Old 03-17-2024, 08:32 PM   #176
KevinK7
KevinK7's Avatar
Re: 65 Fairlane pro-touring build
The attention to detail on this build is crazy. The mismatch of the inner fenderWells, and pie cuts to correct, Wow, very impressed with your skills here
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 03-18-2024, 06:07 PM   #177
Vic1947
Vic1947's Avatar
Thanks very much for the kind words. I'm trying not to go overboard this time, so I'll be more inclined to drive it.
More cutting and metal shaping...
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 03-20-2024, 05:05 PM   #178
Vic1947
Vic1947's Avatar
Outer PS wheelwell is welded and mostly cleaned up. The inner w/w will need to be split and about 2-5/8" added to it to reach the subframe rail.
Victor
Old 03-26-2024, 04:18 PM   #179
Vic1947
Vic1947's Avatar
The right rear quarter panel saga continues...
Because the 66-67 wheelhouse pinchweld flange doesn't match up with the 65 inner panel, I had to add a filler piece. The photo below shows the upper section. I fab'd up two other pieces below that will provide as much support as possible. I also formed a curved flange to add support in the same area as the original. These will get panel adhesive and stainless rivets because I can't get in the area once the wheelhouse is in place.
Victor
Old 03-26-2024, 04:35 PM   #180
Vic1947
Vic1947's Avatar
At this point, it was time to use the metal wheel of death to remove the section of quarter panel I'm replacing. That part went smoothly enough. I hardly ever have problems deconstructing stuff. Putting it all back together is where the stupid starts. After trimming the replacement panel to allow room for final fitment, I clamped it in place. The wheelhouse arch matched up pretty well, but I have a major hiccup with the body lines. The upper body line is about 5/8" too high as you can see in the photo below. I've been pondering the situation and I'll have to pack up the panel and head down to my buddy Keith's place and use the English wheel to flatten out the existing line and then use an 8' brake to relocate the line. I can't believe they were that far off when they put the existing line in. Fortunately, I have the resources to be able to recover from a setback like this, but not everyone is.
Victor
Old 03-27-2024, 09:33 AM   #181
Rickysnickers
Watching this thread and seeing your work, I'm sure you will get the body line right on. You are 100% about others. If I were to do something like what you are doing, I'd be up a creek trying to find a fix.
Old 03-27-2024, 12:06 PM   #182
SCOTI
SCOTI's Avatar
Would it not work to section the difference between where the body line 'is' vs 'should be' & just add material back to the top (vs removing a body line & then re-creating another on the patch piece)?
Not sure which would be more work though (?).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 03-27-2024, 02:31 PM   #183
Vic1947
Vic1947's Avatar
I think I've already painted myself into a corner regarding that option. The panel is pretty much cut to size and after removing the "difference" I'd have to scab a piece back on to replace the missing material. So that would leave me with two seams. The material is so thin (0.026" or 24ga) that even booger welding will probably be a nonstarter. I had planned to use 3M panel adhesive to join the OEM sheetmetal to the patch panel. Another issue I didn't mention previously is that two spots above the wheel arch are bulged out and need to be worked back down. My thinking was that while I had it on the English wheel, I might be able to get those areas back in shape.
As you mentioned, either way is going to require some finesse.
Victor
Old 03-27-2024, 02:51 PM   #184
SCOTI
SCOTI's Avatar
Gotcha. Sounds like a solid plan from your logic.
In my head eliminating a body line w/the English wheel starts stretching the metal possibly in ways not anticipated.
And, sheet metal that thin.... I tack it w/the MIG & then get someone w/a TIG to zip it up. Working through stuff like that now on my Malibu project.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-28-2024, 01:16 AM   #185
mongocanfly
mongocanfly's Avatar
That sucks... but wow....that's some thin metal..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 03-29-2024, 07:12 AM   #186
jaros44sr
jaros44sr's Avatar
Victor I was wondering if I could get some advice from you
You mentioned you were going to use panel bond, I've never used it before and was wondering how much set up time you have before the panel bond goes off
Great work so far, and enjoy your write up
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is online now   Reply With Quote
Old 03-29-2024, 03:39 PM   #187
Vic1947
Vic1947's Avatar
Yeah, if you hold it up to the light, you can almost see thru it.
Thanks! 3M makes a couple of versions, 08115 and 08116. I'm guessing there are other adhesive products on the market but those are the only two I've used. Working time differs slightly, although both are ambient temp sensitive. At 70 degrees you have about 1.5-2 hours to reposition panels. If your shop temp is hotter the time goes down. At 100 degrees, you have about an hour at most. The main difference between the two versions is related to manufacturer specifications. For me, that's not an issue so I usually get the 08115. They also have different part numbers depending on the applicator style. An applicator can be pricey, but most paint supply houses will rent you one or let you use it free with a deposit.
You typically only get one mixing tube, but you can buy extras on eBay or elsewhere. I remove a used mixing tube, throw it away and clean the area where it attaches. I then replace the shipping cap when I've only used a partial amount. If you're careful to keep the epoxy and the catalyst from coming in contact with each other, it will last a long time on the shelf. I've been able to use the same dispenser several times until I use all or most of the material.
One other thing about the stuff is that as long as it hasn't set up, you can use a spot welder to add mechanical joints. I don't typically do this but it's nice to know you can if you want.
Victor
Old 03-29-2024, 07:53 PM   #188
jaros44sr
jaros44sr's Avatar
Victor great info just what I needed, it was the cost of the applicater that threw me off, but I will check with my supplier
Should give me enough time to get it buttoned up
Thanks for your time to explain that
Sorry to hear about that side panel not lining up
This is what I did so far and did you use lacker thinner for cleanup does it come off your hands, does it smell strong
17115430442306797632180518517808 by [url=https://www.flickr.com/photos/97391199@N06
SAFETY FIRST
AS usual, off topic
Jim
Old 03-29-2024, 10:30 PM   #189
Vic1947
Vic1947's Avatar
This is what I did so far and did you use lacquer thinner for cleanup does it come off your hands, does it smell strong
I use lacquer thinner for cleanup and if you get adhesive on your hands, thinner will work to remove it. I confess that I usually use nitrile gloves when dealing with any kind of pookie. That way, I can use my finger to smooth out a bead and/or remove excess material then peel the gloves off and trash them. The adhesive has a bit of odor but it's not so bad that you need a fan running with the doors open.
Victor
Old 03-30-2024, 07:52 AM   #190
jaros44sr
jaros44sr's Avatar
Thanks for all your help I'm going to go for it
SAFETY FIRST
AS usual, off topic
Jim
Old 03-30-2024, 03:49 PM   #191
Vic1947
Vic1947's Avatar
Here's hoping it goes perfectly for you! I know the first time I used it; I was nervous as a cat in a room full of rocking chairs. From what I've seen, if you have the patch exactly where you want it and have all the clamps and tools handy, it goes well. I put a roof skin on a 68 C10 using it and it worked great.
I split the inner PS wheelwell and started the process if widening it. I plan to use stainless rivets and panel adhesive to join the halves together. Probably do the same with the inner and outer wheelhouses - maybe even the wheel arch. That's still a little ways off.
Victor
Old 03-31-2024, 07:36 AM   #192
jaros44sr
jaros44sr's Avatar
I was worried the clecos would get glued to the panel, thats why I used screws
Nice work
Nice Kennedy rolling tool box
Supply house was closed I'll have to wait until Monday
SAFETY FIRST
AS usual, off topic
Jim
Old 03-31-2024, 08:41 AM   #193
Vic1947
Vic1947's Avatar
I was worried the clecos would get glued to the panel, that's why I used screws
Nice work
Definitely don't want to use clecos or you'll ruin them. Screws or rivets are a better choice. Good luck!
The last place I worked gave me the Kennedy box as a retirement gift. it's a quality piece. It will still be working great long after I've croaked.
Victor
Old 03-31-2024, 02:59 PM   #194
Vic1947
Vic1947's Avatar
The widened wheelwell fits pretty well. I heed to scab some material on to fix a couple of places where I went a little crazy with the snips. But other than that, it's going to do just fine. A pro shop would have cut the forward section of the subframe to widen the tub equally front to back. Mine is more pie shaped to follow the subframe but will still give me plenty of tire clearance.
Victor
Old 04-03-2024, 09:04 AM   #195
jaros44sr
jaros44sr's Avatar
Supply house called applicater and panel bond is there, curious he said to apply over bare metal, don't know as I would think it would be an area to rust, might try a painted test piece to see how it bonds
Congratulations on retirement that seems to be a more practical gift then a gold watch that you only wear on special occasions
What field of employment did you work?
Nice work on the wheel tub
SAFETY FIRST
AS usual, off topic
Jim
Old 04-03-2024, 10:03 AM   #196
Vic1947
Vic1947's Avatar
Thanks, Jim. I have no experience painting the lap joint. I always use it on bare metal. I did my PS wheel tub yesterday and applied the adhesive that way then cleaned the edges with lacquer thinner. I think I remember a 3M tech article that said you could apply a DTM paint to the surfaces but not to do that if you planned to also spot weld. I think if you lay down a good coat of epoxy primer over everything after the fact you won't have a problem with corrosion.
I used several clecos to position the parts prior to riveting them together with stainless fasteners. I then soaked the clecos in thinner and blew them out with compressed air and they seem no worse for the wear. I used some old ones that could be sacrificed just in case.
After a stint in the Navy as an aviation electronics technician, I used the GI bill to get an engineering degree and went to work in the oil patch. When that went in the crapper in the mid 80's I migrated into the software business as a sales engineer. Got canned in a reorganization late in life and was unable to find work until a good buddy helped me get an inside sales job at a machine tool company. Finally got my sack just barely full enough to retire and I'm livin' large now.
Victor
Old 04-06-2024, 11:08 AM   #197
jaros44sr
jaros44sr's Avatar
Thanks for tips, we'll see how it goes
Spring break in upstate NY, visiting grand children so I won't be able to work on the truck for a week
With your background I see where you get your ability to work on those restorations with great results
SAFETY FIRST
AS usual, off topic
Jim
Old 04-17-2024, 05:27 PM   #198
Vic1947
Vic1947's Avatar
Just checking in - I've been busy getting the trim ready for powder coating. The shorter pieces I can put in the glass bead cabinet, but the longer ones had to be done by hand. I use an 80 grit DA sander to start with, then block with 280 and finish with a grey Scotchbrite pad. But before I can do any of that, I have to work out all the dings with a variety of tools. Normally I'd send the stuff off to a shop in WI that does the best repair on the planet, but since I'm going the powdercoat route, absolute perfection is not a requirement.
So, I took all the trim as well as the front/rear bumpers and brackets to Sedalia today. The bumper stuff will be sandblasted and set aside for work later on, but since I had a couple of other things to do in town, I multitasked. The number one reason I made the trip was to put a new body line in the quarter patch panel. I think I mentioned earlier that C2C had it in the wrong place, so I dollied it out completely and used my buddy Steve's 8 ft brake to relocate it to the correct position. Turned out great! Now I just need to start fitting the other panels like the trunk drop downs. More to come,,,
Victor
Old 04-19-2024, 04:08 PM   #199
Vic1947
Vic1947's Avatar
Made a material run to Metal by the Foot this morning to pick up some 18ga steel sheet to make new trunk floor drops. I had a pair that came with the car when I bought it, but they were supposedly made for 62-66 models. They had an angle formed into them that didn't match the subframe connectors in mine. So, I beat them flat and used them as a pattern to make new ones. While I was at it, I bead rolled a completely different pattern in them to suit myself.
Victor
Old 05-17-2024, 04:38 PM   #200
Vic1947
Vic1947's Avatar
We were gone almost two weeks on vacation so not much to report on the Fairlane. We went to Maricopa, AZ to the Dwarf Car Museum and then back to KC via Hwy 50 (The Loneliest Road in America). We just happened to be in Kingman, AZ during the Route 66 Fun Run Cruise also, ~800 cars there. Great time, but now I need to get back in the Fairlane groove. Had most of the trim powder coated before we left and managed to get the driver side quarter patch panel fitted up. I really need to finish up the mini tub on the driver side and the rest of the trunk floor, but I've been avoiding that by rebuilding the door hinges and working on taillight assemblies. Doing piddly stuff while I ramp up to the more difficult tasks.
Victor
ford, restomod, t56
