Old 08-27-2018, 10:04 PM   #226
vin63
It's Better With Nitro
vin63's Avatar
Re: Intro and Some Photos of my '63 Project
Got some plumbing done over the weekend. I'll get most of the front sheetmetal on next weekend, then back to wiring.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 09-02-2018, 10:13 AM   #227
vin63
vin63's Avatar
Got most of the front sheetmetal hung yesterday.
Old 09-03-2018, 11:12 AM   #228
jhrusk
Nice. Getting it done.
check out SANFORD build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=522019
jhrusk is offline   Reply With Quote
Old 09-04-2018, 06:04 PM   #229
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
Won't your tire hit the filters on a hard turn?
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 09-04-2018, 06:32 PM   #230
vin63
vin63's Avatar
This is full left lock...
Old 09-04-2018, 06:37 PM   #231
66-PMD-GMC
66-PMD-GMC's Avatar
Well, that answers that...
I guess you have plenty of clearance...
My 19.5s on my crew do not have that kind of clearance
Projects..
440CID 2X4 Pontiac
Old 09-15-2018, 09:11 AM   #232
vin63
vin63's Avatar
Finished up the polishing and Cerakoting of the rear American Rebel Sprint rear wheels with street tire combo. The fronts are not far behind.
Old 09-16-2018, 12:09 AM   #233
Captainfab
60-66 Nut
What happened to the aluminum slots?
Old 09-16-2018, 01:20 AM   #234
vin63
vin63's Avatar
They're stored in the shop with the radial drag slicks still mounted.
Old 09-22-2018, 08:23 AM   #235
vin63
vin63's Avatar
Did a little restoration to the headlamp buckets and they came back from powder coating yesterday, so I was able to assemble the grille for a test fit.
Old 09-23-2018, 10:04 PM   #236
jhrusk
Sweet truck.
Old 09-24-2018, 08:04 AM   #237
The Rocknrod
Moderator
The Rocknrod's Avatar
I dont think I've seen a 62 Grille look that good before. Nice work.
Old 09-24-2018, 09:22 AM   #238
vin63
vin63's Avatar
Thanks! It's actually a 1963 grille. It took a lot of hammer and dolly work to get it somewhat straight. These things took a beating back in the day.
Old 09-24-2018, 10:28 AM   #239
The Rocknrod
Moderator
Ya I dont know why I said 62, I drink in the morning.
Looks great though.
Old 10-14-2018, 10:15 AM   #240
vin63
vin63's Avatar
Progress has slowed a bit to help friends prep for the California Hot Rod Reunion, but was able to finish up the front American Rebel Sprint wheels.
Old 10-15-2018, 09:24 PM   #241
chad64chevy
chad64chevy's Avatar
looks good!
where did you mount your air tank an compressor?
chad64chevy is offline   Reply With Quote
Old 10-15-2018, 11:18 PM   #242
vin63
vin63's Avatar
Originally Posted by chad64chevy View Post
looks good!
Thanks! The air tanks are in the bed (one being a re-purposed nitrous tank), and the compressor is under the rear driver side of the bed.
Old 10-16-2018, 07:25 PM   #243
joesscamaro
Uhhh, that is a gorgeous truck! You should be one proud papa!
joesscamaro is offline   Reply With Quote
Old 04-22-2019, 07:39 PM   #244
vin63
vin63's Avatar
Fabricated and mocked up my little hideaway nitrous arm and purge switch panel in the ashtray.
Old 04-23-2019, 04:36 PM   #245
66-PMD-GMC
66-PMD-GMC's Avatar
Too cool
Projects..
440CID 2X4 Pontiac
Old 07-10-2019, 11:35 AM   #246
vin63
vin63's Avatar
The two least favorite parts of a hot rod build - AC hoses and brake lines - has had me procrastinating since returning from vacation a few weeks ago. Starting to map out hose routing and will be making some AC hoses here shortly.
Old 07-11-2019, 09:38 AM   #247
66-PMD-GMC
66-PMD-GMC's Avatar
It's cool that you are running A/C...
No pun intended..
I dont have any creature comforts planned for my trucks like that, but starting to have second thoughts.
So, what compressor setup are you running? Doesn't look factory Pontiac.
Projects..
440CID 2X4 Pontiac
Old 07-11-2019, 10:49 AM   #248
vin63
vin63's Avatar
Thanks! Yep, request from the wife after I decided on the ignition and fabricated the motor plate mount...ugh. The drive system ended up being way more complicated than expected. Because of the crank trigger and the front motor plate spacing in accommodating the serpentine drive, I had to fabricate all sorts of new spacers and adapters, etc. It's a Vintage Air kit.
Old 07-11-2019, 11:01 AM   #249
66-PMD-GMC
66-PMD-GMC's Avatar
I have a friend who opted to go with genuine Pontiac power.
He wants A/C and we're seeking original V-belt A/C parts.
My prostreet/protouring truck will be a minimalist truck having only power steering.
Being from the Phoenix area, heat isn't much of an issue to me... :-)
Projects..
440CID 2X4 Pontiac
Old 07-15-2019, 09:03 AM   #250
vin63
vin63's Avatar
Yep, if I was going to add AC from the get-go, I would've done a regular V-belt drive system rather than the serpentine drive that I had traded for and thought it would make my life easier. LOL
Stainless brake lines are done. Now to take it apart and bench bleed the MC.
