Old 04-08-2016, 12:23 AM   #251
tinydb84
tinydb84's Avatar
Re: Used Parts Build
Originally Posted by ruffrida2005 View Post
Well have you put the filler panels on the tubes yet?
Yes sir!
and because it is going to rain and I dont have time to paint it before the rain....
David
Instagram: myfabguy
Old 04-08-2016, 04:41 AM   #252
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Those turned out pretty good bud.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 04-08-2016, 12:48 PM   #253
daddyjeep
daddyjeep's Avatar
Very nice. That little bit of time it took to make them unique definitely paid off.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 04-13-2016, 12:30 AM   #254
tinydb84
tinydb84's Avatar
Thanks guys. Got some paint done. I end up wasting time and some paint because I have to do all my work outside and I dont want it all to rust.
David
Instagram: myfabguy
Old 04-17-2016, 02:41 AM   #255
tinydb84
tinydb84's Avatar
Safety lesson. Dont buy cheap stripping discs:
Luckily it only hit my leg and I had some pretty thick pants on. Not much of a mark but damn it actually hurts quite a bit.
Did some more work on my boxing plates.
Didnt get a shot of them welded in since it got dark.
Started on my watts link
David
Instagram: myfabguy
Old 04-17-2016, 09:08 AM   #256
Joe Pass
Joe Pass's Avatar
Looks great...also don't weld in shorts and flip flops
Joe Pass is offline   Reply With Quote
Old 04-17-2016, 10:43 AM   #257
ruffrida2005
Joe doesn't wanna have any fun. Gotta throw a tank top in too so you can tan.
Paul
Old 04-18-2016, 02:40 AM   #258
tinydb84
tinydb84's Avatar
Unless it is tig!
I have a nice arc burn from my mid forearm to mid bicep.
David
Instagram: myfabguy
Old 04-18-2016, 02:43 AM   #259
tinydb84
tinydb84's Avatar
Got a fair amount done today.
Welded in boxing plates from yesterday.
One side of watts link mocked up.
Other side mocked up.
All done.
Still need to add a bunch of support to the frame side mounts.
Ran into a problem though. It cycles perfectly for almost all the suspension travel except the top 1.5''. It runs out of link on the driver side and pulls the suspension that way. I disconnected the driver side and it seems 2'' short. I'll have to figure it out later.
David
Instagram: myfabguy
Old 04-18-2016, 02:57 AM   #260
ruffrida2005
Is it set up at ride height? At ride hight you want the center link top and bottom to be facing at about 350°/170°. That way you don't get the pull.
Paul
Old 04-18-2016, 03:17 AM   #261
tinydb84
tinydb84's Avatar
Not sure if I follow you. Are you talking about the pivot being pretty much vertical? The pic shows it at ride height.
David
Instagram: myfabguy
Old 04-18-2016, 03:24 AM   #262
ruffrida2005
http://www.jalopyjournal.com/forum/t...k-tech.245694/
Correct. You don't want the center link to be perfectly straight up and down. Or it could bind when the bars are parallel to ground are ride height. Also make sure the pivot point it centered between frame rails. That could be reason it pulls.
Paul
Old 04-20-2016, 11:17 AM   #263
Pariah
Originally Posted by tinydb84 View Post
Thanks man.
Just going to run them at a ****ty angle for now. I will probably redo them somewhere down the road.
Finished the bars:
Shock mounts. Not the best angle but will work for now.
Going to run these from the notch to the rear bar and the rear bar to the middle bar.
Started cutting but it got late so this is where I left off.
Sick dude. I love it.
Pariah is offline   Reply With Quote
Old 04-20-2016, 07:58 PM   #264
tinydb84
tinydb84's Avatar
No where near as cool as yours man. Those rivets really set the back half off.
How are you painting the inside of the frame? I would be concerned the inside would rust and run out leaving rust stains all over it. I have to paint/coat the inside of my frame where I body dropped it and my notch. Any tips?
David
Instagram: myfabguy
Old 04-20-2016, 09:39 PM   #265
Pariah
Crazy as it sounds, my plan from the get go was not to treat anything and let all of the fab work rust up to sort of give it the same look or patina that all the sheet metal has and occasionally scuff it all back down till it all gets that darkened brownish orange look. Kinda like how a driveshaft looks after years of rust and oil/grease mixing together. Honestly, as long as it takes rust to cancer out metal at least around here in East Texas, I figure all the work I did will outlast me owning it and probably the next owner or whatever. I'm actually thinking about speeding the aging process after a while on the copper rivets to get them to start that blue/green look. As far as coating the insides of your frame or whatever, if it were me, I'd try to change the tip out of what ever primer/paint you wanted to use to a tip that could accept a spray nozzle or straw like spray lubricants use. And either find areas in the frame w holes or possibly drill some some small holes in the frame just small enough to get the nozzle in every 12-14" inches and blast the paint all around inside then afterward, spot weld the holes back up and touch the outside of the frame back up with whatever paint you're planning to use.
Old 04-21-2016, 11:44 PM   #266
slotard
If you're letting it patina I'd probably give it a few thin coats of BLO
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 04-22-2016, 02:12 AM   #267
tinydb84
tinydb84's Avatar
That is way too nice of a back half to let it rust!
Been getting home late and not able to make a ton of noise. Got the templates for my gussets cut out.
Finally got rid of that brace I was using and put in a proper crossmember. The brace was blocking the watts link a bit.
I'll get it all cut out and welded in this weekend.
David
Instagram: myfabguy
Old 04-22-2016, 03:16 PM   #268
Pariah
That's a great idea. Once it starts getting the color I want, I'll wipe it all down.
Old 04-22-2016, 03:22 PM   #269
jwilson645
One way to speed up the rusting process on steel is to spray with a vinegar/salt solution. Once it gets to the patina you want, wash it down with water to get all the salt off and clear it.
jwilson645 is offline   Reply With Quote
Old 04-23-2016, 03:57 PM   #270
tinydb84
tinydb84's Avatar
Little morning work
Do you think I should run a tube diagonally from the opposite frame rail to the bottom of the mount? Its pretty long off the frame.
David
Instagram: myfabguy
Old 04-24-2016, 11:44 PM   #271
tinydb84
tinydb84's Avatar
Got some more work done.
Cut and grind. Cut and grind...
Crossmember gusseted
Matching ones for the shock mount
Welded the inside of the watts link mounts
Got the other watts link mount boxed in
David
Instagram: myfabguy
Old 04-24-2016, 11:52 PM   #272
tinydb84
tinydb84's Avatar
And got my watt link fixed.
Budget build right?
Had to lengthen my arms by a few inches
I was more concerned about safety than looks so I sleeved the joint an inch in both directions with some 1.5'' .120 dom.
All clear
If you are going to **** up might as well make it look good right?
And video of it in action
https://www.youtube.com/watch?v=VXVEyTYzPEA
David
Instagram: myfabguy
Old 04-25-2016, 03:45 AM   #273
Jaysonb
Jaysonb's Avatar
Your welds are looking good man!
Jaysonb is offline   Reply With Quote
Old 04-25-2016, 08:37 AM   #274
ruffrida2005
I liked your stick watts better. Should have put a plug inside to lengthen your bars. But live and learn. That's a easy thing that can always be replaced if you don't end up liking it.
Paul
Old 04-26-2016, 02:59 AM   #275
tinydb84
tinydb84's Avatar
Thanks. Gotta keep welding and keep learning.
I was thinking about that but didnt have tube that fit the inside well. Just a reminder to measure twice.
Ordered a blazer tank and straps. Once I get that mounted I should be able to start working on my bed mounts.
David
Instagram: myfabguy
