the bracket into place pop rivet to secure it in place. When I did repairs on my hatch I found the metal supports were pop riveted in place.
7D2N
Just for the fun of it |
