01-30-2024, 06:35 PM | #1 |
Hood vents
Has anyone ever decided to run oem gm hood vents on our trucks? I got a second hood and I'm toying with grafting either 66 Chevelle vents or first gen Camaro vents for a OEM performance feel. Maybe even a Nova vent.
01-31-2024, 08:35 AM | #2 |
Re: Hood vents
I've seen it done before. I guess they don't actually vent, but you want the look. I think the lay flat ones (1st & 3rd) would be your best bet. The others would be a lot of skilled work
01-31-2024, 09:09 AM | #3 |
Re: Hood vents
Tha SS chevelle vents look awesome. Local bodyman here has done that by sectioning the two hoods. Quite a bit of work he says.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
01-31-2024, 10:33 AM | #4 |
Re: Hood vents
I've seen the 70-72 Buick GS hood vents on a truck when I went to the GS Nationals in Bowling Green, Kentucky.
01-31-2024, 10:55 AM | #5 |
Re: Hood vents
The Chevelle hood inserts would be a challenge. If you look at hood there is a ridge that runs through the middle of insert so it’s basically on two planes . And they are purely decorative no function at all
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
01-31-2024, 12:05 PM | #6 |
Re: Hood vents
Super cool idea! My choise would be first gen camaro hood vents, with black inserts it would fit nice on red hood.
01-31-2024, 12:07 PM | #7 |
Re: Hood vents
Agreed. Zero function as installed from the factory assembly line.
01-31-2024, 12:23 PM | #8 |
Re: Hood vents
Note. Which ever will be functional as vents. I love the Chevelle style but agreed its going to take a lot of work
01-31-2024, 12:28 PM | #9 |
Re: Hood vents
Otherwise, I thought about grafting a 70-72 Chevelle hood flapper with an electric motor.
01-31-2024, 02:30 PM | #10 |
Re: Hood vents
I'm not sure what these are from (asuming a gm car) but I did toy with the idea for adding these to my hood. Also I thought about keeping the raised area high to the center line , moving the vents slightly closer to the middle boddy line, and flowing it out into it leaving the front of the hood stock.
01-31-2024, 03:06 PM | #11 | |
Re: Hood vents
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
01-31-2024, 04:24 PM | #12 | |
Re: Hood vents
01-31-2024, 08:55 PM | #13 |
Re: Hood vents
The 67 chevelle is the bomb should of had them on the supers with the 396 engine option now the flippers would be going crazy
01-31-2024, 09:11 PM | #14 |
Re: Hood vents
Have you considered the 68 SS Chevelle version. I always felt that they looked more thought out like 65-70 GTO's and less "Let's bolt something on as cheap as possible. Which is what I think when I see the Icecube tray ones.
I'm an admitted Pontiac guy so I may be biased.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-31-2024, 10:51 PM | #15 |
Who Changed This?
Re: Hood vents
If you're (OP) looking for bling, that's one thing. But if you're looking for performance, that's another. In '68, Buick made a cold air induction system that took air at the cowl and ducted it to the air cleaner. Good for a little horsepower. One could cut a hole in the radiator core support (or put an intake under the bumper) and run a duct, too. I had an '05 Corolla that I made a cold air induction system using ABS drain pipe from the hardware store. Didn't make it a barnstormer, of course, but I got 1% better mileage for about $8 worth of parts and a couple hours work. Paid for itself over the 10 years I owned it. I put the intake "scoop", made from a "tri" pipe adapter in the hole left by one of the unused driving lights. One thing that I really appreciated was better performance when it was 118° in the shade. The computer adjusts the mixture for ambient temperature, and when it's that hot, the car was really a dog. Stock, the air is taken in between the radiator and the battery. That cold air intake helped quite a bit with that.
01-31-2024, 11:10 PM | #16 |
Re: Hood vents
You gotta think outside the box.....set yourself apart.
You can always make a sheet metal pan for the hood underside to direct water where you want. |
02-01-2024, 01:31 AM | #17 | |
Re: Hood vents
Wait... how does the drain pan impact the effectiveness of the 'vents' ?
02-01-2024, 01:41 AM | #18 | |
Re: Hood vents
Look at a modern 5th or 6th gen Camaro and how their SS and ZL1 hoods function. I have a 2017 Camaro SS and the hood gills have a drip tray that funnel towards the radiator, so it then acts as a scoop under the hood that doesnt impact the air coming in while driving. There is then another drip pan on top of the radiator that catches what the hood drops and moves to each side of the motor.
02-01-2024, 10:07 AM | #19 |
Old member
Re: Hood vents
I know this isn't what you want for the hood louvers but the under panel can keep the water off the motor and it works very well. I drive this truck in the rain a bunch not as much as I use to but it does get drove in the rain and I've never had a problem with water.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-01-2024, 10:22 AM | #20 |
Re: Hood vents
When I drive the Chevelle in the rain the engine gets wet anyways so it’s really not an issue if the hood vents leak a little too . If you’re trying to get the air out of the engine compartment an air dam under the bumper works well . It causes a lower pressure condition under the car/truck . I put a little SS piece I made under my Avanti and it cooled the motor firewall a great deal.
02-01-2024, 10:43 AM | #21 |
At the body shop.
Re: Hood vents
Anything but a cowl hood would look great.
" That didnt make it any newer " " Dont antique the equipment " |
02-01-2024, 11:29 AM | #22 |
Re: Hood vents
Nothing wrong w/a cowl hood (a functional cowl hood). Slap a couple of heat extracting vents along the outer edges of the hood vs the stuff shown within this thread + a functional cowl induction set-up & I get it.
The GM stuff shown within this thread is nostalgic cool but that's about it.
02-01-2024, 11:38 AM | #23 | |
Re: Hood vents
So its going to be for function plus aesthetics it will not be how I take in air but how I plan to relive negative under hood pressure and heat. this truck is in every essence a muscle truck so with modern performance played down with retro aesthetics |
02-01-2024, 11:42 AM | #24 |
Re: Hood vents
02-01-2024, 11:45 AM | #25 |
Re: Hood vents
