#276 |
![]() Join Date: Nov 2008
Re: 55 2nd serie GMC
At a stand still with the paint job, well actually going backward. The paint job on the cab didn't turn out at all the way i was looking for. After trying to fix the orange peel issues i found the paint was lifting at a few places. So here i am blasting the paint of the cab again and starting all over.
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair 99 S10 http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 Last edited by JML55; 07-16-2010 at 08:12 PM. Reason: spelling |
#277 |
Certified Car Nut
sorry to hear that man.
#278 |
http://67-72chevytrucks.com/vboard/s...2&postcount=83
Did you have any issues with getting the engine level from side to side?? I did some research on those mounts (for the older camaro's) and they are different heights or did you order 2 of the same one??
Better to have it and not need it, then to need it and not have it. Fork In The Road....Cummins Build My Build Thread... Alternative A/C Mounting for LS Engines 4L60E Transmission Rebuild Info Trailing Arm How To Last edited by ambryatim; 07-28-2010 at 04:45 PM. |
#279 | |
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair 99 S10 http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
#280 |
Ok, thanks. I was hoping it was going to be more straight forward, but since you had to modify them "alot" then I will just build my own like I was planning to do.
Better to have it and not need it, then to need it and not have it. Fork In The Road....Cummins Build My Build Thread... Alternative A/C Mounting for LS Engines 4L60E Transmission Rebuild Info Trailing Arm How To |
#281 |
Very little done on the truck since the flop with the paint job. I'm trying to decide if i redo it myself or if i find someone else to redo the body work and then paint it myself. Reworked the back bumper this past weekend. My first one was very rusted on the ends. Had to use two bumper to make one that was decent , i used the ends of one and the center of the other one and cut in a license plate. I'm also reworking the front bumper a little, pics to come.
#282 |
I have to say, JML55, that I am enjoying your buid thread tremendiously. It was a way to spend an evening reading about your truck. It's been a long road, the effort is outstanding and the results are speaking for themselves. Persevere and you will have one sick looking ride when you are done!
Curious though, what shade of green did you choose?? I have yet to start a build thread on my 56 Chevy but will post tons of pics as I appreciate all the pics on this site. Last edited by Woodbutcher; 08-23-2010 at 03:01 AM. |
#283 | |
#284 |
Worked on the front bumper mods this weekend. I though it would be fairly simple mod but it turn out to be a bit of work. Here is before and after pics, can you see what is different?
#285 |
Looks like you installed something inside the bullets?? Maybe a baby moon hub cap?? But, there is an insert of some kind.
Looks really good too, what ever it is.
Better to have it and not need it, then to need it and not have it. Fork In The Road....Cummins Build My Build Thread... Alternative A/C Mounting for LS Engines 4L60E Transmission Rebuild Info Trailing Arm How To Last edited by ambryatim; 09-05-2010 at 11:06 PM. |
#286 |
![]() Join Date: Mar 2009
That is a beautiful grill, Jean-Marc. Did you modify the bullets?
Edit: oops ambryatim beat me to it
1962 Chevy blue SBFS 1957 Chevy yellow SBSS 1956 GMC red SBSS Nov 2017 ToTM https://www.facebook.com/groups/Cana...geChevyTrucks/ Last edited by bobinbc; 09-05-2010 at 11:23 PM. |
#287 |
Looks sharp.
Kim |
#288 |
Tripple Five Fanatic
I like it, is the mesh behind the GMC letters stock?
Tri5
1955 Chevy Stepside/LS1 drive train http://67-72chevytrucks.com/vboard/s...d.php?t=371513 Last edited by Tri5Nerd; 09-06-2010 at 01:58 AM. |
#289 |
No, it never had a mesh in there from the factory and the GMC script would have been on the front of the hood.
#290 |
Insane In The Membrane
I'm kinda do'n the same thing to my grill, do you happen to have a pic of the back of your assembly? How'd you mount the mesh to the grill? Weld tabs on?
Cameron Gunlock Project: ALTER-K-TION ('57 GMC Quad Cab) http://67-72chevytrucks.com/vboard/s...d.php?t=393750 |
#291 | |
![]() Tri5
1955 Chevy Stepside/LS1 drive train http://67-72chevytrucks.com/vboard/s...d.php?t=371513 |
#292 | |
![]() Join Date: Mar 2008
www.mcnichols.com
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
#293 |
Looks Like you're using 57 Gmc Bumper bullets.........
Semper Fi! |
#294 |
You're the winner.
#295 |
This is an old exhaust stack shield from a big rig i had kinking around the shop. It's attached to the filler panel that is between the bullets at the bottom and to the under edge of the cross over bar.
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair 99 S10 http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 Last edited by JML55; 09-06-2010 at 10:41 PM. Reason: spelling |
#296 |
Here is a picture of what i used. Heat shield of a truck exhaust stack.
#297 |
Yes I got a pair of 57 GMC bullet because i like that they have a little bit more character then the 55 ones with the cone part in the center. It wasn't just a swap they had to be modified to fit right. I guest since the 57 doesn't have the crossover bar they have a little bit different shape, they are shorter and do not mount quite in the same location. First i had to cut out the inner braces and remount them to fit the holes in the bumper. Then i added a strip about 1 1/2" that i cut of some old beat up 55 bullets i had to the edge to give me a place to attach the crossover bar.
#298 |
Couple more pics.
#299 |
A320 Pilot/USAF Retired
Great work, it looks awesome!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#300 |
Semper Fi! |
