#251 | |
Re: Chucks SWB Fleetside
#252 |
![]() Join Date: Jul 2007
Its kinda stalled right now. I had to put my Mom in the nursing home. Shes been with us for 14 yrs and its been pretty hard on us. Shes real close to us though so we can pop in whenever we want.
thats been taking most of my time. I'll try to do some on it next week maybe, if nothing else happens ![]()
Chuck 68 ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
#253 |
I started cleaning up the rearend but it started raining so I quit and moved it back inside. I'll get to that later. I decided that the gmc core support that I had was too rough. So I just cut the headlight mounts by drilling the spot welds and I'll put them on the nice core support that I have. It started out as a 72 chevy support. I took the mounts off of it and used it on my 68 frontend. Now it'll be a gmc support.
1st pic is of the rusty gmc support. 2nd is the headlight mounts off. 3rd is the good support that will get the mounts.
#254 |
Restoration Virgin!
Chuck....would you have time to do a "how-to" on converting a Chevy core support to a GMC core support.....I think it would be helpful to others...I've seen several people wondering how to do this!.....Prayers sent for your Mother, you and family too!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#255 |
Thanks, I'll show how to do it here. If I have time I'll do a seperate thread.
#256 |
Well I got something going today. I decided to do the gmc core support while the rearend was drying.
In the first pic- is the core support that I want to convert. Its rust free and I wanted to use it. 2nd pic -I started by marking the edges of the brackets with a nail so I could measure exactly where they were on the original support.
#257 |
So after measuring and transfering them to the good support, I marked them with tape. I then marked where the holes were and ground those marks off. I double checked my measurements and welded them on.
#258 |
Now I have a rust free support that I just need to paint.
#259 |
your light buckets are like rabbits! they are mutliplying!
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 ![]() |
#260 |
VA72C10
![]() Join Date: Mar 2008
Nice job four eyes
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#261 |
I got the rearend in and the cab on. The wife helped. (notice the wrench in her hand) I think she wants her parking spot back in the basement.
#262 |
Looks great!
Dustydog 1940 Ford 2D SDN 1970 GMC SB 2004 C5 Vette |
#263 |
yes, i do
hey lonerife, what's that at the end of the hoist there?? did you make that yourself?? what ever that is that's an awesome idea.
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
#264 |
Thanks guys. I made that out of a couple pieces of angle. It works pretty good. In the past I made one of those cab/bed lifts and it worked much better as it makes it more stable. I sold mine like an idiot.
heres a few more and a silohette ha ha
#265 |
looks great cant wait to see the front end on
#266 |
67cheby
![]() Join Date: Sep 2008
that looks great
#267 |
Still Learning
Looks like some great progress! Awesome!
#268 |
VA72C10
very nice! Always encouraging when they start looking like a truck again!
#269 |
![]() Join Date: Aug 2008
Looks good Chuck- will be rollin' down the road in no time.
#270 |
Thanks guys! I am excited to get the cab on but I still need to do some things that I should have done before puting it on like finish the fuel and brake lines. But I'll get it done. I'm jones'n to ride in an old truck again. I like the Silverado but theres nothing like an old truck.
#271 |
I also did a little trick that I like to do with my core support bolts. I weld the bolt to the square washer just to make it easier to put together.
#272 |
did your doors crease or dent with that peice of wood my dad is wonderin thanks rick
#273 |
No damage at all. It has good hinges and pins. I checked it numerous times and nothing has moved or gotten out of shape. This makes the third time moving it this way and all is perfect. They open and close great. gaps are still good too. If I had loose hinges or hinge pins I would remove the doors.
#274 |
Its a hastle when you have to halfway put to together your truck to clean up but I did get the room I needed.
#275 |
a couple more
