Old 10-29-2014, 04:37 AM   #251
swamp rat
swamp rat's Avatar
Re: 55 Wagon Progress
That's a nice collection of rides!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 10-29-2014, 10:07 PM   #252
MP&C
MP&C's Avatar
A slight diversion, as the Migmaster 250 has left the building.....
Sold it this past weekend on CL, time now to consolidate, where the old machine was a two-story deal, the new one will be a three story. In order to take up less floor space, I need to incorporate the Miller 211, the Hypertherm Tig, and the Snap On dent puller, and two bottles:
Starting with the base, some 1-1/2 square tubing makes up the frame. This stuff was free, and as with most free stuff, it isn't. Kyle spent most of the time in the shop this evening media blasting rusty square tubing that has been sitting outdoors for a number of years. He also learned a bit more of mig welding..
The Tig will go on the bottom, and it has some mounting holes on the bottom side...
So some 3/4 square stock was used to make some rails for the Tig, along with some holes to tie in the front end..
To be continued....
Robert
MP&C is offline   Reply With Quote
Old 11-02-2014, 12:14 AM   #253
MP&C
MP&C's Avatar
Worked some more on the welder cart tonight. Started by adding the front casters.....
A cross brace was added under the center line of the 2 bottles...
12 gauge will be used to form a tray under the bottles...
Support bracket added for Mig welder:
Next time we'll add the bracket for the dent puller...
Robert
Old 11-02-2014, 07:33 AM   #254
duallyjams
duallyjams's Avatar
did you pick up anything from the auction ?
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-02-2014, 10:19 AM   #255
MP&C
MP&C's Avatar
I picked up a new shop clock at the auction.. My old Budweiser clock had quit about a month or so ago. This is a vintage neon Ford clock, looks to be a dealer only item as near as I can tell..
Also got a small machinists tool box, primarily for the adjustable reamers it had inside, and the casters/wheels you see above for the welder cart..
Robert
Old 11-02-2014, 09:25 PM   #256
MP&C
MP&C's Avatar
Also got this crescent wrench rebuild kit that originally came out of a now closed hardware store. New jaws, thumbwheel/gears, and even vise grip springs (which I actually need a couple). Not items you're likely to see at a big box store..
Robert
Old 11-02-2014, 10:24 PM   #257
duallyjams
duallyjams's Avatar
never seen one those
James
IG duallyjams
Old 11-03-2014, 12:00 AM   #258
Cape Codder
Cape Codder's Avatar
That' way up on the cool scale. Cresent wrenches are still the go to tool for changing torch gas bottles. And handy for bending stuff
Cape Codder is offline   Reply With Quote
Old 11-03-2014, 08:42 AM   #259
FarmerSid
FarmerSid's Avatar
Never seen that before. Cool!
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 11-03-2014, 09:36 AM   #260
Advanced Design
Advanced Design's Avatar
Very interesting....from the day when we repaired items instead of buying a new one.
Advanced Design is offline   Reply With Quote
Old 11-05-2014, 11:42 PM   #261
MP&C
MP&C's Avatar
More progress on the welding cart tonight, the rear axle was made from a piece of angle and two 3/4-10 bolts..
Rear bottle tray made from some 12 gauge, and welded on using about 3/8 diameter plug welds..
Top shelf added along with some gussets made of 12 gauge..
Bottle relief and pull handle added....
Robert
Old 11-06-2014, 09:14 AM   #262
FarmerSid
FarmerSid's Avatar
Nice! That bottle must last you some time.
C4 IFS & D44 IRS
5.3 HO L33
Old 11-08-2014, 12:13 AM   #263
MP&C
MP&C's Avatar
They normally last a year or so..
Here's the rivnut installation video!
https://www.youtube.com/watch?v=3jrrf_VbTsc
Robert
Old 11-08-2014, 12:38 AM   #264
MP&C
MP&C's Avatar
More progress this evening on the welder cart, these studs are added to make use of the bottle bracket that came off the old welder. My brother in law had borrowed it at one time, and it came back with the fancy bracket. He retired the ratchet strap I had around the two bottles. This worked pretty well, so rather than reinvent the wheel.... Reminds me, I have some other things needing finishing I should lend him...
Then a bracket for the clip is added to hold the Mig torch..
Holders for the various cables....
.....and a test fit before we throw some paint on it...
Looks like I have some room left, may have to add one more....
Robert
Old 11-08-2014, 02:23 AM   #265
Advanced Design
Robert- great video on the rivnut installation tool. Thanks for posting that. Really nice cart you put together too. Well done.
Old 11-08-2014, 05:02 AM   #266
swamp rat
swamp rat's Avatar
Nice cart!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-08-2014, 03:37 PM   #267
MP&C
MP&C's Avatar
OK, one last welder to add and I promise I'm done...
Now to disassemble and paint it...
Robert
Old 11-08-2014, 09:07 PM   #268
FarmerSid
FarmerSid's Avatar
Sweet! What colour?
C4 IFS & D44 IRS
5.3 HO L33
Old 11-08-2014, 11:47 PM   #269
franken
Originally Posted by MP&C View Post
Well this evening was a short night, back to the day job tomorrow, so we'll have to call it early. .
If this isn't your day job, the rest of us should just give up.
franken is offline   Reply With Quote
Old 11-08-2014, 11:47 PM   #270
MP&C
MP&C's Avatar
Looking through the flam locker, here's what I have in LOUD. The neons typically don't like UV and are quick to fade, so I think it's between the Chrome Yellow and the Scarlet Red. I'm leaning toward the red...
Robert
Old 11-08-2014, 11:54 PM   #271
Advanced Design
Red, closer match to the Lincoln....
Old 11-09-2014, 06:33 AM   #272
swamp rat
swamp rat's Avatar
Besides its a Harley color..
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 11-12-2014, 11:42 PM   #273
MP&C
MP&C's Avatar
Kyle worked this evening to repair the remaining damaged threaded holes in the inner fenders. A couple of the ones for the core support were stripped, so he changed those out to 5/16-18 rivet nuts.
For the welded on clip nuts for the sheet metal style fasteners, we had drilled them out and installed 1/4-20 rivet nuts to be able to use machine screws instead. A couple of them popped off while drilling, and these were welded back on with the Miller spot welder to keep a good backing support for the rivet nut..
While he was working on that, I got busy adding some color to the welding cart. It was a toss up between some bright red (HD color) which was acrylic lacquer, or a bright yellow (H/K Lemon Yellow basecoat). As I didn't have any lacquer thinner in stock for the red, yellow it is...followed by clearcoat
Along with the purple E-wheel, this should help to brighten up the shop!
Robert
Old 11-13-2014, 12:12 AM   #274
duallyjams
duallyjams's Avatar
skittles
James
IG duallyjams
Old 11-13-2014, 05:07 AM   #275
swamp rat
swamp rat's Avatar
Well it was ether that or Patina then.. It will shine down a little with use.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
