Old 11-22-2008, 07:18 PM   #276
solidaxel
solidaxel's Avatar
Re: 52 Project
Bernie,
Check out hytecsales.com , much, much cheaper than lizard skin and it looks like it will do more and maybe a better job.
Let me know what you think.
Bob
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-22-2008, 07:21 PM   #277
solidaxel
solidaxel's Avatar
Re: 52 Project
I found the site !!
Rust Inhibiting Paints
Ceramic Reinforced
Hy-Tech rustproof paints and paint primers feature space age ceramics which dramatically improve the rust inhibiting properties of any paint or coating.
To demonstrate the corrosion protection benefits of Hy-Tech ceramics we replaced a percentage of the zinc phosphate corrosion inhibitor in a standard metal primer with ceramic micro spheres and subjected both samples to 1000 hours salt spray exposure. As you can see by replacing the more porous conventional pigment in the coating with hard, low absorption ceramics a tighter closed film surface is achieved and rust is reduced dramatically.
rustproof primer
Additional Benefits:
With the addition of ceramics and their ball bearing like shape paints apply easier with enhanced flow and leveling. Ceramics will not dissolve in water or react with solvents, organic chemicals, acids, or alkalis. The high crush strength improves the durability of the coating and imparts improved wear, stain and chemical resistance.
Hy-Tech offers a wide variety of rust control "Solutions"
#1390 Metal Roof Wash - A water rinse rust remover for metal roofs and other metal surfaces.
#17 Rust Reform - Rust Converter, A water based, Non Toxic and Non Flammable metal treatment that chemically converts rust into an inert coating that seals out moisture to prevent future rusting. No sanding, wire brushing required.
#18 -Rust Proof Metal Primer Revolutionary Water base, low VOC, rust inhibiting primer for metal. Replaces "old" Red Lead and Zinc Chromate Primers
#1267 Metal Shield The ultimate coating for steel, autos, marine use, bridges, storage tanks and steel pipes. Stops Rust, Insulates, Deadens sound
advancement of materials and process insulating ceramic technology
Product Information
insulating paint additivesInsulating Additive
insulating additive makes paint insulateFor Paint
insulating paintsPaint Listings
fire proofing paint additiveFire Retardants
house painting suppliesSundries | Supplies
house painting suppliesTechnical Info
house painting suppliesTestimonials
house painting questionsFrequently Asked
Questions
how to paint a house
ORDERING
buy insulating paints and paint additivesHow to Order
shipping insulating house paintsShipping
international sale of insulating paintInternational Sales
buy house paints onlineStorefront
Customer Service
privacyPrivacy
secure shopping for house paintSafe Shopping
contact with house painting questionsContact
site map for insulating paint siteQuestions?
mapSite Map
home page for insulating paints and paint additivesHOME
start your own business
Search This Site
HOME | How to Order | Shipping | International Buyers | Contact | Questions? | Storefront
Tech Info | Ceramic Insulating Additive | Insulating Paint | Fire Retardants | Sundries/Supplies | Top
Mail Address: Hy-Tech - P.O. Box 216, Melbourne, FL 32902
Fax: (321) 984-1022
© Copyright 2003-2007 and Disclaimer - All Rights Reserve
LS 3 4L70E
Old 12-05-2008, 01:24 PM   #278
bensimmons_05
bensimmons_05's Avatar
Re: 52 Project
hey Bernie, This truck is looking great so far, Attention to detail and small things makes such a big difference in the end. Can't wait to see more pictures!
---Ben Jammin's 1955 Chevy/GMC Project ---
---The shop's live video feed--- <<< See what I'm up to!
bensimmons_05 is offline   Reply With Quote
Old 12-06-2008, 10:00 AM   #279
pgf545
pgf545's Avatar
Re: 52 Project
Thanks Ben, right now I am that stage that every projects come to....the small stuff that doesn't make for good pictures. Hopefully I am going to start doing the cab corners this weekend so I will take a few pictures. Dad was taking a few days off this week and was going to try and finish up the underside of the cab and put some POR15 on it. After that we can start the body work and get the cab back on the frame and then it will start looking like a truck again.
Bernie
52 Chevy Truck (Dad's)
http://67-72chevytrucks.com/vboard/s...d.php?t=206021
pgf545 is offline   Reply With Quote
Old 12-06-2008, 10:59 AM   #280
pugs
pugs's Avatar
Re: 52 Project
nice work looking good , as for the mounts not being even is on the account of the stock battery box is under the pass. side floor
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done...
pugs is offline   Reply With Quote
Old 12-06-2008, 03:15 PM   #281
50adrod
50adrod's Avatar
Re: 52 Project
makes sense, never thought of that
1971 Corvette convertible 454@ 525 hp
1936 Chevy Truck street rod
1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up
1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html
1950 custom Chevy Truck
50adrod is offline   Reply With Quote
Old 12-07-2008, 10:15 PM   #282
pgf545
pgf545's Avatar
Re: 52 Project
Ok so I went down there today and knocked out getting the cab corners cut off. I am going to wait until we get it back upright to reinstall them. Dad is going to spray some paint on the inside area...inner cab corner. He is also going to get the bottom side painted sometime soon so when all that is done I can get the new cab corners on. Here are a couple of pictures that I took today. Enjoy
Bernie
Old 12-07-2008, 11:52 PM   #283
nuke1
nuke1's Avatar
Re: 52 Project
looking good
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 12-08-2008, 07:52 AM   #284
BIG CHEVY 3600
BIG CHEVY 3600 LONGBOX
BIG CHEVY 3600's Avatar
Re: 52 Project
Originally Posted by mylow53 View Post
who is cpp is the from the former solviet union??? or is that ccp?
Cute, try this. Happy to educate you!
http://www.classicperform.com/
If I were given 8 hours to chop down a large tree, I would spend the first 6 hours sharpening my ax.
Abraham Lincoln
http://s729.photobucket.com/albums/w...cpZZ3QQtppZZ20
BIG CHEVY 3600 is offline   Reply With Quote
Old 12-09-2008, 10:35 AM   #285
bensimmons_05
Re: 52 Project
Cab corner looking good! Can't wait to see it welded up.
Old 12-09-2008, 12:24 PM   #286
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 52 Project
looking good man, keep up the good work.
Kabwe is offline   Reply With Quote
Old 12-09-2008, 02:04 PM   #287
mylow53
mylow53's Avatar
Re: 52 Project
after i did my cab corners and cowl replacements the doors didn't exactly fit. the gaps at the bottom were off. if i were you i would put on your doors before you weld the corners in. I learned the expensive way.
GT
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 12-09-2008, 05:29 PM   #288
pgf545
pgf545's Avatar
Re: 52 Project
Grag, Thanks for the heads up. I have been worried about that exact thing. I did fit the doors while I was doing the firewall and floor. I will double check it before I do the corners. It does seem like the door gaps are a little wide but I might be trying to compare it to a later vechicle. From the looks of the picture you posted mine are about the same so I guess that is good.
Bernie
Old 01-10-2009, 07:00 PM   #289
pgf545
pgf545's Avatar
Re: 52 Project
Hey guys finally got something done on the 52. Dad got the underside cleaned and painted with POR. Looks really good. We are eventually going to undercoat it with some Lizard skin but for now it is sealed and ready to move on to something else. I still need to do the cab corners which will come in the next few weeks. Here are a couple of pictures.
Bernie
Old 01-11-2009, 01:04 PM   #290
CAL 58 GMC
CAL 58 GMC's Avatar
Re: 52 Project
Looking good!
CAL 58 GMC is offline   Reply With Quote
Old 01-11-2009, 06:34 PM   #291
Daniel U
Daniel U's Avatar
Re: 52 Project
Bernie, very nice!
Mom's 1954 (TBI 5.7/700R4/14 bolt 4:10) 5 Chevrolet window 3/4 ton long bed Pick up
build thread ->http://www.67-72chevytrucks.com/vboa...d.php?t=228674
My 1954 (TPI 5.7/700R4/10 bolt 3:73) Chevrolet 5 window 1/2 ton short bed Pick up
build thread->http://67-72chevytrucks.com/vboard/s...3&goto=newpost
1960 (400/T350/?) Apache 10 short/fleet side-big window
1973 (TPI 5.7/700R4/14 bolt 4:10 w DANA 60 front) Chevrolet Cheyenne 4X4
2013 (Vortec 5.3/6-speed 6L90 automatic) Sierra LT CREW CAB
Doing my part to warm the globe
Daniel U is offline   Reply With Quote
Old 02-07-2009, 12:09 PM   #292
ratrodmiller
ratrodmiller's Avatar
Re: 52 Project
nice project truck and i like the shop too....
ratrodmiller is offline   Reply With Quote
Old 02-08-2009, 05:31 PM   #293
pgf545
pgf545's Avatar
Re: 52 Project
Thanks for the comment. The shop is pretty big but right now is packed. We still need to get organized...lol.
Old 02-08-2009, 05:38 PM   #294
pgf545
pgf545's Avatar
Re: 52 Project
I got the passenger side cab corner welded in today. I didn't get it ground yet because my brother was using the power for the compressor. I had to do some creative fitting cause the Chinese panels don't really fit too well. Also I had a brain fart when I tacked it in last weekend. I don't know what I was thinking but I didn't even check the door gap...Duh...so I had to cut it loose and refit the corner, but it all worked out. All in all I think it turned out pretty well. Here are a couple of pictures. Enjoy.
Bernie
Old 02-22-2009, 02:26 PM   #295
Kabwe
Certified Car Nut
Kabwe's Avatar
Re: 52 Project
You are progressing nicely Bernie, keep up the good work.
Old 02-23-2009, 08:09 PM   #296
pgf545
pgf545's Avatar
Re: 52 Project
Thanks Kabwe, I finally got both cab corners on, welds ground and spray bombed. For the most part they came out good. The pass side fit a bunch better than the drivers side. I had a really hard time with it. I am still not completely satisfied with it. I will probably do a little finesse work on it later but I wanted to get it done so that I can move on to something else. We need to do something with the door, either redo the bottom or get a new door. Whenever we do that I will rework the cab corner to get the fit a little better. Dad is now retired so he is going to start doing some stuff like striping paint and getting the body ready for paint. He was showing me colors yesterday so I can tell he is getting excited about it. For the most part all the welding stuff is done the only thing I have left to do is fill the gas tank filler and the cowl vent. He wants to wait a little before we do the cowl vent just in case we need to access something under the dash. He thinks it might be easier to get it through there. Anyway thanks for the comment and here are a couple of picture that I took yesterday.
Bernie
Old 02-23-2009, 08:21 PM   #297
OrrieG
OrrieG's Avatar
Re: 52 Project
Looks good to me. The driver door gap above the patch look tight too, how are the hinges? might just be a simle adjustment too.
OrrieG is offline   Reply With Quote
Old 02-24-2009, 12:02 PM   #298
pgf545
pgf545's Avatar
Re: 52 Project
Yeah the gap is really tight. I rebuilt the hinges already and they are tight. I will probably have to mill the slots a little longer to get the door forward some. Right now I am all the way forward on the hinges and it is still rubbing the door frame. This is not the original door so that could be part of my problem....I will get it though.
Bernie
Old 02-24-2009, 12:22 PM   #299
bensimmons_05
Re: 52 Project
Things are looking GOOD Bernie. Sometimes my biggest obstacle is getting done with one side and then after all that work... doing the same thing on the other side. good job
Ben
Old 02-24-2009, 12:29 PM   #300
OrrieG
OrrieG's Avatar
Re: 52 Project
Ben
Ben, you are SO right, best do do the worst side first, then at least the second seems easier.
