12-01-2009, 10:20 AM | #226 | |
Re: Project NOT4SLE
12-01-2009, 02:12 PM | #227 |
Re: Project NOT4SLE
You might have to break out the hammer and chisel to get the gunk off!
12-01-2009, 02:21 PM | #228 | |
Moderator
Re: Project NOT4SLE
I soaked all my stuff in a large container, using Purple Power concentrate. Bought it at Home Depot in a 5 gallon jug. Mixed with water, soaked for two days. The gunk fell off. The stuff is caustic, don't get it on your hands.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
12-01-2009, 02:56 PM | #229 |
Re: Project NOT4SLE
all these ideas of how to make it easy... Just get a scraper and use some elbow grease. THat is how i did my entire frame then hand sanded it to bare metal after all the grease was gone.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. |
12-02-2009, 12:02 AM | #230 |
Restoration Virgin!
Re: Project NOT4SLE
I agree with ripdog, but then you may rename you project to MIGHTB4Sale after all that
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
12-02-2009, 12:34 AM | #231 |
Re: Project NOT4SLE
12-02-2009, 09:42 AM | #232 |
Under Construction
Re: Project NOT4SLE
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
12-02-2009, 02:41 PM | #233 |
Re: Project NOT4SLE
My head liner was reattached with what looks like Liquid nails. I tried sanding and acid and a number of things and that stuff is very very strong and stubborn. Ill be tackling that this afternoon to try and get it all down off the roof. I also found the fitting for my radiator to have a 3/4" hose fitting for my radiator instead of the 5/8" one on there now. SO Ill be changing that as well. Last edited by vegaschevy; 12-02-2009 at 02:43 PM. |
12-02-2009, 04:16 PM | #234 |
Re: Project NOT4SLE
The new radiator came with a 5/8" fitting?
12-02-2009, 05:04 PM | #235 |
Re: Project NOT4SLE
It came with threads which I believe are a 3/8" MPT thread. All I could find was a 3/8" to a 5/8 fitting and I need to a 3/4". I drove to Mcfadden Dale hardware and picked one up yesterday. Ill take pics of both so you can tell me if it is a 3/8" thread for the radiator. I believe that the radiator was suppose e to come with a fitting but I did not see one and it was not to big of a deal for me. I knew I could pick one up.
12-02-2009, 06:32 PM | #236 |
Re: Project NOT4SLE
Kewl. Alot of times they don't come with a fitting. You normally use the ones from your existing radiator. I usually destroy mine taking them out.
12-02-2009, 09:22 PM | #237 |
Re: Project NOT4SLE
Well I got my sick ass off the couch today to get a few things done.
I started with finally hooking up my Neutral safety switch properly. I just plugged it in and left it. In doing this I learned that I did not have a reverse light out. One was not working and I had just changed bulbs and lenses when I got it on the road. Turns out that the neutral safety switch going out was allowing one to work and not the other. I put the truck in reverse, set the emergency brake and turned the key on. Adjusted it till both lights came on and tightened it down. Worked perfect this way! I also decided to replace the springs and turn signal cancel cam in my steering wheel as the signals work but they do not cancel when making a turn. I started with my 10 buck steering wheel puller, has worked great and pulled 20 or so steering wheels with ease. I had bough this kit at pep boys for 6 bucks and only used the springs out of it as the plastic cam was fine, the springs however were broken in two. |
12-02-2009, 09:25 PM | #238 |
Re: Project NOT4SLE
This is the way the radiator I got came with no fitting, I think it is 3/8" threads.
I found this fitting but could not find a 3/4" one like I needed to make it right so I just tightened the hose down extra tight. Worked for the last 200 miles. I got the correct fitting yesterday and got it installed. And last the nasty crap on the roof from the roof liner that came factory. It must have sagged at one point and someone used this liquid nails crap on it. I used an abrasive paint removing wheel and got it all ground down and cleaned up. now no nasty stuff above my head now im back on my couch with a bottle of nyquil and tussin! |
12-02-2009, 09:32 PM | #239 |
Re: Project NOT4SLE
Ok, I have a question now. The reverse lights are tied in to the neutral safety switch? Mine are not working at all and they weren't working before my ns switch went out either.
Hope ya get to feeling better. |
12-02-2009, 10:35 PM | #240 | |
Re: Project NOT4SLE
yes, they are tied into the switch. If it is not properly aligned they do nto work. Mine only had one not working and the new switch fixed that. |
12-09-2009, 08:19 AM | #241 |
Phone's ringin Dude.
Re: Project NOT4SLE
Hey, I know it's been a while since you posted it, but did you try some good ol 99 cent Dollar General oven cleaner? Worked like a charm on my nasty truck.
I pitty the fool with only two headlights!! 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
12-09-2009, 09:00 AM | #242 | |
Re: Project NOT4SLE
I am going to find a hot pressure washer and wash it up after soaking it with some oven cleaner again. Ive been crazy busy lately. i want to get back to washing and installing my suspension but it may be after christmas before I get back on it. Have to make the girl happy too. LOL |
12-09-2009, 09:00 AM | #243 |
Re: Project NOT4SLE
12-09-2009, 01:09 PM | #244 |
Re: Project NOT4SLE
12-09-2009, 01:48 PM | #245 |
Re: Project NOT4SLE
How important is the neutral safety switch? I removed mine and spliced the wires. Just ensures you do not start the vehicle in gear correct? any risks other then it lunging fwd when starting? I will be installing a floor shifter anyways as i have no clearence between my headers and the colom lever.
69 c-10 BBC 462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build. Last edited by ripdog28; 12-09-2009 at 01:49 PM. |
12-09-2009, 09:53 PM | #246 | |
Re: Project NOT4SLE
Hey Vegas, can you show me what wheel you used on the roof of the truck?
12-09-2009, 11:11 PM | #247 |
Re: Project NOT4SLE
12-10-2009, 09:34 PM | #248 |
Re: Project NOT4SLE
12-10-2009, 09:59 PM | #249 |
Re: Project NOT4SLE
Kewl |
12-15-2009, 01:12 PM | #250 |
Re: Project NOT4SLE
If your other belts are tight then losing the a/c belt shouldn't make any difference on the cooling. As for the compressor, if it locked up internally then the clutch wouldn't turn but if the bearing is locking up then the pulley won't turn (just the part that the belt lays into) You should be able to spin the pulley easily without the belt in place. If you feel any resistance or it feels like it doesn't spin "smoothly" then the bearing is probably shot. I had to replace mine.
