04-07-2024, 09:22 PM | #1 |
Active Member
Re: Patina love
And so it begins. Hate rivets lol
04-12-2024, 06:27 PM | #2 |
Active Member
Re: Patina love
1 notch in 1 to go
04-13-2024, 05:16 PM | #3 |
Active Member
Re: Patina love
Finally both sides done. Those damn rivets that go through 3 panels are the worst
04-14-2024, 07:54 AM | #4 |
Junior Member
Re: Patina love
Looks great. I have that same front brake kit, and the rotors hit the factory lower control arm (front crossmember). Give a search on the boards - many have had the same issue.
While you have it apart, make sure to test fit everything and look for interference on the rotor - you’ll likely need to grind down the outer face of the lower control arm. I did start to see some commentary on different / taller ball joints from square bodies that might help in some manner, but I opted to clearance things. Diggin’ the patina - did the same on this end. |
04-14-2024, 11:44 AM | #5 | |
Active Member
Re: Patina love
04-14-2024, 05:35 PM | #6 |
Junior Member
Re: Patina love
I did 5” springs and 3” blocks in the back. By the time everything was put together, I added some pinion shims, and compared to the front right height, I wish I had gone with a 2 inch instead of a 3 inch block. I think you are on the right track.
04-14-2024, 07:19 PM | #7 |
Active Member
Re: Patina love
Good to hear. Im planning on front end to take a week or two, to get done and then i got this tranny to change out. Maybe ill get trans done first lol. Im indecisive
