Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 02-11-2010, 12:00 PM   #301
sdailey
The Few, The Proud
sdailey's Avatar
Re: Project - '69 4x4 named "Patches"
Originally Posted by my67chevytruck View Post
Shannon, does he rebuild tilts on the side?
Heath he may. I didn't ask him directly about that. I looked at his past feedback and auctions, before buying my tilt and saw that he has sold a few auto and floor shift tilts in past auctions. All of the feedback about the tilts he sold was good. He may rebuild one for you if you ask him.
PM sent.
Shannon
sdailey is offline   Reply With Quote
Old 02-11-2010, 03:46 PM   #302
msgross
msgross's Avatar
Ebay username?
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-11-2010, 04:26 PM   #303
sdailey
The Few, The Proud
sdailey's Avatar
Mike his username is "57dgd".
Shannon
Old 02-11-2010, 09:07 PM   #304
msgross
msgross's Avatar
nice tilt... thanks
The Garage:
Old 02-11-2010, 10:27 PM   #305
sdailey
The Few, The Proud
sdailey's Avatar
Thanks Mike.
Shannon
Old 02-17-2010, 12:09 PM   #306
my67chevytruck
Under Construction
my67chevytruck's Avatar
slacker !
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 02-17-2010, 12:12 PM   #307
sdailey
The Few, The Proud
sdailey's Avatar
slacker !
I'm just waiting for some warmer weather.
Did you by any chance contact the guy about rebuilding your column?
Shannon
Old 02-17-2010, 12:15 PM   #308
my67chevytruck
Under Construction
I sent him an email yesterday, i'll let you know what he says.
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 02-17-2010, 12:36 PM   #309
sdailey
The Few, The Proud
sdailey's Avatar
Slacker.
Shannon
Old 02-17-2010, 02:16 PM   #310
wancosc356
I Like Mine With No Shine!
wancosc356's Avatar
I sent him an email a while ago about rebuilding mine and he said that he is super busy with work and that he does them on the side. And he is backed up about 4 months on the ones he has to do. He said to contact him at a later date and he might be free.
Michael
1967 Chevrolet C10 Short Fleet (Literal Ground Up....One Day)
2006 GMC Sierra Crew Cab 4x4
1969 Lincoln Continental Coupe Project FOR SALE
http://67-72chevytrucks.com/vboard/c...ct=4578&cat=17
1981 Honda CM400 C Bobber SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=384152
wancosc356 is offline   Reply With Quote
Old 02-17-2010, 04:05 PM   #311
sdailey
The Few, The Proud
sdailey's Avatar
Did he give an estimate of what he would charge?
Shannon
Old 02-17-2010, 04:12 PM   #312
wancosc356
wancosc356's Avatar
No. He sure didn't.
Michael
Old 02-23-2010, 09:37 PM   #313
sdailey
The Few, The Proud
sdailey's Avatar
Small update....
If you've read through my build you'll remember that I had some issues with my aftermarket fuel tank. Well, I finally rounded up the necessary material to fix the issues.
The drawing I submitted to the shop had a side fill filler neck that was supposed to be double mitered for easy filling, but this is what I got instead. Can you imagine trying to fill through this at the gas pump?
The next issue was the vent tube. It was supposed to point to the side just like the filler neck.
I cut and welded up a piece of tubing with double miters to help with filling the tank.
Here I test fit the new fill neck compared to the old one. Notice that the old one doesn't even clear the top of the frame rail.
Next I cut off the old fill neck and vent tube and cleaned up the welds.
Here is the final result...a fill neck that should allow fuel to flow freely into the tank. I welded in a pipe coupling to use for the vent line. I'll screw in a 90* barb fitting to connect to the vent line.
It's not amazing progress, but at least it's checked off the list of things to do now.
Shannon
Old 02-23-2010, 09:50 PM   #314
my67chevytruck
Under Construction
showoff
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 02-23-2010, 09:57 PM   #315
msgross
msgross's Avatar
nice welds...
The Garage:
Old 02-23-2010, 10:31 PM   #316
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Nice work Shannon.
Alan's Classic is offline   Reply With Quote
Old 02-23-2010, 10:42 PM   #317
sdailey
The Few, The Proud
sdailey's Avatar
showoff
You know it.
Originally Posted by msgross View Post
nice welds...
Thanks Mike. I've done better. I was in a hurry today trying to finish it before I left work.
Originally Posted by Alan's Classic View Post
Nice work Shannon.
Thanks Alan.
Shannon
Old 03-09-2010, 05:07 PM   #318
sdailey
The Few, The Proud
sdailey's Avatar
Well here's the latest progress.......
We got my cab, cowl, and hood loaded up and dropped it off at the blaster this past Saturday. I should be able to pick it up this coming weekend if all goes well.
Last week Alan and I fished the brake lines through the frame trying to get them mocked up. Everything lines up pretty well for the most part. The only area that's confusing is where they all tie together on the driver's side frame rail. I've searched the board for pictures of the correct routing and found some good detailed build pictures that should help me get mine figured out.
Also, I found a truck on the board that looks like what I had envisioned mine looking like when it's complete. It belongs to NYC-10 and I hope he doesn't mind me using his picture.
This truck has pretty much the same specs as mine.
4" lift
33 x 12.50's
Meduim Olive/White paint
The only difference between the two is I'll be running a 71-2 front end and I haven't fully decided if I'm running any trim or not.
So now I have an almost exact replica to look up to to help me stay focused on my build.
Stay tuned bodywork should commence here shortly.
Shannon
Old 03-09-2010, 05:14 PM   #319
my67chevytruck
Under Construction
looking forward to the progress....
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 03-09-2010, 09:13 PM   #320
Alan's Classic
We hope it looks that good after I (we) get done painting it .
Old 03-09-2010, 09:15 PM   #321
my67chevytruck
Under Construction
yeah yeah, who the heck you kidding Alan, you know it will look kick @$$!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 03-09-2010, 09:40 PM   #322
Alan's Classic
Thanks Heath, my job right now is keeping Shannon motivated during the repair process.
Old 03-09-2010, 09:49 PM   #323
my67chevytruck
Under Construction
You have my SYMPATHY!
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 03-09-2010, 10:00 PM   #324
sdailey
The Few, The Proud
sdailey's Avatar
Don't be too modest Alan. Everyone knows by now that you have some mad skills.
Don't forget we have proof of your talent.
After shooting those bright colors a little green and white should be a piece of cake.
Shannon
Old 03-09-2010, 10:28 PM   #325
sdailey
The Few, The Proud
sdailey's Avatar
Good luck. Hopefully having some nicer weather will break me out of this funk.
Wait...what. Hey, I'm trying.
I almost forgot to post a picture of the latest part that I recently acquired for the truck.
Radio delete plate
I'll eventually mount an aftermarket radio in the glovebox one day.
Shannon
