Old 05-29-2014, 06:43 PM   #226
steve aleve
Re: 49' Patina bagged in PA
Thanks man that helps a lot! I think I have an idea of what to do now ha ha. Also I wanted to get your opinion on using a 2" Beltech drop axle with 3" lowering springs up front? I have the spindles and I was able to purchase some 3" lowering springs for super cheap. Will this sit or ride too low?
steve aleve is offline   Reply With Quote
Old 05-29-2014, 09:45 PM   #227
steve aleve
Woops sorry 2" drop spindles not axle... that's confusing lol
Old 05-29-2014, 10:21 PM   #228
99 to Life
99 to Life's Avatar
steve, I can't comment on the lowering springs with the spindles if that is what you are asking. To me its run one or the other. I'd go with the spindles and 3" drop blocks in the rear. the drop springs are probably going to mess with ridabilty and travel, yeah cheap way to lower but prolly not the best ride. The drop spindle keeps stock shock and spring the same, but lowers the whole unit as one.
Here is a decent link on understanding some important stuff when lowering
http://djmsuspension.com/works/alignment-important/
on my 51' with say 4" body off frame and a 2/3 static drop, I'm as low as I'd wanna go. My running boards are like 5.5" off ground.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 05-31-2014, 11:43 PM   #229
99 to Life
99 to Life's Avatar
5-31 another month down. Not too much to show but I'v been getting my 51' out and man I can't wait to get a cool shot with all my AD's. just need to rearrange alot of whips.
So I had the body back on to readjust a few things, now that its all in order its coming back off and I'm going gunhoe on the frame. I got my radiator/core support ironed out and will get some better pics once body is off.
Made some custom straps for my fuel tank, I still want to add skid plate and I have to finish up some more straps and bracing in the back.
Still chipping away on engine, have a little list of things to buy. I'm also still reworking my heads which has been a minor setback, so it's all getting buttoned up soon. I'm hesitant to bring it up and clutter my garage as i wanted to put it on my start stand to fire it up. We'll see. hoping to bring it up and start it this month, crossing fingers. Then maybe july I can have frame and engine done and in.
Old 06-01-2014, 10:25 AM   #230
oldman3
oldman3's Avatar
Really like the first pics, looking good...Jim
oldman3 is offline   Reply With Quote
Old 06-01-2014, 11:28 AM   #231
IWanna49
IWanna49's Avatar
Love the b/w pic. Looks like a friend dropping by to check in on his buddy. Nice work as always, great link for alignment.
Greg
IWanna49 is offline   Reply With Quote
Old 06-01-2014, 11:30 AM   #232
IWanna49
IWanna49's Avatar
Greg
Old 06-02-2014, 10:13 PM   #233
99 to Life
99 to Life's Avatar
6-2 monday, got a little time in today. power went out cause of a storm. I buttoned up a few things up front with the rad mount. Got cab off frame and started welding up some loose ends. Next weekend should be alot of stripping cab and frame, final welding and maybe laying down some chassis saver.
Old 06-05-2014, 12:44 AM   #234
99 to Life
99 to Life's Avatar
6-5 Been putting in some hours on the engine, long story short I got behind with it. had to mill down my stud bosses. I got the heads done and ready to bolt on. I'm going to transport it up north where my truck is. I'll then just put it on frame for start up rather than using my start stand and cluttering up my small garage. So I'll be bringing it up next weekend and that will give me a little time to finish getting stuff like WP, alt, dist. Here is shot of my custom timing tape I make. I have some for 8" and 7.5" balancers. I got the timing cover on and balancer. Just need oil pan and top end put on. This thing has been on and off for way to long, need to fire it up soon.
Old 06-05-2014, 07:51 PM   #235
FarmerSid
FarmerSid's Avatar
Right on 99!
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 06-08-2014, 12:01 AM   #236
skymangs
skymangs's Avatar
Sweet timing mark brother.
skymangs is offline   Reply With Quote
Old 06-09-2014, 10:47 PM   #237
99 to Life
99 to Life's Avatar
6-9 got a bit tied up this weekend but I am close to being on track. Got front end blown apart, stripped and coated. Still gotta finish up the back, then the bottom of frame. Gotta do shock mounts up front too but I'll worry about that down the road. Might wait one more weekend to bring engine up. Still undecided on what to put over this chassis saver. I still have a good bit of aluminum paint I might coat it with but I'v been liking the black.
Oh and I managed to strip the top, do some final welds and coat in about 4-5 hours. I used some cheap flap discs for angle grinders, 40 grit. Got 20 or 25 of them for like 30 bucks off amazon. I used 4-5 discs so far. So still cheaper than sandblasting. As much as I don't like taking the time to strip a frame, this method is way better than using a wire wheel. been there done that, never again.
Old 06-09-2014, 11:23 PM   #238
oldman3
oldman3's Avatar
Looking good 99....Jim
Old 06-10-2014, 11:03 AM   #239
Sssingo
Sssingo's Avatar
Great work!!!! good to see someone bringing these old girls back to life.
Sssingo is offline   Reply With Quote
Old 06-14-2014, 10:03 PM   #240
99 to Life
99 to Life's Avatar
thanks guys, got another truck hot off the northwest. but..... It's not mine, but....I'm the one building it so its cool. I'll get on this next year along with bouncing around on a couple of my other trucks. This year I got the 49' to finish and my buddies 54' panel that is coming in next weekend. Had the 51' out of some pics with her. I still want a pic of all my AD truck and ones I'm working on, but its gonna be tough cause there are alot of them to line up.
Anyway, the patina is staying, shooting for some crazy hp with an LS turbo or two!!! (be a learning experience). Ford 9", maybe a scott's IFS , lowered and coil overs in back, reinforced frame and the list goes on.
Old 06-14-2014, 11:34 PM   #241
oldman3
oldman3's Avatar
I'll be around to watch you work...Jim
Old 06-14-2014, 11:43 PM   #242
IWanna49
IWanna49's Avatar
X2!!!
Old 06-15-2014, 01:09 AM   #243
Billys68SS
Billys68SS's Avatar
Nice truck. I wish I had your luck in finding them.
1949 GMC PU http://67-72chevytrucks.com/vboard/s...d.php?t=608120
1966 C10 http://67-72chevytrucks.com/vboard/s...06#post6601806
1966 C10 SB Custom Cab, Fleetside, BBW.
1968 Chevelle SS 396
1937 Chevrolet Coupe
Billys68SS is offline   Reply With Quote
Old 06-17-2014, 11:56 AM   #244
99 to Life
99 to Life's Avatar
6-16 Billy, I didn't find this one, my friend did. He's gonna be giving alot of business by the sounds of things. He finds the best patina I swear. Just sent me a link to two killer COE's patina's.
So I didn't get much of anything done on my project due to fathersday weekend and moving a bunch of projects around in the compound. What you see outback is just a few of them. I'll be expanding that lot very soon with fencing and gravel and hope to line up most all my projects. I still alot of stuff to move around. Should be getting my friends panel this weekend if all goes well. So I'll be working on that every monday, he has a thread on here already.
All I go done was some stripping of frame and some final welding. Gonna box in some of the rear and coat next weekend. Still gotta take rear apart flip frame and do underneath. So another day or two on frame and it should be covered in chassis saver. Then I gotta figure out what I'm putting over that. Wanted to do silver since I had some left, but I'm just liking the black frame.
Also traded a ford 9" for a 4x4 60's truck frame and a decent bed I can use for my 55.1 series.
Old 06-17-2014, 08:42 PM   #245
FarmerSid
FarmerSid's Avatar
Nice update 99.
C4 IFS & D44 IRS
5.3 HO L33
Old 06-17-2014, 08:58 PM   #246
Advanced Design
Advanced Design's Avatar
99, cool patina on the new find...sounds like it will be an interesting build.
Apologies if you mentioned..what is the coating on the frame? Looks really good!
Thanks,
AD
Advanced Design is offline   Reply With Quote
Old 06-17-2014, 10:33 PM   #247
99 to Life
99 to Life's Avatar
thanks guys, the coating is called chassis saver, I think I got the antique satin black, I'll have to double check. Its just like POR and all them other brands. Here is their site. I got it off ebay though. Its the best/affordable stuff I'v used.
http://www.magnetpaints.com/underbody.asp
Old 06-23-2014, 10:25 PM   #248
99 to Life
99 to Life's Avatar
6-23 Didn't get much time in this weekend either. Friday I went up and helped my friend with his belair. Sat I took a fam day, Sunday I got a little time in. Some final welds, started making boxing plates, and redid my gas tank mounts. Started stripping frame more. Got the bottom front coated, need to finish up back half, then paint. Should be bringing engine up and firing up soon. Drove back up to erie and got some parts for my friends panel, he will be bringing down this week, so its gonna be a full house finishing that up for him and trying to get my truck done this year. crossing fingers
Oh, put about 150 miles on my 51' this weekend, drove it all weekend.
Old 06-23-2014, 11:06 PM   #249
Advanced Design
Looking good 99. Progress is progress and the family days are important. Thanks for the lead on Chassis saver.
Old 06-23-2014, 11:41 PM   #250
oldman3
oldman3's Avatar
Driving the truck makes for a GREAT weekend...Jim
49' ad, bagged 49, bagged 49 in pa
