Old 05-22-2024, 10:34 AM   #1
j_cst_10
j_cst_10's Avatar
rear axle shock tabs/brackets 4x4 - where to buy?
I have a 70 K5 blazer that has a mystery axle in the rear. It is a 12 bolt, 6 lug axle with spring perches but no shock mounting brackets.
Someone may have added perches to a 2wd bracket at some point? Not sure. Gear ratio's match front to back so it's getting used.
The front axle had a legible BOM number, it's a 1980 K20 dana 44 with a 6 lug pattern. Maybe the rear is also out of this truck, though I would think the shock brackets would be on this.
Are they any factory style brackets I can buy to weld onto the axle tube?
Tried searching but I just come up with the 2wd brackets that attach to the U bolts.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual
1972 Cheyenne Super Short Bed 557 Med Olive DK olive
1970 K5 Blazer Dark Gold
1966 Coronet 440 35k mile survivor
1991 Suburban 2500 454/4L80E 2wd
1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9"
j_cst_10 is offline   Reply With Quote
Old 05-22-2024, 11:07 AM   #2
jeffahart
jeffahart's Avatar
Re: rear axle shock tabs/brackets 4x4 - where to buy?
Take a look at Barnes 4WD
https://barnes4wd.com/collections/shock-mounts
j
White K20
jeffahart is offline   Reply With Quote
Old 05-22-2024, 02:22 PM   #3
loudchevy
loudchevy's Avatar
I've bought from Barnes and RuffStuff and WFO Concepts, all good Vendors
https://www.ruffstuffspecialties.com/SHOCK.html
https://www.wfoconcepts.com/c-139308...bs-mounts.html
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 05-22-2024, 04:12 PM   #4
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: rear axle shock tabs/brackets 4x4 - where to buy?
if your front axle is out of an 80 K20, it would be a GM 10 bolt with 8 lugs unless someone swapped the 6 lug stuff over to it. i believe the last year for dana 44s was 76 then they switched over to the corporate 10 bolt.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 05-22-2024, 05:12 PM   #5
Sheepdip
Sheepdip's Avatar
Check the mounting bolt sleeve of your shock should be 1-1/2" like these brackets
https://www.amazon.com/RuffStuff-Spe...n2dvfli9lrj86g
https://www.amazon.com/dp/B01MT2XON7...9ocXBfc2hhcmVk
Sheepdip is offline   Reply With Quote
Old 05-22-2024, 11:11 PM   #6
57taskforce
All about them K’s
57taskforce's Avatar
I used the tabs from ruff stuff on my K20 and have been more than pleased with them.
Tyler
Old 05-23-2024, 09:21 AM   #7
j_cst_10
j_cst_10's Avatar
Thanks for the info. I’ll get some ordered up.
Old 05-23-2024, 01:49 PM   #8
j_cst_10
j_cst_10's Avatar
That first link looks like something that would work, I'll have to do some measuring
Old 05-24-2024, 10:20 AM   #9
Sheepdip
Sheepdip's Avatar
FYI the second link are the mounts I used to convert my avatar to an 86 14 bolt cab n chassis rear differential. The center pumpkin on the 14 bolt is larger and wider than the HO72 and also has plug weld boss axle housings, so to line the shock up on the drivers side it needed a slight angle to overcome about a 3/4" offset.
Worked perfectly!
Old 05-24-2024, 06:02 PM   #10
j_cst_10
j_cst_10's Avatar
Worked perfectly!
I actually bought the second link after looking at them again. We will see how it goes.
Old 05-24-2024, 06:04 PM   #11
j_cst_10
j_cst_10's Avatar
I looked up the BOM and it came back as an 1980 dana44 k20. I don’t think all of the 3/4 ton was 8 lug at that point but who knows. That’s what it came back with and it’s 6 lug. It’s definitely a Dana 44 axle.
