02-13-2011, 08:48 PM | #276 |
Re: Project: Custom 71 4x4 hotrod
That's going to look slick once the calipers go on! I think you'll really like the OD trans - I know I wish I had one...
-Marcus 1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's 1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow 2022 Silverado 3500 L8T Project Daily Driver Project Heavy Hauler Project Plow Truck |
02-13-2011, 09:22 PM | #277 |
cool
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-13-2011, 10:40 PM | #278 |
I told you so, yours is going to be so bad$%&, and it is actually already there! She sure is looking nice brother, keep up the good work, i need your build to keep my brain sharp.
02-13-2011, 11:06 PM | #279 |
SWBs: 67 2x4, 67 4x4, 70 4x4
I hope you have better luck with your steering box than I have.
Still working the bugs out of that thing. When you going to hang some sheetmetal? Chassis and axles look great.
FINISHED Project thread: 67 SWB 4x4 FINISHED Project thread: 67 SWB 6 cyl cruiser Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT 01 C5 convertable 08 Z06 |
02-13-2011, 11:25 PM | #280 |
Thanks and I agree. That bright red will stand out great against the black and carbon fiber metallic. I hope I can see some red in between my rim spokes.
02-13-2011, 11:29 PM | #281 |
We are certainly motivating each other but I do appreciate the kind words. I'm just trying to keep up with you my friend.
02-13-2011, 11:34 PM | #282 | |
Hopefully I can be in some sheet metal by spring. |
02-19-2011, 07:18 PM | #283 |
After getting both my front hubs finally installed I tried to mount my wheels and discovered the new wheel studs from LMC are too short. Unfortunately, they protrude from the hub about 1.75" - the same thickness of my rim. The lugs in the photo barely grab the stud. Do any of you guys know where I can buy some wheel studs which will work with Dana 44 set-ups (knurl is offset so that the press fit is with outer the hub assembly instead of the inner rotor) and aftermarket/thicker rims?
I probably need around 2.75" long 7/16" 20RH studs (wheel mounting surface to end of the stud) with the offset knurl. Last edited by silver7; 02-20-2011 at 09:43 AM. |
02-20-2011, 10:29 PM | #284 |
With some help Rennat 2006 I think I found my solution -mag style lugs. Ordered them tonight off Amazon after finding them on www.summitracing.com (cheaper and shipping was free). If anyone is looking for a deal on some acorn style 7/16" RH Gorilla Lugs and locks I'm your guy.
Got a great deal on the ultra-low 6.34-1 granny gear NV4500 out of a 93 Chevy last week and received it Thursday. Also found an even better deal on a 6 bolt pattern NP205 transfer case from of a 87 one ton this week. The pics show how this combo is a direct bolt on versus needing a $900 Advance Adapter if I was use my other figure 8 bolt style NP205 instead. They both need some TLC but I planned to rebuild the NP205 anyways. The black/red NV4500 and NP205 photo is similar to what I think I will do with mine- minus the twin stick. Last edited by silver7; 02-20-2011 at 11:21 PM. |
02-20-2011, 11:05 PM | #285 |
Chevy Enthusiast
Nice score on the nv4500 and round 205!
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
02-22-2011, 08:12 PM | #286 |
Got my steering gear, adjusting sleeve, pitman arm, steering knuckle, tie rod and front diff cover installed. I think I may have a clearance issue with the tie rod and front diff cover so I did not torque everything to spec yet but you get the idea.
Still need to get off my rear and order some custom U-bolts from totally stainless for my brackets so I can get my dual steering stabilizer put on as well. NP205 should be here by Monday. Inline Tube stainless brake lines, custom aluminum fuel tank from Boyd Welding, and NP205 cleaning and rebuild are next on the list - I think. |
02-23-2011, 01:00 AM | #287 |
Chevy Enthusiast
You may need a drop pitman arm to get the drag link as close to level as possible, but I wouldn't worry about it until you have all the weight on the suspension.
Everything looks great!
02-23-2011, 09:58 PM | #288 |
Thanks, I'll definitely take a look at that when the time comes.
02-24-2011, 05:54 PM | #289 |
Under Construction
nice progress.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
02-26-2011, 10:18 PM | #290 |
[QUOTE=silver7;4500919]With some help Rennat 2006 I think I found my solution -mag style lugs. Ordered them tonight off Amazon after finding them on www.summitracing.com (cheaper and shipping was free). If anyone is looking for a deal on some acorn style 7/16" RH Gorilla Lugs and locks I'm your guy. QUOTE]
Unfortunately, these new lugs did not work either. : I've come to the realization I am going to need to bore my wheel stud holes to accept the 0.685" diameter shank style lug nuts if I go this route versus longer wheel studs. But even if I do that they may not protrude far enough from the rim to be able to grab them with a socket. censored: At this point if I could buy some longer wheel studs I would. But I've searched far and wide and have yet to find a longer wheel stud in 7/16" 20 RH with the offset or very long knurl. The problem appears to be that my OEM studs have an offset knurl about 1/2" or so deep into the stud where it is a press fit with the hub assembly which fits inside the front rotor. Anyone know where I can find some long wheel studs to replace the OEM studs with the offset knurl in this pic? Something in the 2 1/2 -3" long range would be desireable. Last edited by silver7; 02-26-2011 at 10:22 PM. |
03-06-2011, 10:22 PM | #291 |
NP205 arrived Monday. Exterior looks a little rough but I plan to take it apart so I can rebuild it. Before I do I'll send the case to get sandblasted for epoxy primer, base and clear.
No luck with a definite solution to my wheel stud issue. Called ARP and their special order department seems to think there is replacement in a 1/2" variety they can sell me. They also said it would be about $1K to special make me a special set. . . Although not perfect I like the 1/2" option better. Unfortunately, I'll still have to pay about $12 per stud and redrill my hubs and my rotors to accept a larger knurl. Also just purchased an aluminum fuel tank from David Boyd at www.boydwelding.com. He is having one of his group buys and I took advantage of the great deal. Last edited by silver7; 03-07-2011 at 07:54 PM. |
03-18-2011, 11:29 PM | #292 |
DUDE! Updates please, i need you to get your tank and fuel lines in, you are my guinea pig for this part of the project!
03-19-2011, 12:51 PM | #293 |
Currently Blazerless
You should be able to find a 1/2" wheel stud that is long enough and has the right knurl size to fit your rotors...the 7/16" you have now necks down. I did this years ago on a 72 Blazer that I ran 35"s on and wanted the the bigger wheel studs. Tell your parts counter guy to show you his Dorman catalog, then go into the back where it lists the studs by size instead of application.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
03-26-2011, 08:10 PM | #294 |
I've been really swamped with work, school (pursuing PhD in Forest Biomaterials at NC State) and basketball/baseball (my son) so no time for the truck lately.
I've been through numerous wheel studs and lug nuts but I think I may have a combination that works. The stud on the left is the ARP set ($65+ for a set of 5) and it was too long. The middle stud is a Dorman stud and the only one I could find long enough with an offset knurl. The right stud is what's on my truck now. The lug nut is the longest I could find that takes a special socket and I think it will work with the Dorman stud. Now I need to remove the hubs I worked so hard to install so I can drill the rotors and hubs to accept the new studs. What a kick in the balls. . . But at this point I'm ready to move past this unexpected set back. My Boyd Welding fuel tank arrived earlier this week and looks great from the little bit I have seen it. One I get everything out of the box and mounted I'll post some photos. Hopefully I can order my fuel and brake lines next month. For you hardworking folks out there who believe in US manufacturing my employer Mannington put together this video to promote keeping jobs in the USA. Mannington is a 4th generation family owned company who produces high quality flooring here in the US. I am blessed that Mannington hired me out of the Army in 2002 and I'm currently a Technical Manager at our Wood Flooring Plant in High Point, NC. If you have 2 min to spare check it out and let me know what you think. Shawn Last edited by silver7; 03-26-2011 at 08:19 PM. |
04-15-2011, 03:59 AM | #295 |
Build's lookin great man - keep the pics coming!!! Anxious to see how this one turns out!
1977 Chevrolet K30 LWB Crew Cab 497HP Mast Motorsports 6.0L LY6 HO engine GM NV4500 5-speed, Centerforce clutch + NP205 D60 + 14-bolt FF w/ Eaton posi + disc brakes Skyjacker 2.5" full spring lift w/ Nitro shocks Custom paint + interior http://67-72chevytrucks.com/vboard/s...d.php?t=435722 |
04-15-2011, 07:17 AM | #296 |
cool video, thanks... I'm originally from the midwest so auto manufacturing was what everybody wanted to do after high school... lots of those places closed but I blame unions for a large portion of that..
04-19-2011, 07:15 PM | #297 |
Mannington has been good to me and my family. No union - family owned and professionally managed. US manufacturing is not as prevalent as it once was but it is something to be proud of. Hopefully it will come back strong someday. Thanks.
School is kicking my tail. This wood mechanics class is literally consuming all my available time outside of work so not much progress to report on the truck. But I was able to switch my shop lights to fluorescent and get my Boyd fuel tank temporarily hung in place. The new lights give me so much more visibility in my garage and the tank fits like a glove. Just need to drill my holes and mount it permanently. Both were great decisions. Plan to mount 2 more lights soon and epoxy the floor after I finish the body work. |
04-19-2011, 11:24 PM | #298 |
Lookin good brother. Keep up the good work, both on the school front and on the truck front! My daughter is in her freshman year at the University Of Washington so i know what you are going through, just keep your head down and push through it, the pay off will be well worth it. I work for my brother and we are non union and i feel that makes our company more of a family oriented outfit, we actually care what hapens to our employees and there families, i believe it keeps us honest as employers, im glad that you are involved with such a company.
04-20-2011, 06:19 PM | #299 |
6>8 Plugless........
Cool video. It's nice to see some companies are committed to staying in the US. Man the truck is coming a long nicely. Nice score on the NV4500 and NP205. That will make driving this truck much more enjoyable!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
04-20-2011, 09:14 PM | #300 |
Thanks for the support guys. School is tough but I guess all PhD programs are supposed to be. And I'm lucky to work for a great company like Mannington. But it stinks that I can't work on the truck more but I'll just have to when school allows. At least I'll keep up with your builds and stay motivated to not get too far behind.
