Old 02-16-2011, 07:20 PM   #251
jce4isu
jce4isu's Avatar
Re: Finally starting my Longhorn 4x4 conversion
i will be doing this this weekend and had a few ??? for ya
what paint did u use and where did u get the paint
did u brush it on
thanks
Originally Posted by Dieselwrencher View Post
No real great progress this week. I have been busy with the super cold weather, work, and I got a cold that has been slowing me down. But I did manage to go get some paint for my gauge cluster needles. I tore apart my cluster I got from Toomuchstuff. He included some nicer gauges than what some of the ones in the cluster were. I cleaned everything up, and man were the tins nasty due to a leaking oil pressure line. I had my wife paint the needles while I repaired my odometer. She even painted the red line areas because they were faded really bad. She did a great job! Then I polished the lens a little bit. I tried not to ruin the markings on it because I'm pretty sure no one has any of these in stock anywhere. It came out pretty good. i will install my new repop wood grain bezel when it gets here and then this cluster should be done until I get some LED bulbs for it.
Before
After
jce4isu is offline   Reply With Quote
Old 02-17-2011, 03:02 AM   #252
woodwright
Enjoying left field
woodwright's Avatar
Did I miss a post or thread where you talked about that tach? That's not a standard tach right? Does it run off a crank trigger, or the alternator signal? I'm putting a 6.5T in mine and am trying to figure out the tach situation. I don't want to scab some goofy looking bolt on tach in there. I like things to sort of look like they came that way
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 02-17-2011, 04:19 PM   #253
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
did u brush it on
thanks
Joe, I got orange model paint, testors brand I believe from Hobby Lobby. Yes, my wife used a brush of hers and brushed it on. She is way better at painting small things than I, so I let her have at it.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 02-17-2011, 04:42 PM   #254
Dieselwrencher
No, it isn't a standard tach. It is a cable operated tach ran off usually the injection pump on the older diesel engines. I have a tach drive that goes on my front cover and drives the cable for this tach. These things are pretty rare and hard to find. There are 2 different red lines on them as well. I feel the same way you do. I didn't want to scab some auto meter tach in there at all. Especially when I fund out about these factory diesel tachs. Here are some better pics of the front of it. This one is a 3200 red line. I believe the other style is a 2700 or 2600.
Ryan
Old 02-17-2011, 07:37 PM   #255
woodwright
Enjoying left field
woodwright's Avatar
What is the cable drive unit like? Is it a cummins thing, or could I adapt it to my 6.5?
Clint
Old 02-19-2011, 12:09 AM   #256
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Man that's cool! I wish 73-87's had mech tacks, I've been trying to figure out how im going to hook a stock tach up to a cummins :\
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 02-26-2011, 11:50 PM   #257
67chevy1series
67chevy1series's Avatar
we need progress ryan!
67chevy1series is offline   Reply With Quote
Old 03-10-2011, 08:03 PM   #258
onebadbowtie
onebadbowtie's Avatar
we need some updates!
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 03-15-2011, 05:57 AM   #259
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
um... we need some updates PLEASE?
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 03-15-2011, 07:11 PM   #260
copterav8r
S & S Classics Automotive Supply in Oldtown, Idaho snsclassics@frontier.com can get you the instrument cluster below for a Diesel it has boost & engine/trans temp as well as EGT gauges.
http://www.snsclassics.com/new_gauges.html
copterav8r is offline   Reply With Quote
Old 03-18-2011, 09:24 PM   #261
Dieselwrencher
No progress on this at all guys. I had to go out of town for work again so this truck has been placed back in the yard ornamet phase..............
Ryan
Old 03-18-2011, 11:03 PM   #262
jbclassix
Junk Yartist
jbclassix's Avatar
AAAAAHHHHH!!!!!!! I hate it when an original idea shows up before I'm done with it!!!! Well that will save me time...
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 03-18-2011, 11:29 PM   #263
Dieselwrencher
I wonder how many pesos that thing brings? I'm guessing not real cheap.
Ryan
Old 03-18-2011, 11:44 PM   #264
copterav8r
Originally Posted by dieselwrencher View Post
i wonder how many pesos that thing brings? I'm guessing not real cheap.
$1600 as you said not cheap.
Old 03-19-2011, 12:02 AM   #265
Dieselwrencher
Son of a beach! That is a cool look, but for $1600 I can do some cool stuff plus new gauges. Thanks for the idea though. I do like how close those gauges match up to factry units.
Ryan
Old 03-19-2011, 08:44 PM   #266
copterav8r
Yeah, you are right on that $1600 is quite a bit of coin I would use an instrument cluster like your's if I could find one and dash mount gauges, what vehicle did that instrument cluster and tach come out of? Mosesburb makes another good point that instrument cluster that I posted a photo of mounts the most critical gauges on the bottom whereas on a dash mount they are in line of sight.
Old 04-19-2011, 01:07 PM   #267
Dieselwrencher
No real progress, but plans have changed again. I decided in this economy we don't need to spend 4 grand on a pulling truck. One drag car will be enough to eat up the pesos. I told my brother to put his money in his dodge he is buying. So now it's back to a driver. After a couple other projects get done my friend and I are going to tag team the Longhorn so he can take it to Good Guy's in July. I have another core 47rh so now I just need to finish buying the parts to build my p-pumped 24v. I will try to get a pic of my new wood grain bezel on the diesel tach cluster as well.
Ryan
Old 05-18-2011, 04:59 PM   #268
Dieselwrencher
Guess what? Nope, it's not done. But I did get rear drums and most of the hardware for the D80. Hopefully the transmission will get assembled soon and we can get the truck up and start on it. I'm trying to figure out how I want to do the battery trays and have them appear close to original. That idea might just go away. Function over look will probably have to work. I thought I scored a nice steel 8' bed floor but it was holy crap bad. Some people and their idea of "rust free"!
Ryan
Old 05-18-2011, 09:28 PM   #269
watahyahknow
watahyahknow's Avatar
making some underfloor battery boxes behind the cab under the bad might look good too it gets a bit harder to get to them with jumpercables but other than that i dont see why i would want those bulky heavy bits in the front of the truck .
some of the newer vans here have the batteries under the drivers seat along with a lot of the electronics
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 05-18-2011, 10:04 PM   #270
Dieselwrencher
That is a nice idea, but I work on semis and medium duty trucks with them hidden like that and I much rather have them under the hood where they are easily accessible. They stay cleaner and it's not as easy to forgetting about maintaining them that way. I could mount them under the bed and run jump posts for no start situations, but I doubt I'll do that.
Ryan
Old 05-18-2011, 10:23 PM   #271
watahyahknow
my first idea was making sunk in boxes intoo the bedfloor itself but then you drive around with two small swimmingpools after the first sight of rain and you need some sort of doors to cover them run the chance of those metal doors caving in and making a short across the poles etc etc just hanging them of the frame like in a truck would be eazier might even be able to use the covers and batteryrack from a small boxtruck
you know theres a lot of empty space between the cab abd the rearwheels you could build a door in the bottompart of the bedside on both sides and make a bagage-space under there ... its kindah like as the older vw pickups , they had those too only from one end to the other
Old 05-19-2011, 11:56 AM   #272
propanemudtruck
Good to hear you'll be back on this saddle! Any way to mount one in stock location and the second behind the seat or under the bed?
-Kevin
Old 05-19-2011, 03:35 PM   #273
Dieselwrencher
You know what would be cool? If I could find a side box tool box door and install the batteries there and access them via that tool box door. That is an idea.
Ryan
Old 05-19-2011, 03:39 PM   #274
Dieselwrencher
Finally here are pics of the new wood grain bezel and installed. I'm not too happy with the wood grain decal's fit. It's kind of a joke. I had to stretch it to fit how it is now.
Here is a pic of the spare core 47RH I just got in case my 2nd one has a lot of bad parts. And another D80 rear axle.
Ryan
Old 05-23-2011, 02:07 AM   #275
coggonobrien
so as a recap, what did you end up using (model and year) for each of the following and what difficulties did you run into? Dad told me to use his 82 1 ton dodge 4x4 to convert my 68 chevy to 4x4.
Thanks!
front axle:
front spring perches/mounts:
front springs:
rear axle:
rear axle spring perches/mounts:
rear springs"
coggonobrien is offline   Reply With Quote
