#226 |
78K & 79C Jimmys
Re: Jim Bob a build thread
sure is easy to "plug and play"
found this critter living on it at the trailer
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#227 |
78K & 79C Jimmys
used it more up there this year
seen this yellow one for sale...
#228 |
78K & 79C Jimmys
well after the world ended(dec 21)
the only beast able to move was the 78 sure not the GA no shoveling just back straight out to bad the wipers broke as soon as i used them
#229 |
78K & 79C Jimmys
last week -40
this wednesday +11 a record thought a good day to replace the 78s dizzy... gona miss that miss lol
#230 |
Ha ha I've stopped and looked at that yellow truck too!
#231 |
what kind of dizzy did you replace it with?
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#232 |
78K & 79C Jimmys
lol I stopped to wait for the wife,she shook her head and kept drivin
i duno,I was talking with my parts guy wanting to get a new carb and dizzy. he said he had ordered one ,and the guy changed his mind he said 100 cash,I said yes it was outa the box and in before dinner! returned core already,i gotta stop in there in the morning I'll see if the core/box is still there
#233 |
where was that?
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#234 |
78K & 79C Jimmys
end of ferry road@ the ranch
looking to see if i got some of the others there
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 02-02-2013 at 12:04 AM. |
#235 |
78K & 79C Jimmys
seen these ones there for years,but they move
#236 |
78K & 79C Jimmys
I'd cleaned it a few times,last time it seemed iced up rust lol
#237 |
78K & 79C Jimmys
gona have to drive out and run the 79s
and i got weight springs in the glove box,to play with!
#238 |
78K & 79C Jimmys
I want to make the burb center seat into the jimmy
at this point it dosn't fit between the seats strip it down,build it up I'm thinkin kinda hummer style,tall, black,subs,textured finish,cupholders,storage,....
#239 |
Re: looking at a 78 jimmy
I am having problems with my gauges for my 79 High Sierra Jimmy, The lights have all been replaced yet they keep going out, Not to mention she is starting to make a few whining noises when I turn?
RoughKuntry 73 GMC 25 HUNDRED :Sold 79 GMC High Sierra 4x4 (Ma-Duece) :Sold 99 Chevrolet LS 4.8l/5 Speed Manual 4x4 :Selling 88 Chevrolet Burban 2500 4x4 :Buying ![]() |
#240 | |
78K & 79C Jimmys
I've found the best is to have it out,and apart 1.check all copper paths are straight,use crazy glue ,if any are loose 2.remove and check each bulb (meter it) make the contacts go down and under 3.i give each socket contact,a rub with very fine sandpaper 4.confirm the socket hole is clean,i'll use my finger,thumb to pry/bring up the socket contact to the board that turns in the hole,feel the little lock bump on each hole 5.even tho i might have seen the bulb looks good i test each one after socket inserted too 6.confirm with meter each path is good,you use one (you know is good) bulb ,move it around 7.I also bend to retension the gauge clips ,and then sandpaper to clean contacts 8.with the cluster out,meter the grey(is +),black is neg,turn the dial,meter should swing smooth,if it drops,the dimmer part of the headlight switch is burnt,replace the headlight switch 9.one of the the best things to do is to paint the housing white while totally apart, I used what i had, gloss white rust spray, dosn't take much,but the end result it worth the time hope it helps,let me know
#241 |
78K & 79C Jimmys
wineing mght be a loose steering belt
or low fluid,some say use the tranny fluid,don't headers or manifolds some people forget to replace this brace
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 03-24-2013 at 09:17 AM. |
#242 |
78K & 79C Jimmys
some things to check for
i also clean up the plug copper too,lifting up the contacts to retension those as well
#243 |
78K & 79C Jimmys
that things huge!
#244 |
78K & 79C Jimmys
cleaned up some bush for my Dad
#245 |
78K & 79C Jimmys
second load we covered at home till i dropped it off sat 8:15 am
lol seems only the GMs started early this morning
#246 |
John, still having problems with the Jimmy, anyways I have some aftermarket parts for the gauges and I need a few pictures from you showing how to install the lighter, because when I tried it, it took away the dome light and horn, :/ I am a little frustrated at the moment so can I get a shout out please?
#247 | |
78K & 79C Jimmys
how did you get power? could be an orange right there.... black to ground?
#248 |
Another problem I am having with the rig is, I bought a aftermarket Holly Distributor, with a coil pack, yet I am having problems trying to find the Coil pack to the Flame Thrower Distributor that is on there now?
#249 |
78K & 79C Jimmys
#250 |
78K & 79C Jimmys
did another load
got the stump out I'm done and these guys roll up at the neighbours
