Old 07-03-2014, 02:26 PM   #1
boostedc10
boostedc10's Avatar
Project Beatrix
Renderings:
Changed my first post to be more of a build log. I will include what I have so far for parts and what still needs to be done. Hopefully I get some time and I will try to put prices to everything.
Build Information
Powertrain:
2003 6.0L/317 Heads (LQ4) - Purchased
Turbo Cam (Speed Inc TU1 (Lift .581/.581 Duration @50 225/225 113 LSA) -Purchased
LS9 Gaskets - Purchased
LS7 Lifters - Purchased
ARP Head Studs - Purchased
Valve Springs - Purchased
Hardened Push Rods - Purchased
HV Oil Pump - Purchased
LS2 Timing Chain - Purchased
Accessory Drive (Drive Junky) - Purchased
Holley Hi-Ram - Purchased
Holley Retro Oil Pan (302-2) - Purchased
Valve Cover Adapters - Purchased
1967 Chevy Valve Covers - Purchased
Transmission:
4L80e (2006) - Purchased
boostedc10 is offline   Reply With Quote
Old 07-03-2014, 02:29 PM   #2
boostedc10
boostedc10's Avatar
Re: My 67 SWB BoostedC10 (LQ4 S475)
Cab floor, outer rockers and cab corners were in pretty bad shape but not a big surprise in these norther trucks.
Old 07-03-2014, 02:33 PM   #3
boostedc10
boostedc10's Avatar
Previous owner had also cut a hole in the bed for a fuel cell so the decision was made to go with a black walnut wood floor. It will be fully raised to clear the notch in the new rear suspension.
Old 07-03-2014, 03:04 PM   #4
boostedc10
boostedc10's Avatar
Got the chassis stripped down and ready for the Suicide Door Triangulated 4 Link. Just a note this was long before Nate had his rear kit
Old 07-03-2014, 03:06 PM   #5
boostedc10
boostedc10's Avatar
Here it is with the bed test fit.
Old 07-03-2014, 03:09 PM   #6
boostedc10
boostedc10's Avatar
Next up on the list of to do's was to get the frame filled and sand blasted, then get a fresh coat of paint on it.
Old 07-03-2014, 03:12 PM   #7
boostedc10
boostedc10's Avatar
I had all the chassis bolt-ons powercoated grey. This will be the same gray that will be used on all the bright work on the truck. (Bumpers, door handles and so on)
Old 07-03-2014, 05:16 PM   #8
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
I know that **** Storm all too well. Caught up in one of my own.
It looks like it's coming along good, and I love the fact your doing it with your Son. My boy is right along side me working on mine and My girl is now old enough to Ask Why?, Why?,Why?,Why?,Why?,Why?,Why?,
Good luck and I look forward to seeing it come together!
Subscribed!
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 07-03-2014, 05:32 PM   #9
Sac
I like it. That black & gray look great on the rendering.
Sac is offline   Reply With Quote
Old 07-04-2014, 10:55 AM   #10
boostedc10
boostedc10's Avatar
Thanks guys. A ton more pictures soon.
So.Cal.Super I would say the kids make a build that much more special for sure!
Old 07-08-2014, 12:51 PM   #11
boostedc10
boostedc10's Avatar
I will be running a 6.0l LQ4 stock bottom, 317 heads, cam, and the S475 through a 4l80e. Goal is around 700 at the tires.
Here is the "Little" turbo
And a shot of the 6.0l I just picked up.
Old 07-08-2014, 03:16 PM   #12
Jon01
Jon01's Avatar
Looks good!
Also looks like we're going about the same place with our builds other than I will still have a stock rear clip/no raised bed floor.
64 Biscayne - 230/PG, Accuair E-Level, 18/20 Bonneville C's.
68 Charger R/T - #'s matching 440/auto car, 499/727/3.91.
68 GTX - 440/4-speed, Dana 60. 44,000 miles.
71 SWB C10 - LQ4+S476r
06 Duramax - LBZ - Exhaust, EFI Live, etc...
Jon01 is offline   Reply With Quote
Old 07-08-2014, 03:59 PM   #13
mikeleeshields
mikeleeshields's Avatar
Should be amazing.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme
Mike
mikeleeshields is offline   Reply With Quote
Old 07-08-2014, 05:03 PM   #14
mooseknuckles
mooseknuckles's Avatar
sweet!
mooseknuckles is offline   Reply With Quote
Old 07-08-2014, 05:39 PM   #15
boostedc10
boostedc10's Avatar
Here is the cab after it was sandblasted and put in epoxy.
Working on the cab corners, floor and rockers now. Hope to have the metal work finished up in the next few weeks.
Old 07-08-2014, 05:44 PM   #16
boostedc10
boostedc10's Avatar
Also ordered the CPP big brake kit for the front and rear. Put the fronts on to see how they fit before tearing them down for powder coat. Shortly after the tear down I scored 4 brembo 4 piston calipers so I may swap the CPP calipers out to get the stopping power.
And a pic of my boy tearing them down
Old 07-08-2014, 05:52 PM   #17
boostedc10
boostedc10's Avatar
Had a good friend of mine that is a fabricator build me a aluminum fuel tank to house my A1000.
He thought it was funny to show me after it was done that the pass throughs in the baffles were little penises! Got to love my friends!
Old 07-17-2014, 02:22 PM   #18
boostedc10
boostedc10's Avatar
Made some progress today and got the cab floor out. It was fairly simple just had to brace the cab a bit and go to town with a spot weld cutter. Now, while it is out i need to replace some rot on the inner kick panels and replace the lower end on the "a" and "b" pillar along with the cab corners.
Old 07-17-2014, 02:29 PM   #19
boostedc10
boostedc10's Avatar
Also got lucky and found a Savanah van in a you pull it yard with a 4l80e. An hour of mine and a buddys time with hand tools and she was out with all the parts needed.
I will start tearing it down to rebuild it next week. It will get an HD2 shift kit with a complete trans-go rebuild kit and a single disc 10" 3400 stall converter I am having built.
Old 07-18-2014, 11:15 AM   #20
Wasted Income
Boosted Member
Wasted Income's Avatar
Looking good. Gotta love those BW turbos.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 07-18-2014, 11:23 AM   #21
boostedc10
boostedc10's Avatar
Thanks and ya you can't beat them for the price vs performance.
Old 07-18-2014, 11:31 AM   #22
Brannon yazell
Brannon yazell's Avatar
Ill be watching this one, I like where you're going with it.
Brannon Yazell
67' C10 mated w/ a 01' Silverado, extreme custom
2015 Chevy 2500 Z71 LTZ Crew Cab
MSA, Motorsports Authority, Rigid Industries, Magnaflow, Michigan Metal Works, Raceline, BASF, Street Trucks
http://67-72chevytrucks.com/vboard/s...d.php?t=624964
Brannon yazell is offline   Reply With Quote
Old 07-18-2014, 11:46 AM   #23
nlped
nlped's Avatar
I'm watching. Gotta love a turbo charged ride...
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 09-04-2014, 01:48 PM   #24
mcbassin
Still Learning
mcbassin's Avatar
Killer build! I'm glad I found it. Looking forward to following along.
BTW, I dig the baffles
mcbassin is offline   Reply With Quote
Old 09-04-2014, 01:51 PM   #25
boostedc10
boostedc10's Avatar
Thanks mcbassin. Hoping to have my wheels shortly from Travis @properfomrance! New pictures coming soon!
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
