Old 05-24-2011, 02:27 PM   #301
Kim57
Kim57's Avatar
Re: My 57 Pro Street
Now the fun starts.
I made some tabs to hold things in position.
I had to make a bunch of relief cuts so I could bend the lower section back to meet the upper section.
Started with 4" between them and worked down to 1" at the corners.
Kim57 is offline   Reply With Quote
Old 05-24-2011, 02:32 PM   #302
Kim57
Kim57's Avatar
I started tacking in the center and worked my way around to each side.
When I got to the corners I had to trim the tops to fit.
I got the gradual transition I was looking for.
Well I ran out of welding gas so I will have to leave the rest for another day.
Hope this was informative.
Kim
Old 05-24-2011, 03:09 PM   #303
Kabwe
Certified Car Nut
Kabwe's Avatar
Looking good Kim, looking really good. I welcome you to the club and I will be sending out your membership.lol
Kabwe is offline   Reply With Quote
Old 05-24-2011, 03:37 PM   #304
GeorgeVale
Looks like will turn out spot on. I like the tab Idea to keep things in place. I am so tempted to have ago at doing mine but I do not think I am skilled enough for it. I think moving the cut up was right the gradual transition is important.
GeorgeVale is offline   Reply With Quote
Old 05-24-2011, 03:45 PM   #305
Kim57
Kim57's Avatar
Well you are the President of the club so I expect my card ASAP.
Kim
Old 05-24-2011, 03:47 PM   #306
Kim57
Kim57's Avatar
Thanks George.
I don't have the skills for this stuff either but I figured I had nothing to lose in trying it.
Just take your time and measure, measure, measure.
Kim
Old 05-24-2011, 06:22 PM   #307
57HotTruck
57HotTruck's Avatar
It looks super good , it's definitely a modification I will do on my truck. thanks for all the good photos.
57HotTruck is offline   Reply With Quote
Old 05-24-2011, 08:13 PM   #308
oldman3
oldman3's Avatar
Kim, very informative post, with lots of good pics. You did a great job with the initial cuts, relieve cuts, and all tacked together the lines look just right from each angle you showed. One very nice job.....Jim
oldman3 is offline   Reply With Quote
Old 05-24-2011, 08:43 PM   #309
hotrod1
56 - autocross
hotrod1's Avatar
Great job. Cant wait to see the thing finished especially the underside and the bracing.
hotrod1 is offline   Reply With Quote
Old 05-24-2011, 08:47 PM   #310
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Greta work! I hope to join the club one day too!
ChuckDriver is offline   Reply With Quote
Old 05-24-2011, 09:10 PM   #311
Kabwe
Certified Car Nut
Kabwe's Avatar
Kim
I will give it to you at the next Brothers Truck Show.
You are an honorary member already for contributing a really nice build thread to the site that others can learn from and get motivation. Anybody that strays from the norm gets my vote. Your dash makes you a full member my friend.lol
Like Kim57 said, I'm the president and my motto is "let's see what we can cut up next".lol
Old 05-25-2011, 12:53 AM   #312
Kim57
Kim57's Avatar
Thanks for the encouragement guys I do appreciate it.
hotrod1 when I get it all welded up I'm going to build my own tilt mechanism for it and will post pics on how I do it.
Kabwe I'm looking forward to the Brothers show.
Kim
Old 05-27-2011, 12:41 AM   #313
drivea55
drivea55's Avatar
Kim,
Very glad to see you take the leap!
GREAT JOB!!!
current project;
1950 GMC "Junk Yard Dawg"
http://67-72chevytrucks.com/vboard/s...d.php?t=635960
___________________________________________
SOLD to "ONEBADFIVEFIVE"
http://67-72chevytrucks.com/vboard/s...d.php?t=436406
drivea55 is offline   Reply With Quote
Old 05-27-2011, 07:16 PM   #314
Kim57
Kim57's Avatar
Originally Posted by drivea55 View Post
Kim,
GREAT JOB!!!
Thanks.
I think it was a change that needed to be done.
Kim
Old 05-27-2011, 07:21 PM   #315
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Talking Re: My 57 Pro Street
Looking good Kim!
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 06-30-2011, 04:52 PM   #316
Kim57
Kim57's Avatar
I made a little progress on the hood.
I had to modify the front cross brace to fit. I notched it on each end so it could be bent out to line up with the new position after pancaking the hood.
Kim
Old 06-30-2011, 04:55 PM   #317
Kim57
Kim57's Avatar
The front center brace also had to be done. It was rather easy as all I had to do was re-drill the mounting holes and shorten it by 1".
Kim
Old 06-30-2011, 05:00 PM   #318
Kim57
Kim57's Avatar
Now on with the bracing for the tilt. I really don't like the sharp lines of the kits being sold so I decided to do mine a little different. I used 1" square tube for the cross braces and 3/4" round for the front to back bracing. Right now there is about $40 invested in it. The biggest expense so far is the tabs on the ends of all the braces. I could have saved some money by making my own.
Kim
Old 06-30-2011, 05:05 PM   #319
Kim57
Kim57's Avatar
A few more pics of the bracing.
That's it for now. Next up will be the pieces for the tilt. I'm still debating if I will use spherical rod ends or not for that. They get kinda expensive and I'm trying to do this without spending a ton of money on it.
Kim
Old 06-30-2011, 05:47 PM   #320
Kabwe
Certified Car Nut
Kabwe's Avatar
looking good my friend, looking really good.
Old 06-30-2011, 07:05 PM   #321
oldman3
oldman3's Avatar
Kim, did you drill holes in the square tubing and insert the round and weld, or is it welded flush to the tubing? Looks really good.....Jim
Old 06-30-2011, 09:35 PM   #322
ChuckDriver
Nice work! I can't wait to see it done!
Old 06-30-2011, 10:00 PM   #323
Kim57
Kim57's Avatar
I did drill holes for the tubes to fit into. I figured it would give a little more support that way.
Kim
Old 07-01-2011, 12:25 AM   #324
Rods57
Rods57's Avatar
Kim, your bed is freakin awesome! When I saw that i swear I heard Bam in my head saying 'what can I cut up next"
Rods57 is offline   Reply With Quote
Old 07-01-2011, 01:33 AM   #325
Dinos63
chevy only
Dinos63's Avatar
checked out the whole thread wow great job killer skills dig the truck!!
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
