05-15-2024, 11:57 AM | #1 |
Valve cover clearance
I am about ready to put the cab back on to my chassis. Anyone know if I will have a problem with clearance with these tall valve covers and the firewall? 66 with a sbc
05-15-2024, 04:20 PM | #2 |
Re: Valve cover clearance
My 62 has no problem with clearance with tall valve covers on my small block.
05-15-2024, 04:48 PM | #3 |
05-15-2024, 09:14 PM | #4 |
Gonna be tight
05-16-2024, 06:36 AM | #5 |
I could not use tall valve covers on my 1963 Chevrolet C10. The passenger side hit the firewall. One factor could be that I have AFR Aluminum heads which have a 3/4" deck and are taller then a stock cylinder head. I would pull the covers for the cab install.
Rick
RED RUMBLE 1963 C10 Chevy Truck Owned since 1984 |
05-16-2024, 12:37 PM | #6 |
Stock V8 motor mounts? HEI?
05-16-2024, 12:47 PM | #7 |
yep, stock mounts with MSD dist.
05-16-2024, 12:49 PM | #8 | |
05-16-2024, 03:54 PM | #9 |
Not that this makes a difference for your particular installation, but on my LS install, I made sure I could actually pull the heads off without having to pull the motor. I'd do the same in your case - just make sure it is actually "serviceable."
Do you have a build thread on here? I'd love to see it.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
05-21-2024, 12:08 PM | #10 |
Good idea. Once I have the cab in place I will make sure I have enough clearance to pull it apart. I do have a build thread but am embarrassed about it. I started this build years ago and than let it sit. Now I have retired and am determined to get the truck completed.
