Old 12-01-2014, 10:51 AM   #251
reaper71
reaper71's Avatar
Re: "Project Orangepeel" 52 A.D
The first fitting after I made the bends..
If you look close you can see the marks I had made where the bend started and finished (hence the reason I used the tape) therefor transfer the measurements to the metal,set the bottle in place and make your bend..
reaper71 is offline   Reply With Quote
Old 12-01-2014, 10:56 AM   #252
reaper71
reaper71's Avatar
Pic #1 was able to get it all set in place and using cleckos to hold it there. It also shows the round bar going on..
Pic #2 A closer look and also shows a better look at the marks made for the bend..
Tune in next time....
Old 12-01-2014, 04:13 PM   #253
rusty76
rusty76's Avatar
Wow!
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 12-02-2014, 10:42 AM   #254
reaper71
reaper71's Avatar
Rusty76 thank's again!!
Old 12-02-2014, 10:45 AM   #255
reaper71
reaper71's Avatar
Pic #1 shows the lower round bar tacked in place..Starting to take shape finally!!
Pic #2 a closer look..
Old 12-02-2014, 10:47 AM   #256
reaper71
reaper71's Avatar
A quick look at it all welded and metal finish. It also shows a good look at the panel/door panel lining up.
Old 12-02-2014, 10:58 AM   #257
reaper71
reaper71's Avatar
Pic #1 This is a design idea I have for the inner panel. (wanted to dress the panel up a bit) 1st one has 6 holes.
Pic #2 showing the 5 hole version..
Now, the insert will be made from 1/8" steel and will have the holes drilled in it and will chamfer the edges of the holes or bevel them, for a better look. My idea is the inserts will be painted wrinkle black and the bevel will be re done and left bare (with clear over the bare metal)
Old 12-02-2014, 11:44 AM   #258
youngrodder
youngrodder's Avatar
Looking really good. To add contrast you could always place some fine (SS) screen mesh behind each of the holes in the door panel. That might tie in nice with the edges that you will leave metal finished.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-02-2014, 06:48 PM   #259
rusty76
rusty76's Avatar
That's a great idea!
My build thread
Crossmembers CC
Old 12-02-2014, 10:01 PM   #260
47 Fasttoys
47 Fasttoys's Avatar
Very nice touch having the design flow across the back of the cab.
Rob
My '47 C.O.E build
47 Fasttoys is offline   Reply With Quote
Old 12-03-2014, 11:08 AM   #261
reaper71
reaper71's Avatar
Thank's Marc..something to think about
Marc
Old 12-03-2014, 11:11 AM   #262
reaper71
reaper71's Avatar
Thank's Rob... I felt if I didn't go that route it would look unfinished. You tend to see that alot at some of these shows and so on where the interior just Stops!!
Rob
Old 12-03-2014, 11:13 AM   #263
reaper71
reaper71's Avatar
So....here is the final design I went with.
Old 12-03-2014, 11:15 AM   #264
reaper71
reaper71's Avatar
Just a quick view of the passenger side...
Old 12-03-2014, 11:18 AM   #265
reaper71
reaper71's Avatar
In this pic I am working on the layout of the back panel and the band for it..
Old 12-03-2014, 11:22 AM   #266
reaper71
reaper71's Avatar
Pic #1 showing it with all holes drilled (used a 3/4" rotabroach and made this easy step) The band I had sheared to the same dimension as the back of the panel insert on door.
Pic #2 a better look behind seats with holes..
Old 12-03-2014, 01:41 PM   #267
RockinKees
RockinKees's Avatar
Looks great!!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 12-04-2014, 11:02 AM   #268
reaper71
reaper71's Avatar
Thank's man!!
Originally Posted by RockinKees View Post
Looks great!!
Old 12-04-2014, 11:07 AM   #269
reaper71
reaper71's Avatar
Today I'm going to switch gears a bit I need to fix one issue before I can move forward.
Pic #1 The stock riser.....My bucket seats I have decided to use sit way to high to be able to keep the riser so away it goes...
Pic #2 The sheet of 1/8" I'll be using for the new pan..
Old 12-04-2014, 11:11 AM   #270
reaper71
reaper71's Avatar
Here is a pic of the new pan cut and welded in..
if you notice when I removed the stock riser I left the structure at the back of cab so it will not affect the support of cab at all...
also notice the flange nuts welded in place this is for the seats
Old 12-04-2014, 11:20 AM   #271
reaper71
reaper71's Avatar
Pic #1 shot of the seat/mount I made.
first I needed to remove all the stock mounting pieces and smooth out the bottom of rails. Then I used 2x2x 1/8" tube for the new riser. These were bolted to the bottom of the rails and then I made Tabs so it can be bolted to the new pan.
Pic #2 bottom of seat with tabs on..
Old 12-04-2014, 11:25 AM   #272
reaper71
reaper71's Avatar
Seats all mounted very solid and puts me in the center of the windshield. Since I'm running a visor I put it back on so I could make sure I could see well enough out the windshield..
Next up...The steering column
Mark...
Old 12-04-2014, 05:12 PM   #273
rusty76
rusty76's Avatar
Nice I like how you explain everything!
My build thread
Crossmembers CC
Old 12-05-2014, 10:27 AM   #274
reaper71
reaper71's Avatar
My Pleasure! If you ever have any questions on anything let me know..
Old 12-05-2014, 10:30 AM   #275
reaper71
reaper71's Avatar
In this first Pic I'm mocking up the steering column with my "ultra high tech" tool..
