#251 |
Re: Project: Tall Grass
Keep up the nice work.
#252 |
Needs a Big Block
1964 Short box On dropmembers and billets 1962 Suburban family cruiser 1972 K10 |
#253 |
Needs a Big Block
Pulled the seat and carpet today,
Mounting the new lokar throttle pedal tommarow , and trimming the floor hump to clear the shifter . ![]() Kinda sad how gross looking the engine has gotten... Ughhhhhhh more work... ![]() Ill get there , I just ordered a set of narrowed control arms and sway bar from Dave and Nate at Porterbuilt I don't "need" them but I'll have a lot better turning radius .I also ordered up some more goods for another customer build. When I pulled the carpet out I pulled the door rubbers up, and found rust.... Not cool. Mon the hunt for some NOS Rockers now I guess. I'm also on the fence about swiping the ole credit card on an engine driven compressor. Ugly as hell but very efficient.... By the time I upgrade my alternator , wiring etc and buy electric comps its more money.... Hmmmmm
#254 |
Matt, ever heard of LS motor mount shims? I need to lift the engine up about 1/4+ " so the A/C bracket will clear the rack. I have searched and some guys are using washers??? Im thinking , because it needs to be tapered, to use flat bar, 3/8 on the top, and 3/16 on the bottom??
Ideas
67- 72 Parts collecter |
#255 |
sorry , I thought I sent a PM!!!!
#256 |
Needs a Big Block
No worries!!
Ill call you tommarow.. As for the truck, the fuel lines are off the list!!! Tonight I found a good spot and mounted the lokar gas pedal. And trimmed the floor hump to clear the shifter.. But I'm off to work tommarow, throttle cable, bolt the headers in for good. And get the battery box mounted. And maybe run some cables next week .....
#257 |
Needs a Big Block
So I'm back , haven't done much, having a hard time switching back off night shifts . But did get the Pedal ( NOT impressed with how loose the assembly is)
It's a brand new lokar.... I'll take it apart and see if it can be remedied. And the throttle cable and springs are in. ![]() So that's off the list.... More tommarow
#258 |
sweet build bro..
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#259 |
Needs a Big Block
#260 |
Needs a Big Block
Reverse progress!!!!
![]() Arms are off and delivered to YBNORMAL For his 72 blazer. Just received notification that my new arms and sway bar will be delivered on wensday..
#261 |
Needs a Big Block
We both love to sit in this thing and make engine sounds......
![]() New arms are here! I know what I'm doing this weekend!!!! ![]()
#262 |
Haha, my two oldest do the same. They don't know any different. The 68' has been in pieces since before they were born. Long before.
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
#263 |
Needs a Big Block
Rendering finally came in, been waiting a while....
#264 |
Needs a Big Block
Got I the arms all painted up.....
![]() And installed, gaining me all kinds of room STOKED!!!!! ![]() And gaining me some turning ability at full drop. ![]() So as it sits both sides are bolted up, brakes are on, so I need to toss in a couple cotter pins. And move onto the steering, just to drill an indent into the shaft for the locking bolts and get those coated in some locktite and torqued..
#265 |
Needs a Big Block
New shop, a new truck or two built and sold couple eye surgerys ( retina fell off) and a new kid on the way..
But finally front and center in the new shop. Time to make this thing run and drive.... ![]() ![]()
#266 |
Better get On that... Cruising time is coming!!
I have got so much to do as well...
1968 short box stepside. 2007 5.3L 4L60, tuned w/EFI Live 2005 Silverado bucket seats. Dominator 2600's all around. Porterbuilt tubular control arms. Magnaflow 3" dual exhaust. |
#267 |
Hope to see you at Super Run in Red Deer this summer.
#268 |
Registered Loser
Dang, its been a while! Looking forward to seeing some progress.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
#269 |
Needs a Big Block
N
E W S H O E S ! Rev classic 100's 20's all around Not the Vintecs I want.... But will do until the Canadian dollar isn't down the toilet!! ![]() ![]()
#270 |
Needs a Big Block
Fuel lines are 100% done,
Working on getting the box sitting correct, and wiring right now...
#271 |
Registered Loser
That looks killer.
#272 |
65 suburban vortec 5.3 bagged
nice work the truck is looking awesome!!!
#273 |
Needs a Big Block
Well folks
After a big push to make a local show...... It runs It stops It steers IT DRIVES!!!!!!!!!!!!!!
#274 |
Registered Loser
![]() How long did it take to pry the grin off your of face?
#275 |
Needs a Big Block
