01-23-2017, 05:55 PM | #226 |
Re: Project blue affair
01-23-2017, 05:56 PM | #227 |
One more angle
01-23-2017, 05:56 PM | #228 |
Sorry. Not sure why they are angled wrong
01-23-2017, 06:09 PM | #229 |
I'm sure you've already seen it, but there's some good info here on LS engines:
http://www.pirate4x4.com/tech/billav...SPrimer/Part1/ and buried in all the text there is an install guide: http://www.pirate4x4.com/tech/billav...Engine_Kit.pdf
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
01-24-2017, 05:33 AM | #230 |
A320 Pilot/USAF Retired
Awesome build!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
01-26-2017, 11:17 PM | #231 | |
Thanks buddy |
01-26-2017, 11:18 PM | #232 |
Got the truck back to my house today! Made some progress on the bed floor frame work. I'll post some pics in a little bit
01-27-2017, 12:32 PM | #233 |
Bed is fully bolted to the floor.
01-27-2017, 12:35 PM | #234 |
Cross bars
01-27-2017, 12:35 PM | #235 |
And one more.
Plan is to now make a little tilt floor in the center of it all. Not sure if I'm going to do the normal tilt it forward or be a little different and have it tilt sideways. |
01-30-2017, 09:41 AM | #236 |
Very nice! Can't wait to see what you come up with for the tilt bed.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
01-30-2017, 10:25 AM | #237 |
Dont know how I missed this build thread. Just read through all of it and love the way the truck is turning out. I was looking at making my bed floor bolt in also and you have given me some good ideas on how to do it. Keep up the nice work!
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
02-14-2017, 04:28 AM | #238 | |
Thank man! ive been working my threw your build! badass truck! |
02-14-2017, 04:38 AM | #239 |
Made a little progress on the bed floor. Im planning on having the bed floor tilt sideways to be a little different then most. I have some stuff to figure out still but Im trying
Don't mind the pieces of metal tack welded on top. They were there so I could make sure everything was flush with the floor that wont move. (Really I just don't have enough clamps) |
02-14-2017, 06:47 AM | #240 |
Looking great, excited to see how you make this tilt bed work
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
02-14-2017, 11:17 AM | #241 |
I get a tilt bed for access to components for service.... Sideways just to be different? Not so much (unless it offers equal access to everything).
02-14-2017, 01:58 PM | #242 |
I might be out of the loop here, but did you just drill a hole in the inner bed liner and access the back of the bolt from the cutout where the rear wheels sit?
Inspirational stuff for sure. |
02-15-2017, 05:05 AM | #243 | ||
Thanks man!
I got the idea from this truck. |
02-15-2017, 09:58 PM | #244 |
Mr g, you do nice fab work.
Nate 1967 short fleet Project Blue Goose 'If it don't bounce back... heeheehee you go hungry!" Blues Brothers |
02-16-2017, 04:30 AM | #245 |
Thanks Nate!
This is the last back half I did. Lot more fab work. |
02-16-2017, 04:36 AM | #246 |
I made some changes to the tilting part of the bed floor. I didn't like how I had it stopping due to the rear crossmember I had in place.
Once again don't mind the bars sitting on top. just there to hold everything in place for now. |
03-02-2017, 10:55 PM | #247 |
I decided it was time to build some wheel tubs for the truck. besides the fire wall this is my first real project with sheet metal. I know some wont like them but im happy with how they are turning out and the owner likes them also. Im going to post some pics step by step to give you guys how im building them.
First I drew the parts in the computer and had a friend cut them out. then I bead rolled the panel. after that I rolled the edge with the read roller and this caused a lot or distortion in the panel so I went and bought a shrinker/stretcher setup from harbor freight (actually happy with them) and starting shrinking the edge so pull the panel back straight. Once I had both panel straight I went to a friends shop and had him put a 90 for a flange. |
03-02-2017, 11:00 PM | #248 |
at this point I went and got some more steel and had a local hot rod shop shear a few pieces for me so I could build the top panels of the wheel tubs. I then rolled the edge of the panel while applying downward pressure to help form the panel in a arc. Then I started tack welding the panels together. slowing fitting the panels together with no gap and trying to align them perfectly.
03-02-2017, 11:05 PM | #249 |
then as you can see in the first picture the end of the tubs were long and needed to be bent so I had a flange. I went back to the local hot rod show where they were nice enough to let me use there brake. and that pretty much brings you to the current status of the tubs.
03-02-2017, 11:21 PM | #250 |
Wheel tubs are really cool.
Great Job. |
