#301 |
VA72C10
![]() Join Date: Mar 2008
Re: 1970 VA Longbed Project
I'm going to grind everything down smooth tomorrow and work on the front crossmember. Also going to start the engine cleanup. Keep having family activities getting in the way of working on the truck
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#302 |
![]() Join Date: Nov 2008
everything is coming together! i think i'll need to replace my driver side rocker. was it kind of a pain to do? did you do it with your door in place?
69' 1/2 ton LONGBED__ _______ |__\__ |__(O)______(O)] ![]() My build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=354115 |
#303 |
Now what??
Progress is progress! Good luck with the job and hope it works out for you and your family!
69 Long Fleet - Project 06 Ram 1ton Cummins 4x4-DD 01 Tahoe- wifes "The quality of a persons life is in direct proportion to their commitment to excellence, regardless of their chosen field of endeavor." ~ Vince Lombardi "A dream doesn't become reality through magic, it takes sweat, determination and hard work." ~ Colin Powell my, um, build ![]() ![]() ![]() |
#304 | |
VA72C10
Thanks. I should know in a day or so.
#305 |
how have your interviews gone?
#306 |
VA72C10
Well, I was planning on a longer day today but had other things come up. I got about two and a half hours in this afternoon. However, I picked up a good set of control arms that just need a little more attention and they will be good to go. Got three of the four stripped down clean and will do the last one tomorrow.
Also spent a few minutes cleaning up the inside of the crossmember. Got it looking good. Drilled the holes for the upper bag brackets in it and then wiped it down to prep for paint. Wiped down the control arms and bag brackets also so I'll shoot those first thing tomorrow when I go over to the garage. Started grinding on the cab where the rockers and cab mounts were installed to clean those up. Stopped to ask Jason how far he wanted me to take them until final body work. Just did part of one side..will tackle the rest of that later. Hope he's going to get the last cab mount in tonight. Then I'll be able to prep, prime, and undercoat the cab. Also started grinding on the block. Got most of the old paint off and started grinding all of the slag off of it. Got some parts nice and smooth. Will work on that more tomorrow as well. Left the camera in the garage so no pictures until tomorrow ![]()
#307 |
VA72C10
Thanks for asking. Here's a link where I'm discussing that
http://67-72chevytrucks.com/vboard/s...d.php?t=364926
#308 |
CCTek
Great progress. Keep your head up. Talented hard workers will always be able to find work. Now get back out there and work on that truck!
Chad 68 swb Project http://67-72chevytrucks.com/vboard/s...d.php?t=262840 72 swb Project SOLD http://67-72chevytrucks.com/vboard/s...=1#post3993641 THANKS TO: Hermance Design (www.hermancedesign.com), Paradise Road Rod & Custom, Harry Opfer Welding, Tri-State Machine, Wegner Automotive Research, Nsane Hotrodz (www.nsanehotrodz.com), Clayton Machine Works, CCTek (http://www.candctek.com) |
#309 |
Restoration Virgin!
Must have pictures!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#310 |
VA72C10
'm going to work on the truck for a few hours right now....pictures to follow soon
#311 |
VA72C10
Got a decent amount done but still have a long way to go...keep on having interruptions. But got around 4 hours in today. Here are a few pictures and I will post more later.
Got some A-arms from camtoys1 (mike) that he's chemically stripped. Still had a little undercoating on them but really saved me a lot of time. ![]() Before and after ![]() Closeup of a cleaned upper arm ![]() Cleaned up lower A-arm...still have to take the bumpstop bracket off... ![]()
#312 |
VA72C10
Before and after on the lowers
![]() Tools used to remove the bumpstop bracket. Drilled out the spot welds then used the air chisel to pry it off. ![]() Off ![]()
#313 |
VA72C10
Got the steering linkage apart with a little persuasion...
#314 |
VA72C10
Started priming
![]() More priming ![]() More ![]() Crossmember closeup-holes drilled for the upper bag plates before paint ![]() Painted ![]() Upper a-arm ![]() Extreme closeup.... ![]() Note: I put one more coat on after this...you can see it is thin on the bottom of the picture.
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 10-08-2009 at 10:59 PM. |
#315 |
VA72C10
Started cleaning/grinding the engine down. Want to make it nice and smooth because I will be painting it to match the truck.
The numbers on the block really showed up well after wire wheeling all the old paint off. ![]() Started here but you can see some of the slag/rough areas on the block around the oil filter ![]() Smoothed out...going to do a little more before paint. ![]() Should have taken more before and afters... ![]() This corner was very rough before ![]() Got the intake off...looks clean in there and I plan to keep it that way... ![]() ![]() Will do a little more grinding on the block later. Didn't want to do it today with all the freshly painted parts laying around the shop floor.
#316 |
Now what??
Looking good!
#317 |
Restoration Virgin!
Ahhhh...pictures of progress.....
#318 |
Under Construction
looking good!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#319 |
those control arms look better than new!
#320 |
VA72C10
Thanks!
I knew you needed your "fix" ![]() Thank you. Trying to catch up to you ![]() Thanks, it took long enough...even with all the prep done it was still about 4 hours between taking off the brackets, grinding them, prepping, priming, and painting.
#321 |
VA72C10
NO PICTURES!
![]() However, I picked up a 5 lug rear with 373 gears, and freshened up with new seals/bearings from mike (camtoys1) The best part of the rear are the glock's brackets with CROSS-drilled rotors and nice big calipers. ![]() Going to have 4 wheel cross drilled discs!!!!
#322 |
So are you going five lug now
70 SWB STEPSIDE 70 BLAZER 09 challenger |
#323 |
VA72C10
Yep, either doing coys C5, Torque thrust, Foose nitrous 2, or the new design Boss 338's....whatever I find the best deal on
![]() Going to sell the billet wheels to help finance the final details of the project. Doesn't make sense to have a $4K set of billet wheels and skimp on the paint and interior.
#324 |
VA72C10
Not sure if I mentioned this or not, but I paid for a Brother's one piece window setup from Budnikguy the other day...should be shipping my way next week.
![]() Got a lot of nice parts coming together!!! I'm getting excited!
#325 |
VA72C10
Guys, I am grinning ear to ear and almost laughing I'm so happy with today's progress. And I didn't get a lot of time due to family commitments...but still got a lot done....pictures to follow...here's what I started with...
![]() ![]() And guess why Jason added this dormer in the roof of his shop???? ![]()
