Old 03-14-2012, 08:50 PM   #251
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: My long term 57 project
Originally Posted by Dan in Pasadena View Post
Johnny, I have a couple questions about your tubs:
Why two driver's side tubs? Any reason why you wouldn't want passenger side ones? Or were two driver's side just available?
I can see you're adding a flange to the tub and you say you're gonna bolt them to the bed sides....HOW are you gonna do that and not have it show on the exterior; weld short studs to the flat bedsides?
Dan, I used 2 drivers sides because the passenger side has a cutout for the spare tire well.
Handfull 54 is correct, the bolts want show because they are covered by the fender.
ChuckDriver is offline   Reply With Quote
Old 03-15-2012, 06:03 PM   #252
ChuckDriver
Well got it done! I'll do my best to give you guys a step by step update!
Pic 1: This is what I started with.
Pic 2: Centered it over the rear end and it lined up with an original hole towards the front in the bedside angle strip!
Pic 3: Had to move the rear crossmember back approx 2 3/4in and roughed in the cuts to the angle strip.
Pic 4: Cut line for additional clearance.
Old 03-15-2012, 06:21 PM   #253
ChuckDriver
Pic 1: Had to space the mounting holes in the bedside so they didn't align with the 3 stamped detail lines. You can also see the cross in place and the bed board trimmed to match the wheel tub contour,
Pic 2: Mounting holes transferred to tub flange. Notice new square hole in the flange that bolts to the bedwood and cross sill. If I had made the tubs 1in narrower i could have used an original hole!
Pic 3: The majority of the underside of my truck is brushed on rustoleum Regal Red.
Pic 4: Pax side in place. Added additional board under the floor so I can fasten the bed boards from below.
Pic 5: Drivers side.
Old 03-15-2012, 07:01 PM   #254
Kim57
Kim57's Avatar
Those came out real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-15-2012, 09:24 PM   #255
ChuckDriver
Thanks Kim!
Pic 1: Shot from underside. To the right you can see the supporting board running from side to side with screws going up into the bed boards. There is also another one to the rear that you can't see here. All of the wood is pressure treated yellow pine.
Pic 2: This shows the bolts through the bedsides to the tub flange.
Pic 3: All boards in place.
Pic 4: Close up of the tub fitment to the angle strip on drivers side.
Pic 5: Pax side.
Old 03-15-2012, 09:26 PM   #256
ChuckDriver
Might stain them a flat red or gray? Also thinking of covering them with some old cedar planks I've been holding onto for years.
Old 03-15-2012, 09:59 PM   #257
Rods57
Rods57's Avatar
Looks great, cool ideas.
Rods57 is offline   Reply With Quote
Old 03-15-2012, 10:44 PM   #258
oldman3
oldman3's Avatar
Nice job....Jim
oldman3 is offline   Reply With Quote
Old 03-16-2012, 07:52 PM   #259
robozride
anyone looking to do the same set up....I have a set of these tubs from a 1965 truck same color and all, pm me
robozride is offline   Reply With Quote
Old 03-18-2012, 10:12 PM   #260
Dan in Pasadena
Dan in Pasadena's Avatar
JJ,
Your work looks fantastic as usual. I THINK I've read you're considering yellow as your ultimate color(?). Your rims are orange but you painted you're underneath bodywork red...what's your color plans (if you have one)?
Any particular reason you're not reinstalling putting metal bed strips?
I THINK I saw on the Tanks, Inc site you sent me to, a sort of stainless recess for the filler pipe. Will you be using that or just leaving it as-is?
Dan in Pasadena is offline   Reply With Quote
Old 03-20-2012, 08:15 AM   #261
bensimmons_05
bensimmons_05's Avatar
Bed looks great!
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
Old 03-20-2012, 08:49 PM   #262
ChuckDriver
JJ,
Thanks Dan!
Yep, when I first bought the truck my plans were for it to be yellow. But I've really started to like the metallic blues that are on many of todays cars. If I ever do paint it blue I will change the rims, but will probably leave it red on the bottom!
I'll put the metal strips in when I put nice wood in it after paint. And yes I do have the stainless trim piece from Tanks, need to find it, might put it in place.
Old 03-20-2012, 08:50 PM   #263
ChuckDriver
Originally Posted by bensimmons_05 View Post
Bed looks great!
Thanks Ben!
Old 03-21-2012, 10:28 AM   #264
_Ogre
_Ogre's Avatar
looking good!
yellow would be my choice, but blue metallic would have been my 2nd choice too
shop air compressor timer
Old 03-21-2012, 02:22 PM   #265
Dan in Pasadena
Thanks for the info JJ.
Funny, I'm not normally a guy that likes blue EXCEPT every once in a while I see a blue I like and then I REALLY like it. There are a lot of reds and oranges I like and I've intended to someday paint mine one of those....but there are so many red & orange trucks like these. I suppose because they look great in those colors.
I put a green primer on mine just so it would'nt be the standard light/dark gray, or red oxide. But now it's kind of grown on me, so who knows.
I'd really like to see how that stainelss bowl or dish looks once installed.
Old 03-22-2012, 03:17 AM   #266
Iceman_70
Iceman_70's Avatar
This picture convinced me to go for a 56 Chevy truck ...
I definitely gonna paint mine this blue metallic...
Iceman_70 is offline   Reply With Quote
Old 03-22-2012, 07:44 PM   #267
ChuckDriver
That's what I'm talking about!! Beautiful!!!!
Old 03-22-2012, 10:42 PM   #268
Rods57
Rods57's Avatar
So what year is the sedan in the background? 56?
Old 03-23-2012, 05:29 PM   #269
ChuckDriver
It's a 55!
Old 03-24-2012, 10:55 AM   #270
Rods57
Rods57's Avatar
Originally Posted by ChuckDriver View Post
It's a 55!
Hey that's right you me and Bam all have the "book ends" nice.
Old 03-26-2012, 09:08 PM   #271
72ArizonaBurb
When you get to looking at blue paint be sure to check out House of Color Strato Blue. I really like their paint and it was much cheaper than a Dupont or custom mixed paint. I was really surprised about that.
72ArizonaBurb is offline   Reply With Quote
Old 03-27-2012, 08:48 PM   #272
ChuckDriver
Thanks for the advice, but I think it'll be quite a while before I bite that bullet!
Old 04-12-2012, 09:32 PM   #273
waybad
waybad's Avatar
I love this truck!!
waybad is offline   Reply With Quote
Old 04-13-2012, 12:55 AM   #274
55Cameo
55Cameo's Avatar
looking great so far!! I love how clean your frame and engine bay are. keep up the great work!!!!
55Cameo is offline   Reply With Quote
Old 04-13-2012, 08:06 AM   #275
ChuckDriver
Originally Posted by waybad View Post
I love this truck!!
Thanks guys!
