#251 |
![]() Join Date: Jun 2006
Re: Project Lemon Drop: anything but stock!
[QUOTE=Rokcrln;2080707]The lines pass thru a bulk head fitting and they seal then selves.
Will the shaved cowl keep out all air and water? Are you going to seal off the stock kick panel vent hole or just leave it? Also, how do you plan to route the a/c and heater hoses from the bulk head into the engine bay? are they gonna pass along the inside of the fender above the inner fender, and then may turn back and go up to the compressor. Really, really nice build
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
#252 |
Life, Be In It.....
![]() Join Date: Oct 2003
It should keep all the water and air out. We are using the kick panel vents for other thing and will not seal them off.
Your description of the AC and heater hoses routing is spot on.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
#253 |
Well I had some time in the booth today getting the first bit of color sprayed. I just shot the bottom to try everything out and double check the color. I think it turned out good and I must say I have never had a cab bottom this nice before
![]() Next we will shoot all the misc parts (brackets, inner front fender wells, rad support ect.) then move on to the rest of the exterior. I hope to get it all up to the booth this week and get started next weekend. Kevin LFD Inc. |
#254 |
Freeeeee Mason...
Looks great. Good work, as always.
#255 |
Looks good, what product brand are you spraying Rok?
#256 |
#257 |
Are you shooting a glamour clear from Dupont
#258 |
#259 |
chevy runs deep
#260 |
Kevin-
I've lost track. Are you using your home-made spray booth for this? (probably not if you've spent 2k on the wet stuff). If so, how's it working? If not, I understand.
Have mercy, I'm recovering from my 4x4 addiction. ![]() |
#261 |
someday it will be done!
looks greatWhich of the two pics shows the color best?
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. ![]() ![]() ![]() '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
#262 |
No I went with a rent a booth in Sacramento.
The best color will be once it is out in the sun in a week or two. With the booth lights and a flash it does not show real well. But the stir stick in the sun light will blind you ![]() Kevin LFD Inc. |
#263 |
No wonder you get so much done. I would be sleeping at 3:07AM.
Great job and THANKS for all your posting - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
#264 |
So many posts I couldn't find my answer I hope it hasn't been on here already. With a shaved cowl and the loss of 4-5 screws, how well will the new cowl hold on the truck?
#265 |
Deltron is PPG clear. I haven't heard of that brand label yet but the shop I am at now shoots BASF. Looks like Glasurit for me now.
#266 | |
Kevin LFD inc. |
#267 | |
![]() Then I just got off line with Auto Body Store for about a grand of added parts. Sata Mini jet4 for some of the tighter areas ( I shoot a Sata 3000RP 1.4 for my main gun) Sharp 606B filter/regulator High flow hose and fittings for my dedicated paint hose line. Plus alot of misc. parts and pieces. Kevin LFD Inc. |
#268 |
Lots of high dollar equipment there. Be careful with the high solids clears if you get heavy on the edges it is not very forgiving, it will solvent pop on you and will not come out. Just do not know when was the last time you shot some of the new high solids clears but you probably know that already I am sure.
#269 | |
Kevin LFD Inc. |
#270 |
The only tip I can offer is to go medium wet coats and not full wet coats and also a tip a painter once gave me that helps is to not finish your "pass" where two panels meet, instead if you can finish in between panels or go all the way to the cab corner for instance from the fender if you can.
#271 |
72CSTC5~ thanks for the info, We are on the same page. Yes panel joints I like to give a quick wrist flip for a very soft dusting as you pull away.
Ok you guys wanted to see the real color so I had a fender that was headed for the dumpster and I brought it in the booth with me. This fender was a pull off that was not even scuffed down before laying on some paint so I could test out the new clear for color sanding. It is a hard color to get a good pic of but here are a few. Please remember this is with ZERO body work just some paint, clear, sand paper and hand buff. Kevin LFD Inc. |
#272 |
She's bright alright!!
#273 |
GEARHEAD
Very nice I'm partial to yellow though. If ya don't mine me asking why is that fender going to the dumpster. It doesn't look too bad at all. RJ22
#274 | |
Kevin LFD Inc. |
#275 |
______________
![]() Join Date: Sep 2006
I could probably use that side marker section to turn a 67 bedside into a 68. Front markers are the same size as the rear, right?
