Old 05-08-2024, 12:04 AM   #1
69 customcamper
1960 GMC 3/4 ton 5 speed manual convert
I am going to replace the V6 in this truck and put a 5 speed transmission manual. The issue is the fact that this thing has the E brake on the trans. What is the best choice for this upgrade? I do not mind keeping the brake in the floor. Just not sure which trans is best to use.
Mike
69 customcamper is offline   Reply With Quote
Old 05-08-2024, 01:18 PM   #2
jayoldschool
Moderator
Re: 1960 GMC 3/4 ton 5 speed manual convert
Not a T5, right? A TKO or something like that?
jayoldschool is offline   Reply With Quote
Old 05-08-2024, 03:48 PM   #3
LVPhotos
LVPhotos's Avatar
Try a Driveline brake or pinion brake setup
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 05-09-2024, 11:32 PM   #4
350TacoZilla
pretty sure NV4500 out of the 10 lug 3500HD's had driveline brake on them in nearly same location, would just have to adapt the lever or put in a different one.
Wanted to add I think the 5spd P series bread trucks used same style.
350TacoZilla is offline   Reply With Quote
