Old 03-22-2020, 01:04 PM   #276
mdelosrey
Re: 1972 SWB Build
Thanks for sharing the pictures. Was there not enough room between the block and manifolds to comfortably run them inboard? Would love to see more pictures of the rest of the exhaust routing. If you could take pictures during the exhaust build and note any issues I would really appreciate it.
Take care of yourself and thanks for sharing.
mdelosrey is offline   Reply With Quote
Old 03-22-2020, 01:12 PM   #277
beaterku
beaterku's Avatar
Re: 1972 SWB Build
There wasn't It was really tight so I went around. Not ideal, but it works.
Here is my post on the exhaust. I was, and still am not, happy with the magnaflow exhaust. I just don't like how it fits. I haven't messed with it since I put it on. I'd be interested in trying the hooker blackheart kit, or going the full custom route. http://67-72chevytrucks.com/vboard/s...&postcount=240
beaterku is offline   Reply With Quote
Old 03-27-2020, 11:54 AM   #278
beaterku
beaterku's Avatar
Re: 1972 SWB Build
So I started tinkering with the cruise control last night. My PSI harness manual had a diagram in it that was similar to one I found on here courtesy of Ackattack (http://67-72chevytrucks.com/vboard/s...d.php?t=398006). Looking at the diagram, I was having a hard time wrapping my head around how this works. So I set up my "test bench" and with a bunch of jumpers, a 9V battery, my Rosta stalk and my volt meter and made it happen.
Once I started probing around, it all made sense. Since the Rosta stalk outputs a constant 12V on the set/coast line, and pressing the set/coast button interrupts 12V, it all started making sense. This configuration uses this as the trigger for both relays to get the desired outputs. Pretty trick. Since I am using a Dakota Digital dash, I added another relay to get a ground signal for the DD controller so it will show the cruise light on the dash.
I drew this relay layout last night to hopefully help others. I am going to do an in depth post and video on how to hook all of this up soon.
Old 03-27-2020, 10:03 PM   #279
TA_C10
TA_C10's Avatar
Re: 1972 SWB Build
Nice, that is a much better diagram than the one I mapped out on my notebook Unfortunately the guy who did my column, didn't map the wires for my 4 wire handle he installed so I will be doing the same thing to verify which color is what.
Thanks for this work beater. Anxious for the video.
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444
"It's only money".
TA_C10 is offline   Reply With Quote
Old 04-28-2020, 01:25 PM   #280
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Well, cruise control is installed! Took it out for a short drive yesterday to test it all out. I tried to video as much as I could, but it was hard in tight quarters. I still have to do a little tidying with the wiring and get a proper ring terminal for the ground, but it works! Truck is going in tomorrow to get the exhaust reworked and taken out the back. These dumps are just too loud for my tastes.
Old 04-30-2020, 11:51 AM   #281
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Dropped the old girl off to have the exhaust finished out. I am not a patient enough welder, so I took it to the professionals. Looking forward to not having the booming in the cab at idle. The exhaust waves get stuck under the truck and booms. Tested out the cruise on the highway, and it works like a champ. It's the little things in life!
Old 04-30-2020, 12:19 PM   #282
MDPotter
MDPotter's Avatar
Re: 1972 SWB Build
Let us know what the new setup is!
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 04-30-2020, 05:01 PM   #283
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Threading the needle. I went down at lunch. We were trying to determine where to have the exhaust exit. 90° behind the head wheel, 45° behind the rear wheel or straight out with a slight slash tip tucked behind/below the bumper/. Straight out seem to look the best with everything that was going on and not getting to crazy on the bends and welding. He's hopeful to have it done tomorrow.
Old 04-30-2020, 05:28 PM   #284
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: 1972 SWB Build
Going to be nice! Can't wait to hear it
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 05-01-2020, 11:25 AM   #285
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Me too. I am excited to hear it.
The shop sent some pictures last night. Nice and tucked.
Old 05-02-2020, 06:32 PM   #286
cornerstone
cornerstone's Avatar
Re: 1972 SWB Build
I think that is the perfect placement for the tips! Looks awesome. I hope she quiets down enough for you now.
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
cornerstone is offline   Reply With Quote
Old 05-03-2020, 02:59 PM   #287
beaterku
beaterku's Avatar
Re: 1972 SWB Build
I am anxious to see it in person. Part of the problem is the cab has no carpet on the back wall and no headliner. It's a bit of a steel trap in there. I do have dynomat strips on the back wall. I may put some carpet back there too. Another project.
Old 06-15-2020, 03:15 PM   #288
TA_C10
TA_C10's Avatar
Re: 1972 SWB Build
I recommend closed cell foam insulation everywhere ALONG with the butyl mats like dynomat. It really completes the sound deadening process. Then carpet on top of that.
Back wall and firewall for all of these products.
I used this stuff, sticks well.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
"It's only money".
Old 06-16-2020, 09:41 AM   #289
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Good info! Thanks!
Old 11-22-2020, 12:54 AM   #290
Nitro72
Nitro72's Avatar
Re: 1972 SWB Build
Looking really good.
72 C20 Cheyenne Super Custom Camper. 402 bb, 400th, in a million pieces! Swapping to 6.0, 4l80, C10 short bed.
Nitro72 is offline   Reply With Quote
Old 11-22-2020, 11:16 PM   #291
beaterku
beaterku's Avatar
Re: 1972 SWB Build
Thank you!
