Old 06-19-2011, 12:39 AM   #301
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: Finally starting my Longhorn 4x4 conversion
awesome!
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 06-19-2011, 12:49 AM   #302
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
We got the front of the cab primed and poof canned last night. We also got the new body bushings installed and the cab is bolted down. Hopefully tomorrow there is more news to this story to add.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 07-05-2011, 09:09 PM   #303
Dieselwrencher
Here we go again. 2-3 weeks went by but there was progress. It didn't make Good guys because other projects ate up time, parts didn't show up, or the money tree went dry. You all know the drill. I'll lay out the pics as I can and give some details about what was done.
Ryan
Old 07-05-2011, 09:23 PM   #304
Dieselwrencher
We placed one of my aluminum fuel cells in the frame and got it in position. Placed jack stands under it and cut some angle iron to mount it to. The fuel cell had aluminum angles already welded to it for mounting purposes and I decided to keep it mounted that way. The fuel filler will be on the RH box side when done. The weirdest deal about this is, there were 4 bolt holes in the frame to mount the angle iron too. Kind of crazy if you ask me.
We also made a rectangle tubing cross member for in front of the fuel tank to give the frame more strength in the shackle portion of the frame since we moved the cross member that did support them back to the rear of the frame.
We also got the fuel inlet, return line, and rear brake lines ran in the frame. We will remove them to paint the frame and reinstall them after that.
Next up was getting the new to this truck's cab prepped for primer and paint. We sanded and sanded, repaired some rust holes, removed the glass and interior, blew off, and wiped down to blow it all off. I must have missed the dash because when I sprayed the paint over the primer, I had some areas that fish eyed. I repaired them the next day.
Now the primer and paint. I have to fill in the gas tank filler, and reprime some scratches from the windshield being installed, but it turned out ok. I went ahead and primered these fenders even though I may not be using them. They may have to work for now.
You can see my youngest brother in the last pic posing. He's home from Ca and will be leaving soon to go to training in the desert then off to Afganiland in September. I wish him luck, and will miss him again until next time. We did get his 92 F-350 running so he could drive it while he was home again. Man, I forgot how nice that truck was.
Ryan
Old 07-05-2011, 09:42 PM   #305
onebadbowtie
onebadbowtie's Avatar
keep up the good work!!
James
94' Chevy K1500 Extended Cab 4x4 5.7
72' Chevy LWB K10, 350, SM465, NP205 Project "Daily Driver"
onebadbowtie is offline   Reply With Quote
Old 07-05-2011, 09:54 PM   #306
jbclassix
Junk Yartist
jbclassix's Avatar
tell your bro "Semper Fi"
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 07-05-2011, 10:02 PM   #307
Dieselwrencher
Will do on both! Thanks guys.
Ryan
Old 07-06-2011, 12:43 PM   #308
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
Lookin Good Ryan! What's your latest due date?
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 07-06-2011, 02:20 PM   #309
Dieselwrencher
September 5th 2011. In all seriousness, I'd like to have it running soon so the parts aren't scattered through out the property. I'm tired of trying to figure out where I hid it all.
Ryan
Old 07-06-2011, 02:27 PM   #310
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
It looks great Ryan! Keep it up!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 07-06-2011, 02:37 PM   #311
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Lookin good!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 07-06-2011, 02:50 PM   #312
Dieselwrencher
Hopefully I can get started on the trans this weekend. Or at least get the trans cross member situated and done. We got he seat mounted in the cab. Let me tell you, I love that there is fuel tank in side the cab now. More leg room, and the console will flip up again.
Ryan
Old 07-06-2011, 09:47 PM   #313
jbclassix
Junk Yartist
jbclassix's Avatar
You know, it really doesn't matter how this truck comes out in the end, as long as that tach works it will be friggin sweet! I keep looking back at that and wishin!
-Jeremy
Rebuilding an NP205
Old 07-06-2011, 10:35 PM   #314
Dieselwrencher
You know what's real funny? Last week after work I went over there and my youngest brother painted the top of the dash for me. I unmasked it, set my new dash pad on there, and then put in the gauge cluster. Holy cow, it looked sweet. Of course I didn't snap a pic. I will in the morning though. I need to try to get my hydra boost on there so I can get this thing moving down a high way off of a trailer.
Ryan
Old 07-07-2011, 03:23 PM   #315
Dieselwrencher
Not much for progress, but I have more pics.
Here is part of my 5" exhaust. This is the tail pipe and muffler delete.
Windshield is in with a new gasket. (Needs cleaned badly.)
Seats are in and mounted in the new cab. You can see the rear window is in as well but it has to come back out. The gasket got torn on the install. The front fenders are edged, hood is sanded and waiting on some primer. We started sanding the doors, but they need some sand blasting done on them.
Ryan
Old 07-07-2011, 09:24 PM   #316
Cameron 1137
Cameron 1137's Avatar
Wow! and I thought 3" was going to be alot.
Nice progress, looks great!
Cam
1972 Chevy C/10 "Custom Cruiser Project" Build Thread
1961 Olds Super 88 (Daily)
1966 Chevy Corvair 500, "Marigold" SOLD
2005 Subaru Outback Wagon DEAD
2008 Pontiac G8, New Winter/Daily
Cameron 1137 is offline   Reply With Quote
Old 07-07-2011, 11:10 PM   #317
Dieselwrencher
3" on one of these is stock. We can't have that!
Here's a little more progress. I got the glove box door, hinge and stop, and ash tray cleaned, sanded, primed and painted. Tomorrow I'm going to do the door hinges and start on my interior color switch from dark olive to black.
Ryan
Old 07-08-2011, 01:00 AM   #318
67chevy1series
67chevy1series's Avatar
wow looks awesome!
67chevy1series is offline   Reply With Quote
Old 07-08-2011, 02:05 AM   #319
Dieselwrencher
Thanks Rick!
Ryan
Old 07-08-2011, 04:23 PM   #320
Dieselwrencher
I got the glove box lid back on, ash tray in, dash pad sat on, and gauge cluster screwed in. I took some pics because I am loving the new look from that green.
I'll post pics later of my latest shopping spree I had to go on today so I can try and get this thing buttoned up. I might even start estimating how much I have in this thing as well. That could be scary.
Ryan
Old 07-08-2011, 08:40 PM   #321
jbclassix
Junk Yartist
jbclassix's Avatar
saaawwweeeeettttt!!!!!!!
-Jeremy
Rebuilding an NP205
Old 07-08-2011, 08:57 PM   #322
Dieselwrencher
I think tonight when I get home, I will start to gather what parts receipts I have for this thing and get a (scary) idea how much is actually in this truck. I better not let the wife see it. I bet I could have purchased a dang nice cheyenne super 4x4 that runs and drives, and mine is still beating my butt!
Ryan
Old 07-08-2011, 09:24 PM   #323
72-c20
Packrat
72-c20's Avatar
I hear you there... way more in my '72 than I care to think about....
gone: --'07 Tahoe LTZ 4WD
--'68 Firebird 400 Convertible
gone: --'72 Chevy K20
72-c20 is offline   Reply With Quote
Old 07-08-2011, 09:37 PM   #324
Dieselwrencher
Hey Mick, how have you been? Yeah, I'm just glad she likes old cars and trucks or I'm sure I wouldn't have as many as I do.
Ryan
Old 07-09-2011, 01:39 AM   #325
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Your making some great progress Ryan...and it doesnt matter how much you could have bought a completed Cheyenne Super for....your gonna have something way Cooler when your done.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
