Old 04-06-2017, 07:20 PM   #276
Shucks
Shucks's Avatar
Re: Shucks First Build
Shot some more color today
I really want a new one of these but I don't want the cheap plastic that it'll be so I polished mine out. Has it's fair share of dings but I think it'll work.
C H E V R O L E T
Check out my build thread!
Shucks First Build
Shucks is offline   Reply With Quote
Old 04-06-2017, 11:42 PM   #277
Cape Codder
Cape Codder's Avatar
Looks like you are still moving right along. As far as tailights if you are building a daily driver I would make sure to have 100% legal tail lights with reflectors. If someone hits you it is their fault, but if you don't have legal lighting they have an out. If you are parked with lights off and they hit you they have an excuse for not seeing you without the reflectors. As far as small round marker lamps Crysler products had some nice ones in the late 60's that would work.
http://www.ebay.com/itm/1968-68-dodg...-/371910359817
Cape Codder is offline   Reply With Quote
Old 04-07-2017, 12:12 AM   #278
Shucks
Shucks's Avatar
Those could definitely work, they'd be really close to fitting in one of those holes already in the bed.
C H E V R O L E T
Shucks First Build
Old 04-13-2017, 01:15 PM   #279
Shucks
Shucks's Avatar
So I went a wheel store today and found out every wheel I had in mind was backordered for months! They reccomended these Ridlers to me and I do like them. Lots cheaper than any wheel I was wanting and they look pretty decent. Going back up today to finalize the purchase of 255/45/r20 and 295/40/r20 Nitto G2 tires with 20x8 and 20x9.5 wheels.
I went with the center wheels, grey centers with the brushed chrome lip.
C H E V R O L E T
Shucks First Build
Old 04-17-2017, 07:00 PM   #280
Shucks
Shucks's Avatar
This guy had a great day!
C H E V R O L E T
Shucks First Build
Old 04-18-2017, 09:12 AM   #281
aggie91
I'm just glad to be here!
aggie91's Avatar
Looks good. This was a good choice in wheels for that blue.
What backspace did you end up with front and rear?
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 04-18-2017, 10:04 AM   #282
Shucks
Shucks's Avatar
Thanks!
20x8.5 with 4.75
20x10 with 5.5
C H E V R O L E T
Shucks First Build
Old 04-19-2017, 08:53 PM   #283
Shucks
Shucks's Avatar
Still not done with rust repair, don't know how I missed this on the bed.
Riveted the roll pan on
Bedsides sanded, scrapes and scars gone. Ready for primer after rust is fixed. Picking up a new front piece for the bed tomorrow. The PO actually used the bed for what it was intended for and it was pretty beat up.
Getting so close!
C H E V R O L E T
Shucks First Build
Old 04-19-2017, 09:25 PM   #284
Cape Codder
You are coming right along. If I can give a hint, take those nice new wheels and tires off until painted buffed and cleaned. Just wet sanding mud will be a pain to clean off of them. When you are ready to paint I would jack the truck up a foot and remove the front tires it will make painting the rockers and lower areas much easier. A 3 ft. ladder will let you reach the roof easy enough, or just stand on the frame behind the cab. I am assuming you are going to paint the cab and bed separately.
Old 04-19-2017, 09:29 PM   #285
Shucks
Shucks's Avatar
Sounds good! I just like seeing the new wheels. Should I paint the bed and cab separate? I was going to paint The back of the cab and front of the bed and then put it together and paint it at once.
C H E V R O L E T
Shucks First Build
Old 04-20-2017, 10:05 AM   #286
aggie91
aggie91's Avatar
I would paint them separate. Or at least have a space wide enough to work between the cab and the bed front panel. That way you can spray the entire truck at once and not have to worry with rough overspray on the front of the bed or the back of the cab.
Karl
The LST Challenge:
Old 04-20-2017, 10:32 AM   #287
Cape Codder
First complete paint would be easier by doing one half at a time. You will want to paint the rear fenders off the bed too as it is real tricky getting between fender top and bed rails.
Old 04-20-2017, 10:45 AM   #288
Shucks
Shucks's Avatar
Correct, I would paint the fenders and the tailgate off the bed. But sounds like I'll paint it in halves now. Thanks for the advice guys. Paint is coming soon! Just a few things to wrap up on the bed.
C H E V R O L E T
Shucks First Build
Old 04-20-2017, 12:26 PM   #289
Cape Codder
When painting a metallic color you can get away with painting parts that join at different angles without color match issues as long as it is coming from the same mix . It is when you paint two adjoining panels such as a door and fender that you can sometimes have a difference due to spraying conditions. It you look at any vehicle you will notice the top and side look lighter or darker from the way the light reflects.
Old 04-20-2017, 06:23 PM   #290
Shucks
Shucks's Avatar
Well I made a minor mistake mistake today. I went To shave my stake pockets and got one done then realized I need them open to assemble my latches... So I had to tear it all apart. Luckily I only did one. But I'll just leave them open. Super embarrassing.
Got a lot done though. Got some rail plates welded in, a new headboard, and fixed the rust on the side of the bed.
C H E V R O L E T
Shucks First Build
Old 04-24-2017, 05:23 PM   #291
Shucks
Shucks's Avatar
Just keep pickin at it
C H E V R O L E T
Shucks First Build
Old 04-25-2017, 09:37 AM   #292
aggie91
aggie91's Avatar
Keep at it.
One word of advise I have for you from the last pictures. The masking on the bed floor is all loose and this can cause you problems when you spray paint and clear. Its not too bad when doing primer and all, but the loose folds can trap dust and dry paint.
When you are shooting the color and clear, keep your masking tight and any seams or folds taped down. This keeps from having pockets that dry overspray can land and then get kicked back up when air passes over the area when spraying the next coat.
Karl
The LST Challenge:
Old 04-25-2017, 09:53 AM   #293
Shucks
Shucks's Avatar
Keep at it.
Very very true. Considering the fact I need to minimize as much dust as possible in the environment I have that's a good point...
C H E V R O L E T
Shucks First Build
Old 04-25-2017, 03:53 PM   #294
LT7A
This is the best thread I've seen about the painting process. A lot of practical advice coming from guys with experience and a guy willing to learn and not being offended by being given advice. I've learned a bunch. Thanks!
Truck is coming together nicely and will be very cool to drive. You have good endurance and it is going to pay off.
Old 04-25-2017, 04:06 PM   #295
Shucks
Shucks's Avatar
I wouldn't have made progress like this if it wasn't for this forum. The guys here are very knowledgeable and helpful and I'm glad they give the advice I get. Glad someone else is learning as much as I am through this!
C H E V R O L E T
Shucks First Build
Old 05-12-2017, 06:35 PM   #296
Shucks
Shucks's Avatar
I'm becoming very pleased with how my body work is turning out. I'm wet sanding all my primer, seal some areas and my deadline is the 21st to begin painting.
Old 05-12-2017, 08:27 PM   #297
Cape Codder
Are you sealing now? If so you will need to sand that too. I usually spray sealer an hr. before color and so need to sand.
Old 05-12-2017, 08:35 PM   #298
Shucks
Shucks's Avatar
No, sealing the same day as color
Old 05-12-2017, 08:43 PM   #299
Cape Codder
The most important thing is to just follow the directions on the product. Some vary but painting is no place for home chemistry. They do sometimes list spray pressures low to pass VOC laws.
Old 05-18-2017, 09:38 PM   #300
Shucks
Shucks's Avatar
One more picture before it gets painted. Test fit to Make sure the bed and fenders fit between the new tires and wheels. My body work and sanding job is done, finally! I have everything ready to go, so after work the next couple days I will shoot the truck on Sunday. Next time you see it it'll be blue!
