Old 03-06-2012, 11:12 PM   #276
Mattman2010
Mattman2010's Avatar
Re: 85 GMC Sierra Classic 1 Ton Crew Cab
4.10s
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 03-06-2012, 11:34 PM   #277
yjheep
Originally Posted by Mattman2010 View Post
4.10s
Good, youl be in good shape with the 4.10s and nv4500.
Personally I would go 2wheel drive trans into divorce 205. Gives you much better drive line angles. Also for the "just in case" I put mine in the center of the truck so my front and rear drive shafts are the same size. Ever blow a rear drive shaft or u joint out, just unbolt the front and stick it in the rear and head on down the highway. Not to mention the shaft length is manageable and does not require a carrier bearing, also a huge pluss in my book.
As far as the 12v. Go for it!! I'm doing one now
yjheep is offline   Reply With Quote
Old 03-06-2012, 11:37 PM   #278
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Nice! Mine was dubbed "The Boat".
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 03-07-2012, 09:19 AM   #279
Mattman2010
Yeah I think the 2wd trans is what I am going to do because I can find them for about $500 and it seems any of the other ones are $700+. I figured I could run the truck as a 2wd for a while til I find the transfercase. As for putting it in the middle that is a good idea. It would be nice to have the same size drive shafts but I am not sure that the yokes on my D44 and D70 are the same.
As for the 12v its happening, just gotta pay it off then go get it.
Build Thread
Build Thread
Thread
Old 03-07-2012, 09:53 AM   #280
yjheep
might be right on that dana 70 is proly 1350 44 is proly 1310. You can buy 1350 yokes for your 44, there around 100 bucks, I would double check your yokes obviously.
Old 03-07-2012, 10:11 AM   #281
Mattman2010
Yeah that will be something I will have to look at. If I can get a transmission I plan on just running it as 2wd because I need to get it in there for as cheap as possible and then find all the stuff to make it 4x4.
Build Thread
Build Thread
Thread
Old 03-07-2012, 11:07 AM   #282
yjheep
Exclamation Re: 85 GMC Sierra Classic 1 Ton Crew Cab
Roger that, drive line can get expensive quick. Got almost 3k in yokes and 3 custom built driveshafts
Old 03-07-2012, 11:12 AM   #283
Mattman2010
Yeah I don't have that kinda money so I'm trying to use as much of what I have to get it working. I'll probably have my rear driveshaft lengthened and the put a conversion ujoint in it to hook up to the nv4500. I'll have to buy steel to build mounts and buy some stuff for the motor. So I'm basically spending a lot and luckly I found a guy willing to work with me so I could make payments on the motor. But it seems like every time I talk to him I spend more money lol
Build Thread
Build Thread
Thread
Old 03-07-2012, 11:24 AM   #284
yjheep
Lol, my truck started as a budget build but I Realy don't know if there is such a thing.... As much as I try and keep it that way. I basically got my 64k mile 12v for free so that helped
Old 03-07-2012, 12:53 PM   #285
Mattman2010
Yeah I know what you mean. I have way more money in my truck than it looks. When I added it all up it was just rediculous. You can't beat free! Especially for a 12v, I'll have $2000 in my 12v by the time I get all the accessories I need to adapt it to a nv4500 and get it to work in my truck and including fuel to go pick it up lol.
Build Thread
Build Thread
Thread
Old 03-07-2012, 01:18 PM   #286
yjheep
I bought a 1995 ford, 55 passenger ford school bus from a school district for $2500 it had a new cummins installed in 2007 with documentation showing 64k miles. I drove the bus home, sold tires, wheels, all the seats, windows, rad and intercooler for $1300 and then I scrapped the rest for $1600, rofl.
Old 03-07-2012, 02:09 PM   #287
Mattman2010
Can't beat that! That's a heck of a deal.
Build Thread
Build Thread
Thread
Old 03-07-2012, 03:50 PM   #288
arrover
arrover's Avatar
Your plan sounds almost exactly like what I want to build. Although I have yet to buy a truck.... It's still in the wishing/planning/dreaming stage. I love your project!
I think I have read that the Rough Country springs are the roughest riding springs. You might want to research that though because I could be remembering wrong. Also, don't the shackle flips only raise the rear 4"? How will you make up the other two inches in the back? Just curious. Keep up the good work!
arrover is offline   Reply With Quote
Old 03-07-2012, 04:51 PM   #289
Mattman2010
Rough country springs are the only springs that I have heard of that will hold the weight of the cummins. As for the shackle flip I mounted the front rear doing mounts down 2 inches and so I'm going to get a 2 inch longer shackle which will make up for 6 inches.
Build Thread
Build Thread
Thread
Old 03-07-2012, 05:26 PM   #290
joe231
joe231's Avatar
How much does the cummins weigh?
The 52" or 56" rear springs should handle it...
CHEVY ONLY
Old 03-07-2012, 05:29 PM   #291
Mattman2010
Not really sure. More than a big block. 52 or 56 would support it. They will only give you 4 inches of lift tho.
Build Thread
Build Thread
Thread
Old 03-07-2012, 05:31 PM   #292
joe231
joe231's Avatar
Yeah,
But you would need to move the front mounts so you could build in an extra 2 inches and get longer shackles. It would ride better than lift springs.
CHEVY ONLY
Old 03-07-2012, 05:47 PM   #293
Mattman2010
Yeah I guess that could work. I have not really thought much into it.
Build Thread
Build Thread
Thread
Old 03-07-2012, 06:16 PM   #294
yjheep
My cummins tipped the scales at 1,162 lbs with oil and all acc.
Old 03-07-2012, 06:23 PM   #295
yjheep
Yeah,
I used lift springs but did build 1 3/4" taller hangers and 1 3/4" longer shackles to make up for the cummins Allison combo.
You can see on my build if you like, I don't like filling others threads with my pics
http://67-72chevytrucks.com/vboard/s...d.php?t=508477
Old 03-07-2012, 08:37 PM   #296
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
He's right on the money. 950 with no accessories, 1150 with automotive accessories, 1165 with fluids.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 03-07-2012, 10:28 PM   #297
Mattman2010
Yeah I might look into doing a 56 inch swap or something. I have an extra pair of 56 inch springs that would probably do great on the truck, and will give me a ton of flex which I am not sure if that would be good or not for a DD/Tow rig. But it would save me some money because the lift I was looking at was $700 and I already plan on buying steel for mounting the cummins that i could easily make new mounts for springs.
Build Thread
Build Thread
Thread
Old 03-08-2012, 12:12 AM   #298
joe231
joe231's Avatar
Just be sure to run a sway bar...
CHEVY ONLY
Old 03-08-2012, 12:21 AM   #299
yjheep
I'm no expert but in my experiences a sway bar does not work well in a lifted suspension Situations Especially in a cross over steering setup. But I have run pan hard bars with good results. I have heard of others experiencing some bump steer tho.
Old 03-08-2012, 12:53 AM   #300
joe231
joe231's Avatar
I'm no expert either, but im learning! Lol
Sway bar has little to do with steering, it's for body roll.
A pan hard doesn't help body roll either, it keeps the axle centered.
From what I understand a track bar and leaf springs fight each other.
High steer and a horizontal drag link is the best fix for bump steer.
CHEVY ONLY
