Old 10-07-2018, 09:45 AM   #226
Xenofilus
Re: 1968 C10 5.3 swap, the easy way.
Nice Info, thanks for sharing! I'll try this soon!
_______________________________________
Cheers, https://mechanicguides.com/best-dies...r-6-7-cummins/
Xenofilus is offline   Reply With Quote
Old 03-07-2019, 03:28 PM   #227
faun_cee
Originally Posted by vannatta20 View Post
Goods news My factory drive shaft slid right into the tranny and is the correct length! I adjusted the motor foward/back to get it to work with the tranny. Factory 5.3 exhaust manifolds fit with some minor trimming of the frame. Factory a/c fits but the a/c lines would need some work to fit around the frame. Tomorrow will be the first start and will post more pics.
is this a short bed? i am worried about my drive shaft not fitting but if you have a short bed then i have no worries
faun_cee is offline   Reply With Quote
Old 03-07-2019, 03:36 PM   #228
solidaxel
solidaxel's Avatar
Same here slid the engine back until it ,matched the seal mark on the driveshaft
The shift linkage matched up also with the TH350 part placed on the 4L60E C10 short bed
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-10-2019, 02:21 PM   #229
Grease Rabbit
You mentioned that you build the wiring harnesses, do you have a website or link? I’ve got a 68 C10 I’m putting together and want to do an LS swap on soon. Having an ready to go harness would be so much easier I think.
Grease Rabbit is offline   Reply With Quote
Old 03-11-2019, 08:16 PM   #230
mcmlxix
Collector of Projects
mcmlxix's Avatar
Not sure if Mitch has a website. I follow his youtube channel... Send him a message through the contact member option on here ...
https://www.youtube.com/channel/UC4Y...8WVmguq8PdgAbw
EDIT: Found his website... https://www.swaptimeusa.com/
Rich
1972 K5 Blazer CST Click HERE
Old 02-21-2020, 05:28 PM   #231
Lanman1972
Lanman1972's Avatar
sub'd for the info
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
Old 10-14-2020, 03:42 PM   #232
C10ENVY
sub'd for reference. nice work
C10ENVY is offline   Reply With Quote
Old 10-14-2020, 09:31 PM   #233
Captainfab
60-66 Nut
Subbed for reference also.
