Old 05-18-2014, 07:09 PM   #251
FarmerSid
FarmerSid's Avatar
Re: 1954 3100 C4 Tube Chassis Build
Oh ya! I sent you a pic of the cross member. What more progress pictures do I have to send ya? LoL!
1952 Canadian Chevy 1300
C4 IFS & D44 IRS
5.3 HO L33
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938
FarmerSid is offline   Reply With Quote
Old 05-20-2014, 07:57 AM   #252
FarmerSid
FarmerSid's Avatar
Hey Josh. Things good? Quick question. How much higher is the C notch you made in the rear of your frame?
Cheers!
C4 IFS & D44 IRS
5.3 HO L33
Old 05-20-2014, 09:39 AM   #253
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
How much higher than what? Than factory? Give me a call tonight, I need to get you the info from the front crossmember we talked about the other day. Take care buddy.
--Josh
Old 05-20-2014, 09:43 AM   #254
FarmerSid
FarmerSid's Avatar
Ya, higher than factory.
C4 IFS & D44 IRS
5.3 HO L33
Old 05-24-2014, 08:06 AM   #255
matchstick
matchstick's Avatar
Awesome build Josh! Good to hear from you yesterday. If you need any more brackets cut, get with me. A good friend of mine owns a fab shop. I have access to a water jet and a plasma table.
matchstick is offline   Reply With Quote
Old 05-25-2014, 09:10 AM   #256
STOCKISH
STOCKISH's Avatar
Sounds great man, it was really good to hear from you as well. Its been a long time.
--Josh
Old 06-07-2014, 09:38 AM   #257
STOCKISH
STOCKISH's Avatar
Man, not sure how I let this thing get three pages back. I finally broke down and bought a compressor for the garage, should help with the sand blasting, sanding, etc. I had to fab a couple brackets to mount the lower dog bone brackets about 2" under the rear of my chassis. With my dog bones mounted at the correct angles if they were mounted directly through the side of the frame then my ride height was way lower than I wanted. Ill try to get them finished up and post some pics of that this weekend. After that Ill get to mounting my 5.3/4l60 so I can get my mounts and crossmembers made than its time to paint the chassis.
--Josh
Old 06-07-2014, 08:12 PM   #258
STOCKISH
STOCKISH's Avatar
just got off the phone with the fine gentleman at flat out engineering. Front coil overs and upper and lower mounts are ordered and will be here next week.
--Josh
Old 06-08-2014, 07:54 PM   #259
Advanced Design
Advanced Design's Avatar
That will be cool....really enjoying the build Stockish.
Advanced Design is offline   Reply With Quote
Old 06-08-2014, 09:07 PM   #260
FarmerSid
FarmerSid's Avatar
Right on Josh! What springs did you end up ordering? That's cool that they sold you the upper and lower shock mounts. Keep in touch my southern buddy.
C4 IFS & D44 IRS
5.3 HO L33
Old 06-15-2014, 05:26 PM   #261
STOCKISH
STOCKISH's Avatar
coilovers from flat out arrived on Friday. Spend some time in the garage today with my little man for fathers day. Got the rear batwing brackets made and mocked up.need to build a couple cross members and it will finally be a roller!
--Josh
Old 06-15-2014, 05:42 PM   #262
STOCKISH
STOCKISH's Avatar
Few pics of the progress this weekend.
--Josh
Old 06-15-2014, 05:43 PM   #263
DransportGarage
DransportGarage's Avatar
You're rockin' & rollin' now!
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 06-15-2014, 06:38 PM   #264
oldman3
oldman3's Avatar
Looks good....Jim
oldman3 is offline   Reply With Quote
Old 06-15-2014, 11:19 PM   #265
STOCKISH
STOCKISH's Avatar
Thanks fellas. Ordered a blast cabinet so I can get all my suspension cleaned up and installed. Looking forward to more progress this coming week.
--Josh
Old 06-16-2014, 08:18 AM   #266
FarmerSid
FarmerSid's Avatar
Nice Josh! What model or part number did you go with for the coil overs?
C4 IFS & D44 IRS
5.3 HO L33
Old 06-16-2014, 10:33 AM   #267
STOCKISH
STOCKISH's Avatar
I went with the Aldan Eagle ones from Flat Out. They are the non polished with black springs.Part #7000 I think. Didn't want the high polished to stand out so much.
--Josh
Old 06-16-2014, 06:35 PM   #268
mr incredible
mr incredible's Avatar
looks great....
USN RETIRED
there are two things you don't need in the navy. that's a wife and a pick up truck. cause when your out to sea someone else is using them
mr incredible is offline   Reply With Quote
Old 06-21-2014, 12:28 AM   #269
OneOffStroker
Dang dude, this is pretty cool! I'm going to be doing a 2x4 tube chassis for my '57 next spring or so, but I have a Jaguar IRS & IFS going in. Actually, the Jag IFS is already in the stock frame...MUCH easier than the 'vette stuff!
I did a 5.3/4L60E in my '69 Suburban last year, and the one BIG take-away is that the 4L60E is a pile of trash. I mean, it's about the best auto trans you can get, but it's still an auto trans. My suggestion is to sell it off and get a stick. With your 3.07 rear gear, a T-56 won't do you any favors with the high 1st gear, so go with a NV3500. Low 1st gear, good overdrive, and the same 83mm shaft spacing as the T-56, which give it inherent strength by design, regardless of what 'rating' it has for torque. As long as you don't do 4000rpm clutch dumps or clutch less shifts, it will last forever behind a 5.3.
Anyways...if there are any big Mid-Atlantic shows coming up this fall or next spring, it would be cool to meet up and bench race or at least drink some beers.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
Old 06-21-2014, 03:55 PM   #270
STOCKISH
STOCKISH's Avatar
your project sounds awesome. I look forward to seeing more of it. I think I will stick with the 4l60e. If I can make them last behind 700 horsepower turbo LS motor I think it'll be fine in a stock 5.3
--Josh
Old 06-29-2014, 06:44 PM   #271
STOCKISH
STOCKISH's Avatar
So its finally a roller!! I am going to take it to work and put it on the alignment machine and make sure it is alignable before I go any further with the chassis. Im sure it will be fine but I figured better safe than sorry. Man it looks 4x4 without the running boards, etc... Final ride height will be the same as the second picture.
--Josh
Old 06-29-2014, 06:57 PM   #272
Advanced Design
Looks awesome!
Old 06-29-2014, 07:07 PM   #273
brn agn
brn agn's Avatar
Congrats! That's a big step in the build process.
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 06-29-2014, 08:25 PM   #274
YahamaR1
YahamaR1's Avatar
Read your intire build.. Like your chassis a lott.
That will be a good looking chassis when the paint is on..
YahamaR1 is offline   Reply With Quote
Old 06-29-2014, 10:30 PM   #275
STOCKISH
STOCKISH's Avatar
Thanks for the compliments guys. I really appreciat it.
--Josh
