03-05-2024, 08:03 PM | #1 |
NP205 Speedo delete
I have a 72 Blazer that I recently had a LS swap performed on. I have a leak on the NP205 that I believe is coming from the speedo. I have attached photos. My question is what can I do to solve this. Can I cap it? If so, what size and thread is it? (I have searched and cant seem to find it). Should I remove it altogether and plug it?
Thanks in advance |
03-05-2024, 08:52 PM | #2 |
Carpe manana
Re: NP205 Speedo delete
Replace the seal in the adapter. See here: https://www.motorcityk5.com/i-13102-...=category:9415
This is designed to work w a speedo cable of course so may not be the cure. Other guys might have an idea about a possible cap.
03-06-2024, 03:33 AM | #3 |
Replacing the seal in the cable connection may do nothing if the cable is not attached. ORD sells caps. I purchased one as I no longer need the cable speedometer wih my LS swap. Cannot remember which one I purchased for my 72?
https://www.offroaddesign.com/np205-...20-thread.html https://www.offroaddesign.com/np205-...20-thread.html Maybe I can check my past purchases? Sorry. past purchases are gone on my account, maybe call ORD and see which one they recommend?
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 03-06-2024 at 04:25 AM. |
03-06-2024, 09:25 AM | #4 |
Many of these transfers cases do not have any speedometer seals installed from the factory.
It was ok if they leaked back when, I guess. I have successfully added seals th the speedometer output. I would plug it off if you have an electronic speedometer. In regular speedometers the cable has nothing to do with it leaking or not. A cap with a seal may help. A screw on thread protector will do nothing. Last edited by Accelo; 03-08-2024 at 04:20 PM. |
03-06-2024, 04:58 PM | #5 |
Carpe manana
Maybe this plug is what you need: https://www.offroaddesign.com/np205-...20-thread.html
03-06-2024, 05:52 PM | #6 |
My 72 had 1"-20 thread. I plugged it with the ORD plug when I installed my vss for my 4l80e
03-08-2024, 10:43 AM | #7 | |
03-08-2024, 11:14 AM | #8 |
Carpe manana
Think you could?
03-08-2024, 01:39 PM | #9 |
03-08-2024, 02:09 PM | #10 |
Carpe manana
Start the build thread
03-08-2024, 04:27 PM | #11 |
03-08-2024, 04:48 PM | #12 |
Carpe manana
I admire the skill that it would take to crank items like this out and was just curious how it would be done. I'll have to pay a visit to the shop if the border guards will allow me to cross
03-08-2024, 06:55 PM | #13 | |
Real good profit at $40. |
03-08-2024, 08:17 PM | #14 |
Anythings possible when you have the tool
Let me see what a hexagon aluminum bar stock costs 20140917_111932 by
03-10-2024, 12:27 PM | #15 |
They are not 1" X 20tpi.
03-10-2024, 01:25 PM | #16 |
03-10-2024, 02:06 PM | #17 |
You must have been talking bout the hole the speedo gear threads into.
I was just thinking a cap for the speedometer threads on the plug. So you are correct. |
03-11-2024, 09:27 AM | #18 |
I made two of the plugs.
$20 each includes shipping. I am only making two. |
03-11-2024, 09:42 AM | #19 |
Carpe manana
Nice work.
03-13-2024, 09:34 AM | #20 |
03-13-2024, 10:15 AM | #21 |
Carpe manana
Just think, if you made and sold one or two you could actually pay to support this site as a member.
03-14-2024, 09:13 AM | #22 | |
As I've said before, charge businesses to post ads on here, not individuals trying to build their trucks and sharing the odd part amongst each other. If Billy wants to sell Bob a bolt for his truck, he should righfully be able to do so without having to pay an extortion fee. I'm sure you agree. |
03-14-2024, 05:33 PM | #23 |
Carpe manana
No. I don't agree with you on this.
03-16-2024, 10:31 PM | #24 |
I should have posted this on the For Sale section.
Thanks for the reminder |
03-17-2024, 03:17 AM | #25 |
MY Facebook ( saad_alhajri ) on Instagram
