Old 06-06-2016, 02:03 PM   #226
AJCK87
Re: 1963 GMC C30 panel truck
I found a few rotten sections on the grill support that will have to be remedied. I will be incorporating the radiator support from the Dodge, as it has all the mounting points required for the rad, intercooler, trans cooler and the A/C system. I will have limited space so it should be interesting!
AJCK87 is offline   Reply With Quote
Old 06-10-2016, 12:26 AM   #227
AJCK87
Hey guys, started to patch up the grill support tonight. I have the day off tomorrow so should be able to get it all patched and painted.
Old 06-10-2016, 12:27 AM   #228
AJCK87
Pretty crusty in a few spots. It's always satisfying to cut out the cancer and get some fresh steel in there!
Old 06-10-2016, 12:32 AM   #229
AJCK87
Here is a little sneak peak of the head light assembly. I cleaned up the rings for the head lights and polished up the steel on the light assembly cover and laid down some clear coat. Something different, I think it's going to look pretty good.
Old 06-10-2016, 01:07 AM   #230
62stepside longbox
62stepside longbox's Avatar
Nice work, headlight assembly looks good
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 06-13-2016, 12:08 AM   #231
AJCK87
Thanks Nik!
Got some more done on Friday and did some assembly tonight. Assmbly in the dinning room no less! Hahaha I know what your thinking... It was ok'ed by the wife but it was supervised hahaha
The grill and grill support are done, have to put the drivers side head light assembly together. Really happy about how it's coming out!
Old 06-13-2016, 01:15 AM   #232
62stepside longbox
Good job. You know what they say about grilles, it's the first part of the vehicle that you see so it has to look good.
Old 06-15-2016, 09:15 AM   #233
deejaaa1
looking good. gonna look great when you're done.
Black 93 CCLB 3500 6.5 diesel, GV OD, TCI Ez-TCU controlled 4L80E, back on road 10/25/16 after sitting 4 years.
96 ECLB 2500, 6.5 diesel, auto, gone.
Originally Posted by gottattooz View Post
...68 Chevy Shortbed... guy clearcoated..and...threw glitter all over it...like he was feeding chickens!!!...
deejaaa1 is offline   Reply With Quote
Old 06-15-2016, 09:19 AM   #234
pimpston65
pimpston65's Avatar
please to all members dont be sneeking great builds under my nose, now i gotta start on page 1.
pimpston65 is offline   Reply With Quote
Old 06-21-2016, 03:05 AM   #235
AJCK87
Thanks Nik! You are correct, I will spend some more time on the grill support. Decided end I had better lay some paint down on it.
I agree deejaaa! I hope to get it rolling soon, it's just killing me not being able to drive it hahaha
Hahaha thanks pumpston! I have been here, looking back a should have incorporated some of my plans into the thread title. Live and learn, lession one with these projects!
Some progress to report:
Streering column is bolted in and so is the front axle and suspension. Will be spending some more time getting it just right then moving onto mounting the steering box. I spent some more time stripping down the Dodge, wiring harness is out and the box is off. Make it easier to pull the fuel tank and the rear axle. I also picked up 2 5'x12' sheets of 3/4" maple plywood for the flooring. I initially want to use yew wood boards but I am a little concerned about sealing that all up to ensure I don't die from exhaust fumes hahaha. I have the next two weeks off and dedicated to working on the truck. More to come, thanks for tuning it!
Old 06-21-2016, 03:07 AM   #236
AJCK87
Old 06-21-2016, 03:08 AM   #237
AJCK87
Also thanks out to Jake! Set me up with a lightly used set of Rancho shocks.
Old 06-21-2016, 10:46 AM   #238
62stepside longbox
Progress , it's always a good
Old 06-23-2016, 01:17 AM   #239
Downsouth204
Having spent some quality time in the 92 Dodge donor truck. I thought I'd add a profile here and post a few pics of the mighty Dodge in action!
Though a couple hunting pics can't even begin to scratch the surface of the long list of "adventures" this trucks been involved in, lol... I wanted to post a tribute and raise a glass to ol faithful.
It's comforting to know that the heart of the Dodge will now live on in whats shaping up to be an awesome GMC panel truck!
Cheers buddy!
Downsouth204 is offline   Reply With Quote
Old 06-23-2016, 01:46 AM   #240
62stepside longbox
Looks like the truck had lots of great use. Did it come from Kelowna?
Old 06-26-2016, 11:36 AM   #241
AJCK87
Cheers buddy!
Thanks Doug for the tribute! That's great. Yup I have had the Dodge for over 10 years now and has taken me all over the country side. Loads of camping, hunting and traveling.
Can't wait to get the panel rolling. Missing the clatter of the 5.9 already!
Hey Nik,
Yeah it sure has! I bought that truck in Penticton back in 2006, at about 380,000 KMS. Now it's sitting at about 560,000. I plan on pulling freshening up the motor a little down the road, when I switch to the NV4500. Got to stack up some parts after she is running.
I have been flying at the fab work this last week. Here is where I'm sitting.
I have the front axle and drive shaft in, had to get it lengthened 2", the front shocks are mounted, the steering box is on and hooked lined up with the column, had to re-jig the fire wall and get a new line to plumb it in, got the booster set up on the fire wall and working with the pedal, the drivers side inner fender is done, made a battery box and allowance for the boost pipe, and I started on the passengers side inner fender. I have to fit the air box and and heater box some how. Then I will be moving on to the rad support, should be throwing fenders on pretty soon.
Thanks for tuning it!
Old 06-26-2016, 11:37 AM   #242
AJCK87
Inner fender is painted. I also laid down some paint on the grill support and drivers side fender
Old 06-26-2016, 12:45 PM   #243
62stepside longbox
Looks like it's really coming allong, you'll be on the road in no time
Old 06-26-2016, 01:39 PM   #244
padresag
just went thru yoor thread; looks good
noticed your chrome booster for the brakes. what are you going to use for vacuum with the Cummins?
that was a bit of work making all those door hinge bushings and I hate to tell you after the fact but may save someone else the work. you can buy them at the local auto parts jobber; Lordco. you must have one up there somewhere
ron
padresag is offline   Reply With Quote
Old 06-26-2016, 08:03 PM   #245
AJCK87
Thanks Nik, Ooo yeah super pumped! Yard work today but will be back at it soon
ron
Hey padresag,
Thanks! I have a vacuum line that comes off of the power steering pump, the old booster has he same set up so just going to transfer the lines. Yeah the hinges were probably excessive but the front door hinges were more practice for the barn door hinges. I kept getting better at making them hahaha. Saving a bit of money and getting to play with the lathe. I have another set of hinges I plan to do up really nice with full length brass bushings on both sides
Old 06-26-2016, 09:06 PM   #246
padresag
Hey padresag,
GM used the same hinge pin and bushing for 50 years side doors and back doors
I ran a GM hydro-boost set-up when I had my Detroit in my 64
Captfab makes a nice little adaptor to mount them and will give you more brake than that car booster will for your 1 ton
ron
Old 07-01-2016, 09:56 AM   #247
AJCK87
ron
Yeah those do seem easier! Hahaha. Maybe down the road I will switch to a hydro-boost set up. Run this set up for now.
Quick update then back to the shop
Steering all installed, accelerator pedal is in and hooked up, booster master with proprtioning valve on, whipped up a custom air box and incorporated it into the passengers side inner fender, exhaust is hooked up at the turbo, had to chop 4". Hood is on! Moving on to the rad support today wish me luck
Old 07-01-2016, 02:26 PM   #248
62stepside longbox
The engine bay is looking nice and full like it should be
Old 07-02-2016, 11:46 AM   #249
AJCK87
Hot Damb! Parts keep going on, it's really coming together now. Lots of tid-ally stuff to do including the electrical. But there is a light at the end of the tunnel. Pushing to get it on the road, then I can keep at it. Will be so much easier to be able to work on it at home, needs to be a runner first!
Bit of progress yesterday
Got the foundation of the rad support fabricated and bolted to the frame and the drivers side fender on. Hood clears everything and is looking awesome! Will be mounting the intercooler, trans cooler and tying in the rad support with the fenders and grill support
Old 07-02-2016, 11:50 AM   #250
AJCK87
Front end is starting to take shape. Once the front is done I will be tearing out the bed wood, cutting out the new wood, installing the rear axle and suspension, fuel tank and filler neck, fuel lines and brake lines. There is still items on the list but it is getting shorter hahaha
