03-06-2024, 08:01 PM | #1 |
More dumb questions 72 blazer
My front axle is labeled 44-5f from what I gather that is a Dana 44. I wanted to replace my brake rotates they are rusty not grooved or necessary bad. Since it’s one piece with the outer hub I can’t seem to find the correct rotors. Also now that I’m in this far I’d like to change my axle u joints. And the dust seal that goes against that knuckle is shot.
My question is what is the best way to go about ordering the correct parts? Thank you for everyone’s patience and assistance through this process |
03-06-2024, 10:36 PM | #2 |
Carpe manana
Re: More dumb questions 72 blazer
Reach out to these guys I bet they can provide some help: https://torqueking.com/category/1969...le-front-axle/
03-07-2024, 01:35 AM | #3 |
I’m pretty sure the rotors separate from the hub. The lug studs hold everything together from what I remember. They are pressed together. When searching use 72 K10. If you search Dana 44 most parts that come up will be Jeep.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
03-07-2024, 01:45 AM | #4 |
Found these when I rebuilt my Dana 44 5 years ago.
03-07-2024, 01:55 AM | #5 |
One more. Rock auto is a great source. I bought all the seals here.
https://www.rockauto.com/?carcode=1029259&parttype=1896
03-07-2024, 08:18 AM | #6 |
knock the studs out and the rotor will separate from the hub
Look here for info and parts I've bought a lot of parts from Randy's https://www.randysworldwide.com
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
03-07-2024, 10:44 AM | #7 |
Awesome thank you fellas.
I decided yesterday to go ahead and rewire the whole truck as well. After going through and trying to clean up multiple cobbled messes. If anyone has helpful tips to make that process easier as well that would be great. I went with the painless kit |
03-08-2024, 10:41 AM | #8 |
Like Kirk said, Rockauto.
Half the parts I used to restore my truck came from Rockauto, and I'm in Canada. Great place to deal with and good prices. |
03-09-2024, 09:14 AM | #9 |
You can still purchase the K series rotor and hub assembly brand new, albeit not cheap.
https://www.thewrenchmonkey.com/prod...bestos/56300r/
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress... 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels Last edited by 1970cstblazer; 03-09-2024 at 01:26 PM. |
