05-03-2009, 12:25 AM | #1 |
'56 Chevy Panel build (SLP)
Well with the purchase of the suspension I’ve decided to go ahead and start a build thread. I’ll start from the beginning just to document it all on one page.
In high school I would drive buy this little old junk yard that was in a town of around 900. I kept eying this panel that was barely visible. This was what it looked like from the street. 3rd year of college I decided to talk to the guy and ended up buying it for $50. Turned out to be a ’56 chevy ½ panel. Last time it was on the road from the plate was ’68. It took 6hrs to get it out of the junk yard and to the farm only 8 miles away. More junk yard shots. It was full of engine parts he was storing. And it was covered in moss. I used an old axle that my dad had lying around to transport it once out on the farm. Here are pics of it after I scraped most of the moss off.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared |
05-03-2009, 12:26 AM | #2 |
Re: '56 Chevy Panel build (SLP)
Then it sat in the old shed until for 14 years collecting dust.
While it didn’t look like much the panel body has zero rust through. The only rust though is in the typical truck areas, steps, toe board, firewall, and cowl.
05-03-2009, 12:27 AM | #3 |
Over the last few years I’ve been collecting parts. Now I’m going to start on the first stage of the build, to get it rolling. Here is my rendering I did to inspire me. I look at this every day.
Plans Suspension front- Scott’s Super Slam IFS, airbags, disc brakes, power rack. Suspension rear- SD’s Super lift triangulated 4link Wheels - dodge 20” steel spares, filled holes, and early chevy hub caps Body- 2 tone paint, slight custom touches here and there but keeping it stock looking Interior- Keep it simple and looking stock Motor- ?? don’t know yet leaning toward and LS.
05-03-2009, 12:29 AM | #4 |
May 1st after work.
I pulled the panel over to the shop to start. Since it was a late start that’s all I got done. May 2nd It started off good found 4 used 20’s for $25 on my way to the metal shop. Metal shop was closed, so no metal for the boxing plates. Next I just started to clean the panel out. After 41 years of sitting there was a ton of dirt. I knew that the wood was in decent shape but wow only one small spot that had a little rot. Here’s more of the clean up.
05-03-2009, 12:30 AM | #5 |
A few things I never noticed fire extinguisher bracket and flare bracket
Dash has the heater delete and radio delete plates.
05-03-2009, 12:31 AM | #6 |
Little bit of the fun stuff.
20's” mounted to the s-10 rear. Now it’s time for cutting up that nice wood floor. You truck guys have it easy, just yank the bed off and there you have it. Just for fun I rolled the rear end up front to see what it was looking like. Still need lower profile tires and the rockers are still too high. That’s it for a little while. Since it’s out on the farm 20 miles away, only get to work on the weekends.
2001 GMC SIERRA 1956 Chevy Panel Build Page with a Scott's Hotrods IFS 1953 Chevy trucks Project Dime Time 1968 Camaro 1968 Volksrod "NOBACK" Jared Last edited by GRIMSS; 05-03-2009 at 12:32 AM. |
05-03-2009, 01:05 AM | #7 |
sweeet.
using adapters in the back? |
05-03-2009, 06:25 AM | #8 |
Nice work Jared
You must be excited to finally get started on the panel. You sure got luck with that shell. Good start. I'll definitely be following closely every weekend Luv your rendering of the finished product, that gonna be sweet
--Glenn-- http://67-72chevytrucks.com/vboard/s...d.php?t=345975 http://67-72chevytrucks.com/vboard/s...d.php?t=564403 |
05-03-2009, 08:51 AM | #9 |
For now I'm using adapters. Later on I will probably build a rear with out them.
Very excited about the start. Like I said been setting on this thing for 14 years plus the 5 years from when I first saw it. And yes deals like that are getting harder to come by.
05-03-2009, 11:10 AM | #10 |
keep it up man .....
05-03-2009, 10:33 PM | #11 |
Nice work, i like it with the 20" looks rely good. Keep the pictures coming.
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair 99 S10 http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
05-04-2009, 09:23 AM | #12 |
Yellow truck club
Have you finished up a wheel and tried to balance it yet. I remember seeing a thread about you doing this with the wheels and wondered how it worked out?
Neat build......
................................................................ Brian ...... My hub garage address http://www.hubgarage.com/mygarage/59apache I gue$$ everything has it'$ price ALL GONE NOW 59 Chev Apache PRAISE THE LOWERED 350 700r lokar shifter power MII front end, shockwaves tilt, 4 wheel discs 4-link and bags 10 bolt limited |
05-04-2009, 03:01 PM | #13 |
subscribed..
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
05-04-2009, 05:55 PM | #14 |
Not yet. Still need to do a little grinding on the test wheel.
05-05-2009, 12:34 AM | #15 |
they will balance. You'd seriously have to bend the wheel for it to not balance.
you'd be freaked out if you saw how actually out of round and horribly off weighted 99% cast chrome wheels are. |
05-05-2009, 07:12 PM | #16 |
what are the wheels off of? looks like some great progress!
05-05-2009, 09:07 PM | #17 |
Wheels are newer 20" dodge truck spare tires.
05-05-2009, 09:13 PM | #18 |
BlahBlahBlah
Lotta nice ideas going together here. 56 panels are very cool.
… … … … … … … … ... … … … … … … … … … … … Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 |
05-05-2009, 09:40 PM | #19 |
Any progress on the cab?? I have to ask... Why did you have to cut the floor out??
and which S10 rear axle did you p/u for your truck?
--Glenn-- http://67-72chevytrucks.com/vboard/s...d.php?t=345975 http://67-72chevytrucks.com/vboard/s...d.php?t=564403 Last edited by 57ToyBox; 05-05-2009 at 09:43 PM. Reason: added to the question |
05-05-2009, 11:05 PM | #20 | |
Thanks, been thinking about this thing for a while now. With all the stuff going on today it's getting harder to come up with something different.
Cut the floors for my 4link. With the size of tires and how low I'm going it had to be done. This is a 2wd S10 rearend. I did checking and since I had to run addapters it was going to work for me. I plan later to build a rearend that will do with out the addapters and be wider.
05-06-2009, 04:45 AM | #21 |
05-06-2009, 03:32 PM | #22 |
ck the width of a mustang or cougar they mite be what you need
the body looks real decent from what we see
I don't do thing cuz I can, I do it cuz someone told me it couldn't be done... |
05-06-2009, 06:56 PM | #23 |
I love it!!
05-10-2009, 08:51 PM | #24 |
Big fat zero done on the panel this weekend. Wife birthday, mothers day, and nephew's dedication used up my whole weekend. And found out that next weekend is loaded up also.
I did go out to the farm to check on it after some nasty storms rolled through the area the other night.
05-10-2009, 11:48 PM | #25 |
I understand my weekend was honey doos involving the cabinet making part of the shop. Next week end I'm traveling to my Mother's memorial service. But after that I get to finally prime and paint all the stuff I worked on this winter and get to finishing the body work. Did have a nice mothers day BBQ over at my kids.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
