Old 05-09-2015, 07:58 AM   #226
FarmerSid
FarmerSid's Avatar
Re: 1952 Chevy Vette Roadmaster LT1 Farm Truck Build
Originally Posted by 99 to Life View Post
iv seen guys do the same with wooden wheels. nothing wrong with that one bit. I actually thought it was you using your head, which you are. its ideal to have the right size tire for your ride height. and yeah fab work eats up time for sure.
Thanks 99! I figured you'd know why I used them. There are more important things I have to spend that money on in order to keep moving forward.
Hope it doesn't bite me in the end.
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 05-09-2015, 07:16 PM   #227
FarmerSid
FarmerSid's Avatar
Another day work'in on the truck and play'in with the boys. Got the shock mounts in and carrier mount in. Took longer than I thought but that's how things have been going. Super happy how things are turning out.
Those that have asked about the pdf's, PM me your email and I will send you what I have.
Here's a few pics of how things look now.
First few are of the carrier mount before being welded in.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-09-2015, 07:18 PM   #228
FarmerSid
FarmerSid's Avatar
a few more
C4 IFS & D44 IRS
5.3 HO L33
Old 05-09-2015, 07:20 PM   #229
FarmerSid
FarmerSid's Avatar
welded in
C4 IFS & D44 IRS
5.3 HO L33
Old 05-09-2015, 07:22 PM   #230
FarmerSid
FarmerSid's Avatar
Shock mounts.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-09-2015, 07:28 PM   #231
FarmerSid
FarmerSid's Avatar
a few more showing the upper brackets too.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-09-2015, 07:32 PM   #232
FarmerSid
FarmerSid's Avatar
A few more with the carrier mount actually welded in this time.
That's it for today. Not much going to get done tomorrow as it's Mothers day. Will be a good family day.
Have a good weekend all!
C4 IFS & D44 IRS
5.3 HO L33
Old 05-10-2015, 01:18 AM   #233
Nut Case
Nut Case's Avatar
These brackets are so over built, I love it. Build it so you could land 747s on the frame and she wouldn't budge. I envy your design and welding skills. Keep on keeping on, and sharing. Thanks NC
Been there, wrecked that
Nut Case is offline   Reply With Quote
Old 05-10-2015, 01:54 AM   #234
Advanced Design
Advanced Design's Avatar
Really nice work on the brackets and mounts. Functional and looks good at the same time!
Advanced Design is offline   Reply With Quote
Old 05-10-2015, 09:02 AM   #235
oldman3
oldman3's Avatar
Hey Sid, nice job and looks great...Jim
oldman3 is offline   Reply With Quote
Old 05-10-2015, 09:55 AM   #236
MIKESAD50
very nice fab work!
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 05-11-2015, 11:01 AM   #237
oossuuu754
oossuuu754's Avatar
Some people just have an ability that I couldn't even dream about. Nice work!
---Shawn
Cecil-1953 5 window build thread
Skymangs..Chris of Old Sarge customs had a shop fire and was severly injured. To help with the medical bills and expenses a fund has been set up here....http://gofundme.com/c49h5mjx8 More details are here...http://67-72chevytrucks.com/vboard/s...=1#post7253189
oossuuu754 is offline   Reply With Quote
Old 05-15-2015, 08:18 PM   #238
FarmerSid
FarmerSid's Avatar
Hey all! Thanks for the comments. You have an awesome ride Shawn! Maybe I'll get that TOTM trophy from ya someday. It's been a bit but grass is growing and the wife wants to do yard work. The progress is not picture worthy yet but I got the dog bone crush sleeves all done and welded in. The front cross member is all welded in. Got my boxing plates sheared up today. $25 bucks for 16' of 3/16" X 5 3/4" plate. I have sheets of 3/16" plate but for $25 bucks cut to size and new steel, I said do it. Saves a ton of work. I will post some pics next week as it's our May 24 long weekend up here and there's beers to consume!
C4 IFS & D44 IRS
5.3 HO L33
Old 05-17-2015, 02:19 PM   #239
BIGglaSS
BIGglaSS's Avatar
Looking good, Sid. What is the measurement from the wheel centerline to the batwing mount centerline supposed to be? I can't seem to find this on the net. Thanks.
BIGglaSS is offline   Reply With Quote
Old 05-21-2015, 06:43 PM   #240
FarmerSid
FarmerSid's Avatar
I don't have that measurement but you could measure from the carrier to the batwing centerline. I just put the half shafts 90 degrees to the drive shaft and angled them down 2 degrees.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-21-2015, 06:57 PM   #241
FarmerSid
FarmerSid's Avatar
A bit of an update and have some questions. I have the frame rails epoxy primed and painted John Deere Blitz black. Ready for the boxing plates which will go in this weekend.
So...........I think I'm going to go the LS route now. I found a 2007 L33 aluminum 5.3 out of a truck pretty local. No harness or ECM. None of the local yards supply the harness or ECM from the donor. All said they harnesses get cut when removing the engine.
One place said they have another truck (2005) that came in that has a 5.3 but not the L33 and I could get that harness and ECM. Would those one work with the L33? I bought a programmed ECM from Blackbear Performance for my 04 2500 GMC as it was much cheaper that buying one up here and sending it down to the US to get programmed.
They want $500 for a 2wd 4L60E. Should I get that as well or can I use the one out of the 95 roadmaster?
Any help with the swap would be appreciated. Done tons of reading but things are starting to get confusing. Info overload..
Cheers!
C4 IFS & D44 IRS
5.3 HO L33
Old 05-21-2015, 07:35 PM   #242
JJorgensen52
Simple? What's simple?
JJorgensen52's Avatar
Cheers!
Pretty sure if I remember right the '07 should have had a separate TCM, so you need a controller to run the 4L60E regardless of what trans you use.
The L33 and the regular 5.3 share the same electronic hardware and such, it's a difference in the heads (compression ratio is a bit higher and ports are better) that gives it the boost in power - the biggest advantage really being the weight reduction, about 65lbs. As long as you make sure you get a DBW harness, you should be fine - of course the ECM would have to be flashed anyway to get rid of VATS and such to run it stand-alone.
Oh. And the FlexFuel - do you know if the '05 is a flex fuel or not? They use different fuel injectors (which have different electrical plugs) and there are some other minor differences in the harness, and in the ECM. As far as I know, none of the L33 engines came in FlexFuel
CURRENT
'50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build
'63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos
'66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos
'69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!)
'72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh
'99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily)
'99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs)
SOLD
'71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder)
JJorgensen52 is offline   Reply With Quote
Old 05-21-2015, 07:36 PM   #243
starterman99
starterman99's Avatar
BIGglaSS heres a copy of flat out instruction diagram for 49-54
1950 5 window
starterman99 is offline   Reply With Quote
Old 05-21-2015, 08:08 PM   #244
FarmerSid
FarmerSid's Avatar
Thanks Starterman. I would mock up the box and center the wheel where you want it. Don't mount anything by those measurements. Mine came out different based on where I wanted my wheel centre to be.
Are you using a Flat out rear kit BigGlass?
C4 IFS & D44 IRS
5.3 HO L33
Old 05-21-2015, 08:17 PM   #245
FarmerSid
FarmerSid's Avatar
Thanks for the info. Understand the ECM flash and that's why I may go back again to Blackbear. The tranny and harness the junk yard has is from an 05 I think but are you saying that I should get the tranny and harness from the 05 and it will work on the 07?
Never said anything about flex fuel but will ask. So I should get the gas pedal out of the truck the ECM and harness came out of?
C4 IFS & D44 IRS
5.3 HO L33
Old 05-21-2015, 08:48 PM   #246
_Ogre
_Ogre's Avatar
nice brackets farmersid
i wish we had the plasma table when i did truk
i would have fabbed a lot more
shop air compressor timer
Old 05-21-2015, 08:53 PM   #247
JJorgensen52
Yes, for DBW you will need the throttle pedal and the extension harness for it (there's a connector up under the dash).
The '07 had a standalone TCM, in the '05 it's part of the ECM - so if you get the '05 harness and an '05 ECM, it should be able to control the trans. I had misunderstood and thought you had an '07 ECM.
It would be easiest to use the '05 trans with the '05 harness, because there are a some changes in the way the trans is wired and the sensors - it can get confusing to try and swap them around. Memory says any trans from 03-07 should work, but the earlier ones are different, as are the later ones.
On my '50 project, I'm using a 2011 ECM and TCM and harness with a 2010 trans, which works out fortunately.
If you're feeling brave, check out this page: http://lt1swap.com/2000harness.htm ... TONS of info about the differences in the harnesses for the 99-07 style trucks.
CURRENT
SOLD
Old 05-22-2015, 07:47 AM   #248
Coach529
Coach529's Avatar
Not sure how I missed this build thread before. Amazing work!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 05-23-2015, 07:27 AM   #249
FarmerSid
FarmerSid's Avatar
Thanks Ogre. Everything was made by hand. Good ol drill press, jig saw, die grinder and files.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-23-2015, 07:30 AM   #250
FarmerSid
FarmerSid's Avatar
Thanks Coach. I try my best.
C4 IFS & D44 IRS
5.3 HO L33
