10-30-2008, 12:58 PM | #251 |
Re: mylow53 build
I'm speechless...super nice truck. Anymore pics?
My build, 53 GMC / S10 swap http://67-72chevytrucks.com/vboard/s...d.php?t=305723 My build, 59 Chevy / 88 fullsize swap http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc U.S. Marines - Certified Counselors to the 72 Virgins Dating Club. |
11-11-2008, 09:19 PM | #252 |
Re: mylow53 build
thank you and yes there are....
heres the basic install of the vintage air. had the local ac shop in simi valley crimp the hoses for me (2 bucks). also started to do some wiring on the gauges, just some simple ground connections for all the lights and gauges. installed the original rebuilt gauges and skadoosh it's pretty nice. the gauges were rebuilt at north hollywood spedo. they do it thru the mail also. cost around 800 bucks but nothing can beat the originals... and a bit of a tease i've married the tranny for the final time (please God) to the engine (the ceremony was beautiful). not before striping one of the torque converter bolts (there's always some striping before a wedding). well i had my old school machine shop guy rethread it to a larger bolt. slapped it togeather and am hoping to install it this weekend ish!! GT
Greg 1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school http://67-72chevytrucks.com/vboard/s...=215079&page=5 |
11-12-2008, 12:38 AM | #253 |
Re: mylow53 build
I thought I was the only one to have the stock gauges rebuilt. Nobody remanufactured the '54 gauge, but I didn't like the look of the telescoped 47-53 gauge in a '54 hole. Just my personal preference. Interesting to see someone else make the same ddecision with all the aftermarket companies out there for our pick ups. BTW, nice job on the A/C install. I can't wait for my truck to be road worthy. I'll have to make a road trip down south to meet up with you and check out your ride.
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674 My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost 1960 (400/T350/?) Apache 10 short/fleet side-big window 1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4 2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB Doing my part to warm the globe |
11-12-2008, 10:16 AM | #254 |
Re: mylow53 build
looks great, could you help me out? the fourtys chevys that is tan and burnt orange looks sweet. I have been lookin for a combo. I think I found it!!! could you would you let me know the paint chips?
thanks alot Matt |
11-12-2008, 02:15 PM | #255 | |
Re: mylow53 build
GT
11-14-2008, 03:20 PM | #256 | |
Re: mylow53 build
Did you lower the mounting of the Gen II unit in order to retain a glove box? What modifications (brackets) were needed in order to hang the unit. Mine is getting ready for paint, but I was thinking that I might want to intstal the AC unit in case more welding is needed. Let me know Thanks Marc |
11-14-2008, 03:49 PM | #257 |
Re: mylow53 build
marc difineatly test fit the system prior to paint. the back of the unit requires a mounting point on the firewall. if your firewall is clean you my be stuck. i haven't screwed in the glove box yet but it should fit. the unit is in the correct position according to the instructions no real mods to get it there. just the firewall bolt is hidden. i had to cut one of the firewall supports and put in a speed nut to hold it in. you want i take some picts?
In other news Jay Also known as Houston54, send me a set of used lower hinge covers. i would like to thank him for his kindness. her's what they look like jay. i still need to paint them but they fit like a charm
11-14-2008, 04:01 PM | #258 |
Re: mylow53 build
Greg--
Some pics would be great. I have a smooth (*****in products) fire wall. I now that I need to mount a bulk head but I was waiting until I get the unit. Where did you buy yours from? I like the way yours mounts. I have a custom lower dash panel that I will mount my control unit in and it will also cover some of the Gen II unit as well. Thanks Marc |
11-14-2008, 04:23 PM | #259 |
Re: mylow53 build
directly from vintage air. get the pass thru firewall bulkhead i got as well it's pretty nice
GT
11-14-2008, 08:15 PM | #260 |
Re: mylow53 build
if your firewall is already painted you could use some of the new two part body panel adhesive to hold the mounting brackets, they use it to to bond on door skins and quater panels. that stuff is amazingly strong.
1971 Corvette convertible 454@ 525 hp 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck |
11-21-2008, 01:43 PM | #261 |
Re: mylow53 build
sorry it took so long to get these photos i've been lazy! anyway here they are. one thing to think about since i have the stock firewall and yours is more recessed you may need to alter the rear mount of the ac unit.
11-21-2008, 03:44 PM | #262 | |
Re: mylow53 build
Thanks for the pictures. It gives me an idea of what I am in for. I could always weld a bolt to the back of the firewall if it is not in the recessed area. The truck is looking good. I need to give vintage air a call. I already have new compressor, I just need the other STUFF. Thanks Marc |
12-04-2008, 03:49 PM | #263 |
Re: mylow53 build
engine installed and started. over the thanks giving weekend my brother and dad helped me install the engine. we ran it with out water for a fue minutes. straight headers no muffler. my dad set the timing visually and it fired on the first crank... brad came by and tried to fix a drip on the firewall but messed up with my dull razor. no big deal i'll have several other scraches for him to fix when i'm done..
12-04-2008, 03:52 PM | #264 |
Re: mylow53 build
also spent hours working on the wiring. i think i actually understand what is going on here...
12-04-2008, 04:01 PM | #265 |
Re: mylow53 build
Ooooh, youre going to love polishing that Billet Specialties Tru Trac setup !!!!! After a year of that I was ready to get my LS1.
Looks good though! |
12-04-2008, 04:03 PM | #266 |
Re: mylow53 build
i like the chevy II
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
12-04-2008, 09:27 PM | #267 |
Re: mylow53 build
Greg - Are you working in the garage bare foot?? I thought I was bad working in my garage with flip flops.
The truck is looking good. Keep up the good work. Marc |
12-04-2008, 10:18 PM | #268 |
Re: mylow53 build
Where did all the rats come frome and look what they did to your wiring, better get pest control, lol, by the way nice truck,
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
12-05-2008, 12:11 AM | #269 |
Re: mylow53 build
Working on your truck bare foot...now that's hardcore man.
12-05-2008, 01:08 PM | #270 |
Re: mylow53 build
thats my barefoot brother i tried to get him to put some shoes on but he was on vacation...
12-09-2008, 10:47 AM | #271 |
Re: mylow53 build
WOW... Thats really all I can get our right now, I'll get back with more later...
---Ben Jammin's 1955 Chevy/GMC Project --- ---The shop's live video feed--- <<< See what I'm up to! |
12-15-2008, 12:23 AM | #272 | |
Re: mylow53 build
Thx! |
12-15-2008, 01:55 PM | #273 |
Re: mylow53 build
not sure on the backspacing that was 1 year ago. if you look at earlier posts you'll see when i got the wheels. there was a mixup with the width of the rear axle and i was left using tubs and the most backspacing i could get from the manufacture. i think the rear was over 4" and i had to use a 1/2" wheel spacer to fit it. regardless you should have a pro order your wheels since every build is different. project 57 look thru the earlier posts for the tire widths i can't remember the front but the rears are 18x9.5
12-15-2008, 08:03 PM | #274 | |
Re: mylow53 build
Rick |
12-29-2008, 02:11 PM | #275 |
Re: mylow53 build
spent the last couple of days off installing parts on the 53. i took a bunch o picts. the rear is for the most part bolted up. I'm planning on installing the front fenders soon. also i just finished plumbing the power steering.
additionally i took my glide engineering seat and cushions to a local upholstery shop and asked for a rough quote. he said leather would cost 4k. needless to say i took the seat back home! guys what should it cost?
