Old 04-13-2016, 04:19 PM   #226
Kevin_Otto
Re: 48 Chevy COE custom diesel build
Very cool build.... Im glad I found this thread. Im building the same truck and have same donor vehicle.. what did you use for the steering box and where did you source it?
Originally Posted by 47 Fasttoys View Post
Great progress Chance, It's fun when you can start to see the look it will have later. The cab mount set up looks good. Are you gonna need to flare your fenders using the Dodge chassis?
On the radiator/inter-cooler issue: There is a lot of room to be had under the cab, mine lives there with no issues with heat at all. The bottom of the radiator and the bottom of the oil pan are at the same height. I am using the donor unit and I have removable covers should I need to access the front of the engine or radiator.
Rob
Kevin_Otto is offline   Reply With Quote
Old 04-17-2016, 09:33 AM   #227
47 Fasttoys
47 Fasttoys's Avatar
Hey Kevin, if your referring to my build, I used the stock '03 Silverado rack and pinon just changed the angle. It would be best to ask questions on my build thread as to not run over Chance's thread.
Thanks,
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 04-17-2016, 11:22 AM   #228
Kevin_Otto
Hi, thanks for reply.. Was looking at some pics I thought it was chances pic... But got info needed thanks .
Old 04-21-2016, 07:47 AM   #229
Chance48
Lol, glad you got your info Kevin.
My situation is a bit different than Robs, but simple at least. I'll be building a drop box for mine so I can get the steering column angle reduced. Could use a double joint without any mods if I didn't want to change column angle. Good luck
SHAKE N BAKE BABY, SHAKE N BAKE....
http://67-72chevytrucks.com/vboard/s...d.php?t=686729
Chance48 is offline   Reply With Quote
Old 04-30-2016, 01:35 PM   #230
chase@ridetech
chase@ridetech's Avatar
subscribed
Chase Mundy
Direct Line: (812) 481-4736
Email: chase@ridetech.com
chase@ridetech is offline   Reply With Quote
Old 04-30-2016, 07:12 PM   #231
rusty76
rusty76's Avatar
I'm riding. Cool truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 05-02-2016, 07:58 AM   #232
Chance48
Thanks for the interest fellas. Unfortunately I will not be making any progress on her till at least Fall this year. Just to busy during spring/summer months. Chance
Old 08-14-2019, 07:58 PM   #233
1950chevy4x4
Hey Chance,
Any progress on the truck?
1950chevy4x4 is offline   Reply With Quote
Old 08-20-2019, 10:14 AM   #234
lower50's
lower50's's Avatar
Interested?
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
