08-15-2008, 04:44 PM | #301 | |
Re: 68 K-10 SWB build thread - project Money Pit...pics galore!
There are a few guys that have done this floor... Tri-pro automotive's project GPW (also found in jaros44sr "po has me po'd build halfway through it)
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
08-15-2008, 04:50 PM | #302 | |
I'll either drop the crossmembers off at the sand blaster with the cab or clean them up with a wire wheel and then use etching primer on all of it.... ok, banding needs to come off...thanks
08-15-2008, 08:35 PM | #303 | |
C10 addict
Build is lookin good! |
08-15-2008, 08:40 PM | #304 |
did it have the squigly lumps under the center of the seat? I guess some didn't, not sure what it's for though...
08-17-2008, 09:55 PM | #305 |
Decided to take a break on Saturday and hit NYC with the wife, dad and one brother (they came in town from Indy)....
Yankees pulled it out in 13 friggin innings! They stop selling $10 beers after the 7th thankfully!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 08-17-2008 at 10:04 PM. |
08-17-2008, 09:57 PM | #306 |
the pic of the city looks cool. bet that was a lonnnng game
08-17-2008, 10:00 PM | #307 |
Then got back out in the garage for a few hours today.
Rest of the floor is out except the firewall portion and the rear area. I'm gonna make an appointment with the media blaster...and finish those areas up this week. i did notice that my high hump floor has a center brace that the replacement 2WD floor doesn't. Guess i'll pull it off and clean it up as well. Gotta love rust! Do you think I should go with Coal slag media (the blaster does indutrial trailers and already did my axles, springs etc..) I would have him avoid the large sheetmetal areas like the roof and back wall. Probably run $200 I bet. Or should I go with a local guy that does bodywork and uses Garnet? He charges $90/hour and will probably cost me $300+.
08-17-2008, 10:01 PM | #308 |
Should I epoxy primer it or etch primer it after blasting?
08-18-2008, 08:25 AM | #309 |
nice work MS, I had been wondering why the build had slacked off.
Eric |
08-18-2008, 10:41 AM | #310 | |
Thanks, Uncle Sam said that I needed to go to school for 6 months over the winter, then I really didn't feel like messing with it when I got back home. Now I have cleaned out some of my storage parts and picked up replacement parts so i'm back on stride. Oh yeah, mama gave me a few bucks to get things rolling again...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 08-18-2008 at 10:42 AM. |
08-20-2008, 10:37 AM | #311 |
Since i'm working nights for the next two weeks I should have a little free time in the morning to work on the cab. Decided to get the remaining sheetmetal off the firewall/floor seem this morning. Drilled out the spotwelds and one shot with the air chisel knocked it all off. Cleaned it all up with a wirewheel. Then I cut out the bad area of the firewall so the blaster won't have to mess with it.
Also removed the cross support that the new floor doesn't come with.
08-20-2008, 10:38 AM | #312 |
Oh yeah, got in a little fight with the coarse wire wheel... I think he won this round but i'll be back to fight another day....
Nothing like 10,000 RPM's coming to a stop on your chest! Only a few scratches on me, no worries...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 08-20-2008 at 10:39 AM. |
08-20-2008, 12:10 PM | #313 | |
Are you making a patch panel for the firewall? Wierd your floorboard didn't come with crossbrace You can take some of the spotwelds off of the diagonal brace going up the firewall(there's about 10 - 15, but count them to be sure) If you have two drills. you can start the hole with a normal drill then switch over to a drill that you have ground the point off. Work from the horizontal brace side, since you will be throwing that away. Eventually you will have to remove the diagonal brace as well, since you won't be able to get the floorboard under it. Nice work so far
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 08-20-2008 at 12:20 PM. |
08-20-2008, 12:57 PM | #314 | |
Must have been the rock hard foundation under my shirt that stopped the grinder! Army Strong, that's what the commercials say... So the large vertical brace will need to come all the way off then? I figured that sine my cab corners and B pillars are off I could slide the front in place first then the rear...I will bend some steel once the floor is in to fill in the firewall hole.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 08-20-2008 at 12:58 PM. |
08-20-2008, 01:18 PM | #315 | |
Junior Member
I was able to slide the new floor into place under the braces. It's tight but it fits. One thing to look out for; if you look at the firewall edge that you cleaned up, you'll see that it's not perfectly straight across. Under the braces the edge has some bumps in them. I had to trim the floor a little to match the bumps, otherwise the floor doesn't fit flush against the firewall. Man, you almost caught up to me!
1971 Short Stepside,(sold) 2011 Caprice PPV 1950 Chevy Fleetline Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=302759 |
08-20-2008, 02:17 PM | #316 | |
Try your method first, I didnt have the rear of the cab off as you do. Might work
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
08-20-2008, 04:49 PM | #317 | |
I noticed that bump that you are talking about. The Driver side rot went into that area so I trimmed it out too!... This build will more than likely stall after this week while I wait for the sandblaster to do his thing. Hopefully he will have it done by labor day...
08-24-2008, 02:33 PM | #318 |
Got the remaining portion of the floor out now. Off to the blasters tomorrow... probably won't see if before Labor day. I'm gonna have them coat it with a basic shop primer. I was going to do Etch or Epoxy but have been told that it will depend on my final paint as to which primer to coat it with. What are your guys thoughts? Place wants $150 to do it in Epoxy....
I cleaned off some paint to find the spot welds, drilled them out and she spilt right apart. Also added a piece of angle iron to keep the main two braces connected for transport...
08-24-2008, 05:06 PM | #319 |
Got the cab loaded on the trailer this afternoon.....
Here's the old floor... and a shot of the rad support temporarily in place to hold the rad. As you can see I couldn't find my upper red holddowns... had to start her up for the neighbors that came over....
08-24-2008, 09:50 PM | #320 |
Under Construction
looking good Mike.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
08-24-2008, 09:54 PM | #321 |
thanks...
08-25-2008, 08:17 AM | #322 |
looking GREAT ms, keep it up.
Eric |
08-25-2008, 09:00 AM | #323 |
Damn Yankee
grab a sawzall and go nuts.....
08-25-2008, 09:04 AM | #324 |
isn't that what I already did?
The floor actually comes out very easily, hopefully the new one goes in as easy.... I have a number to customer support in NJ if it doesn't!
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 08-25-2008 at 09:05 AM. |
08-25-2008, 09:21 AM | #325 |
Damn Yankee
non habla english...the sawzall comment was for Jim's benefit. He had an ambitious "Technical Advisor" here earlier in the year making him crazy
