Old 11-29-2012, 03:28 PM   #276
Dan in Pasadena
Dan in Pasadena's Avatar
Re: 58 TRUK intro
Originally Posted by _Ogre View Post
....never did tell him it was going on a 58 chevy truck.
That would have blown his mind
His head would have exploded.
Fortunately, as there is nothing IN HIS head, you would have been unhurt!
Dan in Pasadena is offline   Reply With Quote
Old 11-29-2012, 04:02 PM   #277
xpickup
xpickup's Avatar
Re: 58 TRUK intro
_Ogre, did he ask you if it had AC or power windows, ect. That always makes me laugh when they ask all the questons that do not pertain to what you are buying. Or when you tell them what it goes on and it is not in the computer.
Shannon
xpickup is offline   Reply With Quote
Old 11-29-2012, 07:13 PM   #278
DransportGarage
DransportGarage's Avatar
Re: 58 TRUK intro
Ogre, you're the BOMB !!!!
Bob
"It won't take long and it won't cost much."
'55 3100 (383/700R4)--'55 Belair Sedan (350/4-speed)--'64 'Vette Conv. (327/4-speed)--'68 GTO Conv. (462/4-speed)--'69 Cutlass Conv. (350/TH350)--'06 'Vette Conv. (LS2/6-speed)
Bob's Retirement Build - My 55 TF
Bob's 700R4 Build (how-to)
DransportGarage is offline   Reply With Quote
Old 11-29-2012, 07:37 PM   #279
OKGMC4
OKGMC4's Avatar
Re: 58 TRUK intro
I haven't worked in a parts store in 10 years and I still have to school those guys from time to time. I've found they argue less when I pull up in the orange bomb. Guess it makes it look like I know what I'm talking about. I hate this the most..."It's not in the computer so it can't possibly exist. Catalog? What's that?"
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 11-29-2012, 09:36 PM   #280
OrrieG
OrrieG's Avatar
Re: 58 TRUK intro
My local O'Reilys has a bunch of older gearheads behind the counter and they know me so we usually dispense with the "what is it for" interigation. The greeting is usually "what are you trying to do now"! And they let me go behind the counter to recon on my own too.
OrrieG is offline   Reply With Quote
Old 11-29-2012, 09:59 PM   #281
DransportGarage
Re: 58 TRUK intro
Hoooooooo!!!! Hoooooooowl!!!!!! I've had a few sips of the soda pop tonight, but this is really a hoot!!! It is so true I can hardly stand it!
Bob
Old 11-30-2012, 03:31 PM   #282
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
i've used the same o'reilly's for years (absorbed murry's years ago).
they rotate counter people as often as i rotate tires.
it does help when i have truk in the front window, i can just say ''that''.
bob: step away from the keyboard, you've had to much pop tonight
shop air compressor timer
Old 01-06-2013, 09:00 PM   #283
ind59
Re: 58 TRUK intro
Wow this truck is soo sweet very nice build. The bed is different but looks real good loving the interior.Good job keep up the good work.
ind59 is offline   Reply With Quote
Old 01-06-2013, 09:13 PM   #284
ind59
Re: 58 TRUK intro
I agree 100% this is a very good pic of. This truck I love everything about this truck!!!!!
Old 01-06-2013, 09:19 PM   #285
ind59
Re: 58 TRUK intro
Originally Posted by drivea55 View Post
that's an awesome pic of truk!!!
This is what I was posting about
Old 01-07-2013, 08:56 PM   #286
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
thanks ind59, glad you like it
and thanks for the bump
Old 01-07-2013, 09:01 PM   #287
ind59
Re: 58 TRUK intro
No problem buddy I haven't seen a thing that I dont like about ur truck im new to this site.and posting so bare with me still gotta learn to post pictures. I just started on a 59 gmc about a month and half ago.
Old 01-09-2013, 05:41 PM   #288
DransportGarage
Re: 58 TRUK intro
Ogre, I made some wire looms (that get wires into the doors) that are similar to yours (but of course not quite as good as yours!). Can you give me some ideas as to how you made the plastic bushings in the fronts of the doors, and how you mounted them?
Thanks for all the ideas!
Bob
Old 01-09-2013, 07:04 PM   #289
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
i made a round hole in the door with plenty of clearance. for the bushing; i used some 1/4'' plastic that i cut a 3x3 square from, then drilled a 3/4 hole in it and filed it square and snug on my 3/4 square wire loom. it is stuck to the inside of my door with 3m double sided tape. that's it. post a pic when you have them done.
you should have pm'd me, i drew those up in autocad and could have sent you the drawings with measurements, using material from home depot.
Old 01-10-2013, 03:05 PM   #290
DransportGarage
Re: 58 TRUK intro
<snip> ...post a pic when you have them done.... <snip>
Since you wanted a photo I had to polish them. What a difference!
I also decided to make a floating gasket out of two squares of a plastic lid and two screws:
(Wow, that pic's a little fuzzy, but you get the idea.) The plastic that shows has through holes and the one inside the door grips the threads. I'll tighten the screws until the gap between the plastics is the same as the thickness of the door sheet metal. The square tube will hold the gasket square.
Home Depot had the square tube, but no 1/4" x 2" aluminum stock. Same at Lowes, Ace Hardware and Brandt's Hardware here in town. My buddy did, however, have a piece of 1/4" x 1-1/2" stock so I used that. That cut down the real estate for the screws so I had to use #6-32 flatheads, but it worked.
Bob
Old 01-11-2013, 02:07 AM   #291
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
those look vaguely familiar and very shiny
looks good, nice idea with the plastic.
not much room in between the door and the jamb on these trucks.
Old 01-11-2013, 10:16 AM   #292
Russell Ashley
Russell Ashley's Avatar
Re: 58 TRUK intro
That's funny. Not to hi-jack, but I went to a new Advance Auto parts store recently and there were two women working there. I asked for a foot of 1/4 inch gas hose, and got the typical "What kind of car is it for?". As she started to the keyboard I said it's for a 1987 Craftsman leaf vacuum. She hesitated for a minute but didn't want to appear dumb, so started trying to find it on the computer. She couldn't find it so finally said they didn't have it. I said yes you do because I see it, LOL. There was a rack with different sizes of hose right behind the counter that I guess she had never noticed.
Russell Ashley is offline   Reply With Quote
Old 01-11-2013, 01:48 PM   #293
DransportGarage
Re: 58 TRUK intro
I have a real problem when I read your stuff, Ogre -- it's hard to beat the ideas you have! My truck now looks like Son of Truk (except from the rear). And ya know, that's not all bad!
FWIW, my plastic gaskets are 2" x 2". The rectangular hole is just over 3/4" tall (just to fit over the tube) and 7/8" wide (to allow for the changing angle of entry of the square tube). The two screws are about as close to the interior corners as practical, about 3/16", on the diagonal line through the corners (not critical).
The hole in the door is 1-1/4" square. This compensates for the riding up and down of the tube when the door opens and closes (vertical), and to make room for the screws through the plastic (horizontal). (I recommend "sneaking up" on the final size by first fitting the square tube alone, then adding the plastic gasket.)
Also, I added a 1/8" long piece of electrical wire insulation on each screw (between the plastic parts) so the metal screw doesn't scratch the paint as it rides up and down.
Bob
Old 01-11-2013, 06:47 PM   #294
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
son of truk? sounds like a serial killer.
i actually wanted OGRE in a personalized tag, it was already taken by some sick individual. my 09 sierra has truk tag, i had to make this one 58 truk. truk makes a lot more sense if you spell it backwards
russell: i'd have made her look harder, maybe even had her call over an associate to help.
Old 01-20-2013, 11:10 PM   #295
4544speed
4544speed's Avatar
Smile Re: 58 TRUK intro
I could not make out the name on those brackets on the radiator cover. Were they made by Nortel?
4544speed is offline   Reply With Quote
Old 01-21-2013, 06:56 PM   #296
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
not sure what brackets your referring to 4544speed.
the radiator and fan shroud came from us radiator
the radiator cover is fiberglass from ogre manufacturing
the L-brackets are bent 10 ga steel
Old 01-21-2013, 08:13 PM   #297
4544speed
4544speed's Avatar
Re: 58 TRUK intro
I was giving you a hard time over the brackets because they look like some telephone equipment. I thought you might have been a retired telephone man. You would have known what I was talking about.
This is a great build thread and I really admire you fiberglass skills. I have an old vette and should invite you down to help out on that disaster.
You have done a tremendous amount of work to your truck.
Old 01-21-2013, 08:57 PM   #298
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
i googled nortel after i posted that reply and figured out you were giving me a hard time.
ogre needs a new project, bring by the vette if it's old enough (and the title)
thanks for the kudos, it's salt season up here now.
all i can do is look and keep the battery charged up for spring
Old 03-28-2013, 08:35 AM   #299
57picupnewbie
'57 Rosa
57picupnewbie's Avatar
Re: 58 TRUK intro
i chose the easy route...
sand blasted first, then started to hammer the louvers down and realized it was warping the cover.
i just used duraglass (short strand fiberglass filler) and smucked up both sides.
welded in the ends, seam sealed the top edge (windshield edge) and bottom edge.
finished with regular filler. not much to it, really.
when i had my cab blasted i asked the blaster to get inside the cowl and made sure primer covered everything inside.
plus i covered everything in there with undercoating from a can.
i've seen other builds where the louvers were cut out and metal welded in.
not sure which one is better, just telling you what i did and what my body/painter friend told me to do.
Ogre,
Do you have pictures of this step by step process of the smoothing of the cowl vent for us amatures...?
My '57 Truck Build "Rosa" (Current Project) http://67-72chevytrucks.com/vboard/s...21#post4118721
2003 Dodge Dakota 4X4 (Daily Driver)
Only two defining forces have ever died for us: CHRIST died for our salvation and VETERANS died for our freedoms. Glorify CHRIST and thank VETERANs
Dru~ USN Retired
57picupnewbie is offline   Reply With Quote
Old 03-28-2013, 11:28 PM   #300
_Ogre
_Ogre's Avatar
Re: 58 TRUK intro
as an amateur myself (working around pros), the text pretty much explains it.
blast, smuck, weld and sand.
you can see where the original screws still hold the cowl vent down
the only thing i can add is to screw the wiper bezels in to hold the panel tight to the cowl when you weld the sides.
as my post states "not much to it, really''
thanks for posting and resurrecting my build from page 9 oblivion
